Plank not start after logout and login
Hi.
I installed plank in manjaro xfce.
plank work in normal system boot but if I logout and login plank not start.
Not only in manjaro IN ALL LINUX DISTROS !
sounds like a bug in plank. you should report there.
if you added it to startup it should just work.
Yes is bug.
But plank is not active develop or if active so have very bad developers that not fixed this.
this is only linux dock that can be use in xfce.
plank is not part of xfce, reporting it here does nothing.
i’ll tell you what if a dock is your thing, you should try there new desktop.
Works fine for me)
Screenshot_2021-07-15_09-06-44
