I have a PC that has multiple outputs on the MOBO.
In the past (with Debian) and pulse I had it configured to offer the outputs as separate outputs. (This allowed using something like Calf crossover to split an audio stream and send Carla to wire it to the appropriate out for high, low, sub.)
I am looking for info on how to define the onboard outputs in this way with pipewire.
Much of the info I’ve found on the web has given me an inkling of how to do it, but, I love to find more definitive info. The examples for surround sound, etc. don’t provide clarity…at least for my age muddled brain.
Any suggestions welcome.
Please provide system information as described (below).
Update Announcements
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes more indepth information is usually needed;
It’s best to ask your system directly.
Output of the inxi command with appropriate parameters will achieve this (naturally, formatted according to forum requirements) and will generally be more useful for those wishing to help:
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Required reading
Resources
Tomek
16 April 2025 17:36
3
Try qpwgraph or other gui mentioned on Arch Wiki - with them you can freely manipulate and redirect outputs anywhere.
Kernel: 6.14.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64
root=UUID=b1e5a73f-8c3a-41ba-b650-e410abdf8f42 rw plymouth.enable=0
disablehooks=plymouth resume=UUID=6091dcd2-1fa9-4c25-9ce6-ae3c1846a2fc
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Desktop Mobo: ASUSTeK model: M5A97 R2.0 v: Rev 1.xx
BIOS: American Megatrends v: 2603 date: 06/26/2015
Device-1: hidpp_battery_2 model: Logitech K520 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: discharging
Device-2: hidpp_battery_3 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
System RAM: total: 16 GiB available: 15.51 GiB used: 4.31 GiB (27.8%)
Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
Device-1: DIMM0 type: DDR3 detail: synchronous unbuffered (unregistered)
size: 4 GiB speed: spec: 1600 MT/s actual: 800 MT/s volts: N/A width (bits):
data: 64 total: 64 manufacturer: Crucial part-no: BLS4G3D1609DS1S00.
serial: <filter>
Device-2: DIMM1 type: DDR3 detail: synchronous unbuffered (unregistered)
serial: <filter>
Device-3: DIMM2 type: DDR3 detail: synchronous unbuffered (unregistered)
serial: <filter>
Device-4: DIMM3 type: DDR3 detail: synchronous unbuffered (unregistered)
serial: <filter>
Info: model: AMD FX-6350 bits: 64 type: MCP arch: Piledriver level: v2
built: 2012-13 process: GF 32nm family: 0x15 (21) model-id: 2 stepping: 0
microcode: 0x6000852
Topology: cpus: 1x dies: 1 clusters: 1 cores: 6 smt: <unsupported> cache:
L1: 288 KiB desc: d-6x16 KiB; i-3x64 KiB L2: 6 MiB desc: 3x2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 1405 min/max: 1400/3900 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1405 2: 1405 3: 1405
4: 1405 5: 1405 6: 1405 bogomips: 46956
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht
hw_pstate ibpb ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor
msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean
vme vmmcall wdt xop xsave
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ZOTAC
driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
non-free: 550-570.xx+ status: current (as of 2025-04; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: none off: DP-2,DP-3 empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:2504 class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 93 s-size: 1049x292mm (41.30x11.50")
s-diag: 1089mm (42.87")
Monitor-1: not-matched mapped: DP-3 pos: right res: mode: 1920x1080 hz: 60
scale: 100% (1) dpi: 94 size: 521x293mm (20.51x11.54") diag: 598mm (23.53")
modes: N/A
Monitor-2: not-matched mapped: DP-5 pos: primary,left res: mode: 1920x1080
hz: 60 scale: 100% (1) dpi: 94 size: 521x293mm (20.51x11.54")
diag: 598mm (23.53") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.133.07
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.4.309 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 570.133.07
device-ID: 10de:2504 surfaces: xcb,xlib
Device-1: Advanced Micro Devices [AMD/ATI] SBx00 Azalia vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383
class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
class-ID: 0403
API: ALSA v: k6.14.0-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
vendor: ASUSTeK P8 series driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager, sshd, systemd-timesyncd
Local Storage: total: 1.35 TiB used: 182.22 GiB (13.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0102 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
tech: SSD serial: <filter> fw-rev: 0100 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A02 scheme: MBR
ID-1: / raw-size: 214.77 GiB size: 210.34 GiB (97.94%)
used: 182.22 GiB (86.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: b1e5a73f-8c3a-41ba-b650-e410abdf8f42
ID-2: /home/<filter>/MiscWIP raw-size: N/A size: 915.82 GiB
used: 13.62 GiB (1.5%) fs: nfs4 remote: 192.168.53.123:/MiscWIP
ID-3: /home/<filter>/SharedData raw-size: N/A size: 915.82 GiB
used: 122.67 GiB (13.4%) fs: nfs4 remote: 192.168.53.123:/DataShare
dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: 6091dcd2-1fa9-4c25-9ce6-ae3c1846a2fc
ID-1: /dev/sdb1 maj-min: 8:17 size: 222.62 GiB fs: ext4 label: N/A
uuid: 17bddbbc-f6c9-4ca1-88a4-93904b18af03
ID-2: /dev/sdb2 maj-min: 8:18 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sdb5 maj-min: 8:21 size: 975 MiB fs: swap label: N/A
uuid: fcd7cda8-a30c-49b6-845e-b15de688b122
ID-4: /dev/sdc1 maj-min: 8:33 size: 931.51 GiB fs: ext4 label: N/A
uuid: 8d462e2d-f3bf-41ec-80e2-f18ac6fffd94
Hub-1: 1-0:1 info: full speed or root hub ports: 5 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Hub-2: 2-0:1 info: full speed or root hub ports: 5 rev: 2.0
Hub-3: 2-4:2 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0
chip-ID: 1a40:0801 class-ID: 0900
Hub-4: 2-4.2:11 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0
Hub-5: 2-4.2.1:12 info: Realtek RTS5411 Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 2-4.2.2:13 info: Sunplus Innovation Optical Mouse type: mouse
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 1bcf:0005 class-ID: 0301
Device-2: 2-4.2.3:14 info: Logitech Unifying Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c52b class-ID: 0300
Hub-6: 3-0:1 info: full speed or root hub ports: 5 rev: 2.0
Hub-7: 4-0:1 info: full speed or root hub ports: 4 rev: 2.0
Hub-8: 5-0:1 info: full speed or root hub ports: 5 rev: 1.1
Hub-9: 6-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-10: 7-0:1 info: full speed or root hub ports: 4 rev: 1.1
Device-1: 7-4:2 info: STMicro duckyPad(2020) type: keyboard
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0483:d11c class-ID: 0301
serial: <filter>
Hub-11: 8-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-12: 9-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-13: 10-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-14: 10-2:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
Hub-15: 11-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-16: 11-2:2 info: Realtek Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
System Temperatures: cpu: 17.6 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Packages: pm: pacman pkgs: 1787 libs: 458 tools: octopi,pamac,yay
pm: flatpak pkgs: 0
1: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
2: http://manjaro.grena.ge/stable/$repo/$arch
3: https://mirrors2.manjaro.org/stable/$repo/$arch
4: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
5: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
6: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
7: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
8: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 263
1: cpu: 200% command: ps pid: 21546 mem: 3.84 MiB (0.0%)
2: cpu: 4.2% command: pipewire.conf started-by: SciTE pid: 19656
mem: 48.2 MiB (0.3%)
3: cpu: 3.9% command: firefox pid: 4077 mem: 916.5 MiB (5.7%)
4: cpu: 2.3% command: qpwgraph pid: 21439 mem: 172.3 MiB (1.0%)
5: cpu: 1.2% command: thunar pid: 19322 mem: 52.5 MiB (0.3%)
Memory top: 5 of 263
1: mem: 916.5 MiB (5.7%) command: firefox pid: 4077 cpu: 3.9%
2: mem: 672.7 MiB (4.2%) command: plasmashell pid: 814 cpu: 1.1%
3: mem: 332.2 MiB (2.0%) command: firefox pid: 4224 cpu: 0.1%
4: mem: 291.6 MiB (1.8%) command: firefox pid: 9951 cpu: 0.7%
5: mem: 264.1 MiB (1.6%) command: firefox pid: 10396 cpu: 0.0%
Processes: 263 Power: uptime: 6h 54m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 12 Shell: Zsh v: 5.9
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.38
If the Debian PulseAudio configuration was using remap-sink virtual devices, they can be loaded in pipewire-pulse by using pactl:
pactl load-module module-remap-sink sink_name=High remix=no master=alsa_output.pci-0000_00_14.2.analog-surround-51 channels=2 master_channel_map=front-left,front-right channel_map=front-left,front-right
pactl load-module module-remap-sink sink_name=Mid remix=no master=alsa_output.pci-0000_00_14.2.analog-surround-51 channels=2 master_channel_map=rear-left,rear-right channel_map=front-left,front-right
pactl load-module module-remap-sink sink_name=Low remix=no master=alsa_output.pci-0000_00_14.2.analog-surround-51 channels=2 master_channel_map=front-center,lfe channel_map=front-left,front-right
Or pw-loopback:
pw-loopback --capture-props='media.class=Audio/Sink node.name=High audio.position=[FL FR]' --playback-props='audio.position=[FL FR]'
pw-loopback --capture-props='media.class=Audio/Sink node.name=Mid audio.position=[FL FR]' --playback-props='audio.position=[RL RR]'
pw-loopback --capture-props='media.class=Audio/Sink node.name=Low audio.position=[FL FR]' --playback-props='audio.position=[C LFE]'
PipeWire Wiki - Virtual devices · Remap Sink
But the suggestion by @Tomek to use qpwgraph GUI in pipewire-jack (change the card profile to pro-audio ) is probably simpler to implement and maintain
Ben
17 April 2025 07:03
6
Tomek:
qpwgraph
This is pretty cool - it also updates live - fascinating to watch when I connect my phone (audio via bluetooth), then change audio output from analog 4.0 to quadrophonic.
I’m registering a disconnect (in my brain…)
when I fire up qpwgraph I get this. And it doesn’t appear to show anything but 2 analog outputs. And, I see no option for pro-audio.
Edit: I see the pro-audio in in the volume control application…
Your posted system information has been tidied for you. In future you are expected to post code or command output as preformatted text.
I recall this being brought to your attention on multiple occasions. The link was also included in post #2 .
Please make an effort.
Indeed, I have very bad memory.
I’m sorry the quality of my questions don’t live up to your expectations.
After finding the pro-audio setting the system outputs are available.
Now I need to figure out how to get sinks that appear from things like Eliza and Firefox to not disconnect for each new song.
Perhaps I should start a new thread for that.
Hmm…while the “pro audio” channels show up as 8 playback_AUX# channels, I can only get sound out of AUX0 & 1.
I’ll presume that comment was meant as a “thanks” for editing and correcting it, shall I?
The quality of your pasted system information was in question. At least now it’s easier for those who might wish to help with your issue, to negotiate the information you provide.
What a difference two simple lines can make…
Your wall of text …
Yes, thanks.
Now I need to remember the xml that allowed a similar expandable field like that.
I know I figured that at one point as well.
drmacro:
Discourse, the software upon which the Manjaro forum is built, allows a combination of markdown, HTML and BBCode; a limited subset of each.
The following links are not exhaustive, but may be useful to bookmark as a quick reference.
Interesting, I can route audio to all the “pro audio” channels on a external 7.1 USB interface.
But, even though 8 AUX channels show on the internal sound no sound when other AUX0/1 are patched.
Ben
18 April 2025 02:56
16
drmacro:
There is nothing to remember, it is an extremely basic skill - and your sarcastic deflection is duly noted.
Also noteworthy is that as you type in this forum, there are symbols at the top of the edit window designed to give direct visual access.
Code
To enter code, you can type a backtick to start the code, and another to finish.That will appear like this’.
To enter a code block, like a paragraph, then you can use three backticks on a new line, then start on the next line:
This is how you type a code 'block'
This can also be achieved with three tilde ~~~
Three tilde will appear like this
But really, it’s quite simple to also use the symbol in the EDIT window that looks like </> if you don’t remember (and you’ll see that the effect is to put a backtick before and after what you have selected).
After some more searching around I looked at what alsamixer showed.
It appeared to have the “pro audio” channels enabled. But poking around some more showed additional channels labeled Surround, Center, LFE, Side, and Line. All were muted, once unmuted the wiring seems to work as expected for the onboard analog audio.
drmacro:
ALSA mixer control for Line is to monitor audio from Line-In jack, not a surround channel
I also suggest set alsamixer control Auto-Mute Mode to Disabled to prevent rear audio channels being muted if headphones are plugged in
and use this command to save changes to ALSA settings:
sudo alsactl store
