hey,
i have an issue, where can i change the sample rate for pipewire, i cant found the configs,
nothing in:
tree /etc/pipewire
/etc/pipewire
├── client.conf.d
├── client-rt.conf.d
├── minimal.conf.d
├── pipewire.conf.d
└── pipewire-pulse.conf.d
and in the home folder under the .config is no pipewire entry
any idea where i can find the configs or is there ab better solution to change the sample rate for an: BEHRINGER International GmbH UMC204HD 192k
its connected via USB
thx i copyed the config from /user/share/pipewire/pipewire.conf > ~/.config/pipewire/pipewire.conf and set the entrys to:
default.clock.rate = 192000
default.clock.allowed-rates = [ 48000, 88200, 96000, 176400, 192000 ]
now i check how i can get it automatic to 192000 when the device can it
6x12
14 April 2023 20:14
4
In the link @mithrial posted it says: ’ with configuration above, no resampling is done when supported.’ so
default.clock.allowed-rates = [ 192000 ]
should force resampling of everything below 192k.
Just a warning. Unless you have a pretty decent cpu/machine these settings may stress your pc, ramp up temps and fan noise whilst getting you no benefits at all.
Create .config/pipewire/pipewire.conf.d/clock-rate.conf
with
context.properties = {
default.clock.allowed-rates = [ 48000 44100 88200 96000 192000 ]
thats all
with your config everything is resample to 192khz
system
Closed
19 April 2023 08:21
6
