Pipewire stuttering fix
If you are doing any kind of screen capture on KDE, and noticed your mouse stuttering periodically, this guide is for you. This guide will be obsolete once there is a new kwin release, but until then, hopefully it helps out.
If anything breaks, you can do pacman -S kwin to go back to the original version of kwin.
This is no longer necessary as of the 5.27.11 release of kwin.
