While the update itself went fine, can’t stay aside and not mention that since the advent of plasma 5.25 every time i use VirtualBox or Blender while i have a browser opened in another Activity, and then i try to edit something in Inkscape or Gimp (for example) in Work Activity, or i open any GTK+ app, all the context menus and the file dialog of all those opened apps (Qt or GTK+) are behind their main window. I can see them via the Overview, Present Windows or Desktop Grid, but i can’t get them the focus unless i minimize the main application window.
When this pops up in logs:
gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
and also
A backend call failed: No such method 'CreateMonitor' in interface 'org.freedesktop.impl.portal.Inhibit' at object path '/org/freedesktop/portal/desktop' (signature 'ooss')
The entire UI is broken, as mentioned above, and sometimes those messages will spam the log ad nauseam.
The Panel, regardless where is placed, from that moment will cover all windows, even tho is set otherwise, including full screen apps and the System Tray menu will open under whatever application/window is opened. Resolution is to do what i mentioned above, minimize main application window or all and get the use of the Panel menu again, but once an application window is app, all fails to work again.
Once i close them and i start using other applications, things get back to normal till next time. Due to my workflow it happens 90% of the time.
The 5.25.3 did not sort this out for me, and since i was able to reproduce on 2 installs, i gather is something that might affect others too. Would be great if someone else can confirm this, so we could fill a bug report, or maybe point me to something that i might have missed.
