I use Manjaro Cinnamon with Pix as default picture viewer. When I try to preview an image in the printing dialog, the dialog simply closes without any message. I also tried Eye of Gnome with same result. Printing itself works flawlessly, and the print preview with Gimp works fine, although I would expect a more dedicated preview instead of a PDF. Is there anything to configure for use of print preview, or what can be the cause?
Found it by myself. I had to create a file ~/.config/gtk-3.0/settings.ini with content:
[Settings]
gtk-print-preview-command = xreader-previewer --unlink-tempfile --print-settings %s %f
