Hi
After running the Manjaro updates on the 23 May one of the applications that i use quite often seems to no longer load. I have cross posted this into the Pixinsight forum to see if they have any ideas also.
Previously all was working fine, however after the latest Manjaro updates when I am trying to start PI i can see the following error message when using Terminal to start the application.
libGL error: MESA-LOADER: failed to open radeonsi: /opt/PixInsight/bin/lib/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required
by /usr/lib/dri/radeonsi_dri.so) (search paths /usr/lib/dri, suffix _dri)
libGL error: failed to load driver: radeonsi
libGL error: MESA-LOADER: failed to open swrast: /opt/PixInsight/bin/lib/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required b
y /usr/lib/dri/swrast_dri.so) (search paths /usr/lib/dri, suffix _dri)
libGL error: failed to load driver: swrast
Failed to create OpenGL context for format QSurfaceFormat(version 2.0, options QFlags<QSurfaceFormat::FormatOption>(), depthBufferSize
24, redBufferSize -1, greenBufferSize -1, blueBufferSize -1, alphaBufferSize -1, stencilBufferSize 8, samples 0, swapBehavior QSurfaceF
ormat:[image]efaultSwapBehavior, swapInterval 1, colorSpace QSurfaceFormat:[image]efaultColorSpace, profile QSurfaceFormat::NoProfile)
Received signal 6
#0 0x7f27127b73c9 base::debug::CollectStackTrace()
#1 0x7f271271f716 base::debug::StackTrace::StackTrace()
#2 0x7f27127b6403 base::debug:[image]anonymous namespace)::StackDumpSignalHandler()
#3 0x7f27127b7346 base::debug:[image]anonymous namespace)::StackDumpSignalHandler()
#4 0x7f270b0318e0 (/usr/lib/libc.so.6+0x3e8df)
#5 0x7f270b08136c (/usr/lib/libc.so.6+0x8e36b)
#6 0x7f270b031838 raise
#7 0x7f270b01b535 abort
#8 0x7f270c499bc7 QMessageLogger::fatal()
#9 0x7f270900b57f QQuickWidgetPrivate::handleContextCreationFailure()
#10 0x7f270900b8b7 QQuickWidgetPrivate::createContext()
#11 0x7f270900d956 QQuickWidget::resizeEvent()
#12 0x7f270f237169 QtWebEngineCore::RenderWidgetHostViewQtDelegateWidget::resizeEvent()
#13 0x7f270e1bc9bf QWidget::event()
#14 0x7f270900e617 QQuickWidget::event()
#15 0x7f270f237472 QtWebEngineCore::RenderWidgetHostViewQtDelegateWidget::event()
#16 0x7f270e179def QApplicationPrivate::notify_helper()
#17 0x7f270e182b60 QApplication::notify()
#18 0x55626bbdd0df pi:[image]ixInsightApplication::notify()
#19 0x7f270c6ce52a QCoreApplication::notifyInternal2()
#20 0x7f270e1b4606 _ZN14QWidgetPrivate30sendPendingMoveAndResizeEventsEbb.localalias
#21 0x7f270e1b4569 _ZN14QWidgetPrivate30sendPendingMoveAndResizeEventsEbb.localalias
#22 0x7f270e1b4569 _ZN14QWidgetPrivate30sendPendingMoveAndResizeEventsEbb.localalias
#23 0x7f270e1b4569 _ZN14QWidgetPrivate30sendPendingMoveAndResizeEventsEbb.localalias
#24 0x7f270e1b4569 _ZN14QWidgetPrivate30sendPendingMoveAndResizeEventsEbb.localalias
#25 0x7f270e1b4569 _ZN14QWidgetPrivate30sendPendingMoveAndResizeEventsEbb.localalias
#26 0x7f270e1b4569 _ZN14QWidgetPrivate30sendPendingMoveAndResizeEventsEbb.localalias
#27 0x7f270e1b4569 _ZN14QWidgetPrivate30sendPendingMoveAndResizeEventsEbb.localalias
#28 0x7f270e1b4569 _ZN14QWidgetPrivate30sendPendingMoveAndResizeEventsEbb.localalias
#29 0x7f270e1b4569 _ZN14QWidgetPrivate30sendPendingMoveAndResizeEventsEbb.localalias
#30 0x7f270e1b8fe7 QWidgetPrivate:[image]repareToRender()
#31 0x7f270e1b9684 QWidget::render()
#32 0x7f270e1ba1b7 QWidget::render()
#33 0x55626c89ec2a pi::MovingWidgetAnimationPrivate::MovingWidgetAnimationPrivate()
#34 0x55626c89ed03 pi::MovingWidgetAnimation::MovingWidgetAnimation()
#35 0x55626c89ed79 pi::MovingWidget::MovingWidget()
#36 0x55626c5ac2f2 pi::AutoHideWidget::Show()
#37 0x55626c5afc5a pi:[image]ixInsightCentralWidget::ShowWidget()
#38 0x55626c5b61ae pi::ComponentWindow::Show()
#39 0x55626ba379c9 main
#40 0x7f270b01c290 (/usr/lib/libc.so.6+0x2928f)
#41 0x7f270b01c34a __libc_start_main
#42 0x55626ba8244a _start
r8: 0000000000000000 r9: 0000000000000073 r10: 0000000000000008 r11: 0000000000000246
r12: 0000000000000006 r13: 000055627764a600 r14: 00007ffd9847b540 r15: 000055627764a600
di: 0000000000000dac si: 0000000000000dac bp: 00007f270f450000 bx: 0000000000000dac
dx: 0000000000000006 ax: 0000000000000000 cx: 00007f270b08136c sp: 00007ffd9847b1d0
ip: 00007f270b08136c efl: 0000000000000246 cgf: 002b000000000033 erf: 0000000000000000
trp: 0000000000000000 msk: 0000000000000000 cr2: 0000000000000000
[end of stack trace]
Calling _exit(1). Core file will not be generated.
When i check i can see that there is a GLIBCXX_3.4.30 located in the /usr/lib64/libstdc++.so.6 but not in /opt/PixInsight/bin/lib/libstdc++.so.6 which has GLIBCXX_3.4.29.
Any thoughts or pointers please ?
Mark
