Hi fellow penguins,
I have an issue since I switched to pipewire: Any bluetooth headset is appearing as two capture devices, for my daily driver headset, it’s also connecting the wrong one per default (no sound captured).
I’m running manjaro XFCE kernel 6.11.2-4, trying to get a Bose NC700 to work, but the issue is the same with any bluetooth headset.
I tried to change the priority in wireplumber, but it doesn’t take effect. The default session and driver prio was 2010, I tried setting it to 2050 for one of the sources , but it’s still 2010 after restarting pipewire & wireplumber (see conf below).
Thanks in advance for your help!
Helvum for visualization:
$ cat ~/.config/wireplumber/wireplumber.conf.d/bose_prio.conf
rule = [
matches = [
node.name = "bluez_input.60_AB_D2_76_87_D3.0"
actions = {
update-props = {
priority.driver = 2050,
priority.session = 2050
matches = [
node.name = "!bluez_input.60_AB_D2_76_87_D3.0"
node.name = "bluez_input.60_AB_D2_76_87_D3"
actions = {
update-props = {
priority.driver = 1010,
priority.session = 1010
matches = [
node.name = "~.*Driver"
actions = {
update-props = {
node.disabled = true
matches = [
node.name = "Midi-Bridge"
actions = {
update-props = {
monitor.alsa.rules =
matches =
node.name = "~.*"
actions =
update-props =
item.features.monitor = false
