Why doesn’t pipewire when installed not produce audio for HDMI using Asus i5 11400, 730 HDMI Audio? Before pipewire install, pulseaudio works fine with all outputs and Inputs.
If you could set up a test procedure for my hardware that would be great?
Heres my info
aplay -l
card 1: PCH [HDA Intel PCH], device 0: ALC897 Analog [ALC897 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: PCH [HDA Intel PCH], device 1: ALC897 Digital [ALC897 Digital]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 3: HDMI 0 [Sceptre N43]
Subdevices: 0/1
works
speaker-test -Dhw:1,0 -c2
speaker-test -Dhw:1,1 -c2
Playback device is hw:1,1
Stream parameters are 48000Hz, S16_LE, 2 channels
Using 16 octaves of pink noise
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 64 to 1048576
Period size range from 32 to 524288
Using max buffer size 1048576
Periods = 4
was set period_size = 262144
was set buffer_size = 1048576
0 - Front Left
1 - Front Right
^CTime per period = 9.061709
[vic@500gbSSD ~]$ speaker-test -Dhw:1,0 -c2
speaker-test 1.2.8
Playback device is hw:1,0
Periods = 4
0 - Front Left
^C 1 - Front Right
Time per period = 1.785710
Not working
speaker-test -Dhw:1,3 -c2
[vic@500gbSSD ~]$ speaker-test -Dhw:1,3 -c2
speaker-test 1.2.8
Playback device is hw:1,3
Playback open error: -16,Device or resource busy
Why is device is hw:1,3 busy… I dont understand? Why no audio from this port… its listed as functional… I need an exact answer and test procedures… using Manjaro and Archlinux with kde. * Asus 560, I5-11400 with graphics, 730, 32gb ddr4" Windows 11 works great at 4k 60hz, I really want to get this working out of the box no issues…" THIS SAME CONFIGUration works fine with the Dell Optiplex 3050, I5-6500 530, 16gb ddr4, 4k @30hz, installed on 500gb ssd usb, just went over and plugged in drive usb 3 and reboot uefi to boot off ssd)
Thanks
