Pipewire process using 100% of CPU (2)
I am with the same problem
Your issue has been moved to a dedicated topic.
Please note that so-called “me too” posts are discouraged.
Note that another Member suggests;
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
Required reading
Resources
Are you referring to the wireplumber process? I had this as well upon boot up.
Member @cimarronline has reported this issue;
Please monitor the above link for any updates. When fixed it should eventually filter through the branches.
Also, see here:
pipewire 1.4 100% core usage with older kernels (#4621)
Wim Taymans closed with merge request !2313 (merged) 1 day ago
I applied that patch. Please test.
