Pipewire doesn't use ldac or aptx
So I installed pipewire because of the lower latency and the better support for my headphones (Sony WH-1000X M3) and to keep compatiblity with GNOME I had to install pipewire-pulse. But ever since making the switch, I only can use the SBC codec.
I know that I can use aptX and LDAC with my headphones.
Here is output of pactl list sinks
Sink #46
	State: SUSPENDED
	Description: Starship/Matisse HD Audio Controller Stéréo analogique
	Driver: PipeWire
	Sample Specification: s32le 2ch 48000Hz
	Channel Map: front-left,front-right
	Owner Module: 4294967295
	Mute: no
	Volume: front-left: 32559 /  50% / -18.23 dB,   front-right: 32559 /  50% / -18.23 dB
	        balance 0.00
	Base Volume: 65536 / 100% / 0.00 dB
	Monitor Source: alsa_output.pci-0000_0b_00.4.analog-stereo.monitor
	Latency: 0 usec, configured 0 usec
	Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Properties:
		alsa.card = "1"
		alsa.card_name = "HD-Audio Generic"
		alsa.class = "generic"
		alsa.device = "0"
		alsa.id = "ALC887-VD Analog"
		alsa.long_card_name = "HD-Audio Generic at 0xfc700000 irq 81"
		alsa.name = "ALC887-VD Analog"
		alsa.resolution_bits = "16"
		alsa.subclass = "generic-mix"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		api.alsa.card.longname = "HD-Audio Generic at 0xfc700000 irq 81"
		api.alsa.card.name = "HD-Audio Generic"
		api.alsa.path = "front:1"
		api.alsa.pcm.card = "1"
		api.alsa.pcm.stream = "playback"
		audio.channels = "2"
		audio.position = "FL,FR"
		card.profile.device = "5"
		device.api = "alsa"
		device.class = "sound"
		device.id = "42"
		device.profile.description = "Stéréo analogique"
		device.profile.name = "analog-stereo"
		device.routes = "2"
		factory.name = "api.alsa.pcm.sink"
		media.class = "Audio/Sink"
		device.description = "Starship/Matisse HD Audio Controller Stéréo analogique"
		node.name = "alsa_output.pci-0000_0b_00.4.analog-stereo"
		node.nick = "ALC887-VD Analog"
		node.pause-on-idle = "false"
		object.path = "alsa:pcm:1:front:1:playback"
		priority.driver = "1009"
		priority.session = "1009"
		factory.id = "18"
		clock.quantum-limit = "8192"
		client.id = "32"
		node.driver = "true"
		factory.mode = "merge"
		audio.adapt.follower = ""
		library.name = "audioconvert/libspa-audioconvert"
		object.id = "44"
		object.serial = "46"
		node.max-latency = "16384/48000"
	Ports:
		analog-output-lineout: Sortie ligne (type: Line, priority: 9000, availability group: Legacy 4, available)
		analog-output-headphones: Casque audio (type: Headphones, priority: 9900, availability group: Legacy 5, not available)
	Active Port: analog-output-lineout
	Formats:
		pcm
Sink #9397
	State: SUSPENDED
	Description: Navi 10 HDMI Audio Digital Stereo (HDMI 3)
	Driver: PipeWire
	Mute: no
	Volume: front-left: 48287 /  74% / -7.96 dB,   front-right: 48287 /  74% / -7.96 dB
	        balance 0.00
	Monitor Source: alsa_output.pci-0000_09_00.1.hdmi-stereo-extra2.monitor
	Flags: HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
	Properties:
		alsa.card = "0"
		alsa.card_name = "HDA ATI HDMI"
		alsa.device = "8"
		alsa.id = "HDMI 2"
		alsa.long_card_name = "HDA ATI HDMI at 0xfcba0000 irq 79"
		alsa.name = "KG241Q S"
		api.alsa.card.longname = "HDA ATI HDMI at 0xfcba0000 irq 79"
		api.alsa.card.name = "HDA ATI HDMI"
		api.alsa.path = "hdmi:0,2"
		api.alsa.pcm.card = "0"
		card.profile.device = "11"
		device.api = "alsa"
		device.id = "41"
		device.profile.description = "Digital Stereo (HDMI 3)"
		device.profile.name = "hdmi-stereo-extra2"
		device.routes = "1"
		device.description = "Navi 10 HDMI Audio Digital Stereo (HDMI 3)"
		node.name = "alsa_output.pci-0000_09_00.1.hdmi-stereo-extra2"
		node.nick = "KG241Q S"
		object.path = "alsa:pcm:0:hdmi:0,2:playback"
		priority.driver = "616"
		priority.session = "616"
		factory.id = "18"
		client.id = "32"
		object.id = "43"
		object.serial = "9397"
	Ports:
		hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, availability group: Legacy 3, available)
	Active Port: hdmi-output-2
	Formats:
		pcm
Sink #9689
	State: RUNNING
	Description: XooparBoy Stereo
	Driver: PipeWire
	Sample Specification: s16le 2ch 48000Hz
	Mute: no
	Volume: front-left: 40766 /  62% / -12.37 dB,   front-right: 40766 /  62% / -12.37 dB
	        balance 0.00
	Monitor Source: bluez_output.CE_DA_1B_27_38_6B.a2dp-sink.monitor
	Flags: HARDWARE HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Properties:
		api.bluez5.address = "CE:DA:1B:27:38:6B"
		api.bluez5.codec = "sbc_xq"
		api.bluez5.profile = "a2dp-sink"
		api.bluez5.transport = ""
		card.profile.device = "1"
		device.id = "101"
		device.routes = "1"
		factory.name = "api.bluez5.a2dp.sink"
		device.description = "XooparBoy Stereo"
		node.name = "bluez_output.CE_DA_1B_27_38_6B.a2dp-sink"
		priority.driver = "1010"
		priority.session = "1010"
		factory.id = "8"
		device.api = "bluez5"
		object.id = "122"
		object.serial = "9689"
		client.id = "32"
	Ports:
		handsfree-output: Mains-libres (type: Handsfree, priority: 0, available)
	Active Port: handsfree-output
	Formats:
		pcm
How can I enable the other codecs?
I only found this with a quick search:
https://kasunc.medium.com/enabling-ldac-codec-support-in-fedora-linux-for-bluetooth-headsets-66008e2287ae
It pertains to Fedora but I gather from it that some (these) codecs are needed to be installed.
I don’t know how to check for these in Arch / Manjaro
but maybe they are currently missing in your system.
I checked beforehand, and the libraries of the codecs were already installed (of course because I could use them with pulse) and in the tutorial, the two other packages aren’t event on the AUR so it’s useless for Arch users.
… of course the package names are not the same between Fedora and Arch/Manjaro
I thought it contained information that may be useful though.
… apparenty not
Can’t help further.
For pipewire issues I recommend opening an issue in the Gitlab: Issues · PipeWire / pipewire · GitLab
Some codecs require recent kernels or bluetooth versions. Could be related.
Take a look at:
Which packages? That article is over two years old and out of date.
The pulseaudio-modules-bt repo linked there was archived as the same functionality is available via Bluez. There was an AUR package but it was deleted last year sometime.
Having bluez and gst-plugins-bad along with the normal PipeWire packages should be enough.
i’m not sure what is the latest, but the way it was when pulse was upgraded into v15, support for pulseaudio-modules-bt (which brought support for HD codecs) was deprecated, though pulse v15 was supposed to support all HD bluetooth codecs it was non-available in the official packages from arch. only pipewire supported most HD-codecs out of the box. i’m not sure whether LDAC is supported as a sink, but aptx and aptx-HD is. supported endpoints;
bluetoothd[936]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/ldac
bluetoothd[936]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSink/aptx_hd
bluetoothd[936]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_hd
bluetoothd[936]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aac
bluetoothd[936]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSink/sbc
bluetoothd[936]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/sbc
bluetoothd[936]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSink/sbc_xq
bluetoothd[936]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/sbc_xq
bluetoothd[936]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_ll_1
bluetoothd[936]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_ll_0
bluetoothd[936]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
bluetoothd[936]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
bluetoothd[936]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/faststream
bluetoothd[936]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/faststream_duplez
UPDATE: checked aptX-HD works.
when installing pipewire, always resort to installing manjaro-pipewire and nothing else.
pactl list sinks
Sink #60
        State: RUNNING
        Description: KZ Earphone-HD
        Driver: PipeWire
        Sample Specification: s24le 2ch 48000Hz
        Mute: no
        Volume: front-left: 30446 /  46% / -19.98 dB,   front-right: 30446 /  46% / -19.98 dB
                balance 0.00
        Monitor Source: bluez_output.34_D0_B8_92_FF_70.a2dp-sink.monitor
        Properties:
                api.bluez5.codec = "aptx_hd"
                api.bluez5.address = "34:D0:B8:92:FF:70"
                device.routes = "1"
                device.form_factor = "headphone"
                device.bus = "bluetooth"
                device.id = "55"
                device.description = "KZ Earphone-HD"
                node.name = "bluez_output.34_D0_B8_92_FF_70.a2dp-sink"
                device.icon_name = "audio-headphones-bluetooth"
                factory.id = "8"
                object.id = "56"
                object.serial = "60"
                client.id = "31"
        Ports:
                headphone-output: Headphone (type: Headphones, priority: 0, available)
        Active Port: headphone-output
        Formats:
                pcm
wouldnt hurt to check which bluetooth endpoints are registered in your system. re-install manjaro-pipewire
restart pipewire
systemctl --user restart pipewire.service
systemctl --user restart pipewire-pulse.service
restart bluetoothd
sudo systemctl restart bluetooth.service
get the registered endpoints;
journalctl -b | grep bluetoothd
I had installed pipewire with the meta-package and I did what you told me to, and there is no other codec available for the headset and I got the output of journalctl -b | grep bluetoothd :
jun 27 20:48:19 bary bluetoothd[1017]: Bluetooth daemon 5.64
jun 27 20:48:19 bary bluetoothd[1017]: Starting SDP server
jun 27 20:48:19 bary bluetoothd[1017]: Bluetooth management interface 1.18 initialized
jun 27 20:48:21 bary bluetoothd[1017]: profiles/audio/avctp.c:avctp_server_socket() setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 27 20:48:22 bary bluetoothd[1017]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSource/ldac
jun 27 20:48:22 bary bluetoothd[1017]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 27 20:48:22 bary bluetoothd[1017]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 27 20:48:22 bary bluetoothd[1017]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aac
jun 27 20:48:22 bary bluetoothd[1017]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSink/sbc
jun 27 20:48:22 bary bluetoothd[1017]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSource/sbc
jun 27 20:48:22 bary bluetoothd[1017]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 27 20:48:22 bary bluetoothd[1017]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 27 20:48:22 bary bluetoothd[1017]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 27 20:48:22 bary bluetoothd[1017]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 27 20:48:22 bary bluetoothd[1017]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 27 20:48:22 bary bluetoothd[1017]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 27 20:48:22 bary bluetoothd[1017]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSource/faststream
jun 27 20:48:22 bary bluetoothd[1017]: Endpoint registered: sender=:1.35 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 27 20:48:44 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/ldac
jun 27 20:48:44 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 27 20:48:44 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 27 20:48:44 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aac
jun 27 20:48:44 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSink/sbc
jun 27 20:48:44 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/sbc
jun 27 20:48:44 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 27 20:48:44 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 27 20:48:44 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 27 20:48:44 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 27 20:48:44 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 27 20:48:44 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 27 20:48:44 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/faststream
jun 27 20:48:44 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 27 20:48:46 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/ldac
jun 27 20:48:46 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 27 20:48:46 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 27 20:48:46 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aac
jun 27 20:48:46 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc
jun 27 20:48:46 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc
jun 27 20:48:46 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 27 20:48:46 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 27 20:48:46 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 27 20:48:46 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 27 20:48:46 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 27 20:48:46 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 27 20:48:46 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream
jun 27 20:48:46 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 27 21:25:14 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Message Notification: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 27 21:25:14 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Message Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 27 21:25:14 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Phone Book Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 27 21:25:14 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for File Transfer: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 27 21:25:14 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Object Push: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 28 10:48:03 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/ldac
jun 28 10:48:03 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 28 10:48:03 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 28 10:48:03 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aac
jun 28 10:48:03 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc
jun 28 10:48:03 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc
jun 28 10:48:03 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 28 10:48:03 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 28 10:48:03 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 28 10:48:03 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 28 10:48:03 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 28 10:48:03 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 28 10:48:03 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream
jun 28 10:48:03 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 28 10:48:03 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.86" (uid=1000 pid=1913 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="org.bluez.MediaEndpoint1.Error.NotImplemented" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 28 10:48:06 bary bluetoothd[1017]: profiles/audio/avctp.c:avctp_server_socket() setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 28 10:48:06 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Message Notification: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 28 10:48:06 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Message Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 28 10:48:06 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Phone Book Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 28 10:48:06 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for File Transfer: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 28 10:48:06 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Object Push: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 28 10:48:06 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/ldac
jun 28 10:48:06 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 28 10:48:06 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 28 10:48:06 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aac
jun 28 10:48:06 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc
jun 28 10:48:06 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc
jun 28 10:48:06 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 28 10:48:06 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 28 10:48:06 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 28 10:48:06 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 28 10:48:06 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 28 10:48:06 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 28 10:48:06 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream
jun 28 10:48:06 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 28 14:44:02 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/ldac
jun 28 14:44:02 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 28 14:44:02 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 28 14:44:02 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aac
jun 28 14:44:02 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc
jun 28 14:44:02 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc
jun 28 14:44:02 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 28 14:44:02 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 28 14:44:02 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 28 14:44:02 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 28 14:44:02 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 28 14:44:02 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 28 14:44:02 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream
jun 28 14:44:02 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 28 14:44:02 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.86" (uid=1000 pid=1913 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="org.bluez.MediaEndpoint1.Error.NotImplemented" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 28 14:44:05 bary bluetoothd[1017]: profiles/audio/avctp.c:avctp_server_socket() setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 28 14:44:05 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Message Notification: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 28 14:44:05 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Message Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 28 14:44:05 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Phone Book Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 28 14:44:05 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for File Transfer: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 28 14:44:05 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Object Push: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 28 14:44:05 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/ldac
jun 28 14:44:05 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 28 14:44:05 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 28 14:44:05 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aac
jun 28 14:44:05 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc
jun 28 14:44:05 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc
jun 28 14:44:05 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 28 14:44:05 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 28 14:44:05 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 28 14:44:05 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 28 14:44:05 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 28 14:44:05 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 28 14:44:05 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream
jun 28 14:44:05 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 28 15:58:50 bary bluetoothd[1017]: /org/bluez/hci0/dev_38_18_4C_7C_CB_3D/sep1/fd0: fd(29) ready
jun 28 20:14:10 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.86" (uid=1000 pid=1913 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 28 20:14:10 bary bluetoothd[1017]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
jun 28 20:16:15 bary bluetoothd[1017]: /org/bluez/hci0/dev_38_18_4C_7C_CB_3D/sep1/fd1: fd(31) ready
jun 28 21:02:42 bary bluetoothd[1017]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
jun 28 21:02:42 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.86" (uid=1000 pid=1913 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 29 11:18:47 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/ldac
jun 29 11:18:47 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 29 11:18:47 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 29 11:18:47 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aac
jun 29 11:18:47 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc
jun 29 11:18:47 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc
jun 29 11:18:47 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 29 11:18:47 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 29 11:18:47 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 29 11:18:47 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 29 11:18:47 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 29 11:18:47 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 29 11:18:47 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream
jun 29 11:18:47 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 29 11:18:47 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.86" (uid=1000 pid=1913 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="org.bluez.MediaEndpoint1.Error.NotImplemented" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 29 11:18:51 bary bluetoothd[1017]: profiles/audio/avctp.c:avctp_server_socket() setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 11:18:51 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Message Notification: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 11:18:51 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Message Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 11:18:51 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Phone Book Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 11:18:51 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for File Transfer: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 11:18:51 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Object Push: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 11:18:51 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/ldac
jun 29 11:18:51 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 29 11:18:51 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 29 11:18:51 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aac
jun 29 11:18:51 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc
jun 29 11:18:51 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc
jun 29 11:18:51 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 29 11:18:51 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 29 11:18:51 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 29 11:18:51 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 29 11:18:51 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 29 11:18:51 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 29 11:18:51 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream
jun 29 11:18:51 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 29 14:40:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/ldac
jun 29 14:40:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 29 14:40:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 29 14:40:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aac
jun 29 14:40:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc
jun 29 14:40:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc
jun 29 14:40:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 29 14:40:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 29 14:40:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 29 14:40:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 29 14:40:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 29 14:40:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 29 14:40:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream
jun 29 14:40:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 29 14:40:17 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.86" (uid=1000 pid=1913 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="org.bluez.MediaEndpoint1.Error.NotImplemented" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 29 14:40:21 bary bluetoothd[1017]: profiles/audio/avctp.c:avctp_server_socket() setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 14:40:21 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Message Notification: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 14:40:21 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Message Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 14:40:21 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Phone Book Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 14:40:21 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for File Transfer: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 14:40:21 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Object Push: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 14:40:21 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/ldac
jun 29 14:40:21 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 29 14:40:21 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 29 14:40:21 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aac
jun 29 14:40:21 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc
jun 29 14:40:21 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc
jun 29 14:40:21 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 29 14:40:21 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 29 14:40:21 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 29 14:40:21 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 29 14:40:21 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 29 14:40:21 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 29 14:40:21 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream
jun 29 14:40:21 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 29 19:42:50 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/ldac
jun 29 19:42:50 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 29 19:42:50 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 29 19:42:50 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aac
jun 29 19:42:50 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc
jun 29 19:42:50 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc
jun 29 19:42:50 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 29 19:42:50 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 29 19:42:50 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 29 19:42:50 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 29 19:42:50 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 29 19:42:50 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 29 19:42:50 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream
jun 29 19:42:50 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 29 19:42:50 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.86" (uid=1000 pid=1913 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="org.bluez.MediaEndpoint1.Error.NotImplemented" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 29 19:42:53 bary bluetoothd[1017]: profiles/audio/avctp.c:avctp_server_socket() setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 19:42:53 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Message Notification: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 19:42:53 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Message Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 19:42:53 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Phone Book Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 19:42:53 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for File Transfer: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 19:42:53 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Object Push: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 29 19:42:53 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/ldac
jun 29 19:42:53 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 29 19:42:53 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 29 19:42:53 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aac
jun 29 19:42:53 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc
jun 29 19:42:53 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc
jun 29 19:42:53 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 29 19:42:53 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 29 19:42:53 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 29 19:42:53 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 29 19:42:53 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 29 19:42:53 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 29 19:42:53 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream
jun 29 19:42:53 bary bluetoothd[1017]: Endpoint registered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 29 19:49:27 bary bluetoothd[1017]: /org/bluez/hci0/dev_CE_DA_1B_27_38_6B/sep1/fd2: fd(30) ready
jun 29 19:54:23 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.86" (uid=1000 pid=1913 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 29 19:54:23 bary bluetoothd[1017]: /org/bluez/hci0/dev_CE_DA_1B_27_38_6B/sep1/fd3: fd(27) ready
jun 29 20:01:39 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.86" (uid=1000 pid=1913 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 29 20:01:40 bary bluetoothd[1017]: /org/bluez/hci0/dev_CE_DA_1B_27_38_6B/sep1/fd4: fd(27) ready
jun 29 20:03:00 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.86" (uid=1000 pid=1913 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 29 20:03:00 bary bluetoothd[1017]: /org/bluez/hci0/dev_CE_DA_1B_27_38_6B/sep1/fd5: fd(27) ready
jun 29 20:06:14 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.86" (uid=1000 pid=1913 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 29 20:06:15 bary bluetoothd[1017]: /org/bluez/hci0/dev_CE_DA_1B_27_38_6B/sep1/fd6: fd(27) ready
jun 29 20:06:18 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.86" (uid=1000 pid=1913 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 29 20:06:19 bary bluetoothd[1017]: /org/bluez/hci0/dev_CE_DA_1B_27_38_6B/sep1/fd7: fd(27) ready
jun 29 20:07:34 bary bluetoothd[1017]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
jun 29 20:07:34 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.86" (uid=1000 pid=1913 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 29 20:07:48 bary bluetoothd[1017]: /org/bluez/hci0/dev_CE_DA_1B_27_38_6B/sep1/fd8: fd(31) ready
jun 29 20:07:55 bary bluetoothd[1017]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
jun 29 20:07:55 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.86" (uid=1000 pid=1913 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/ldac
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aac
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.86 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint registered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/ldac
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint registered: sender=:1.1785 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint registered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint registered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/aac
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint registered: sender=:1.1785 path=/MediaEndpoint/A2DPSink/sbc
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint registered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/sbc
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint registered: sender=:1.1785 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint registered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint registered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint registered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint registered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint registered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint registered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/faststream
jun 29 20:16:34 bary bluetoothd[1017]: Endpoint registered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 29 20:16:41 bary bluetoothd[1017]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
jun 29 20:16:47 bary bluetoothd[1017]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
jun 29 20:17:01 bary bluetoothd[1017]: Device is already marked as connected
jun 29 20:17:10 bary bluetoothd[1017]: /org/bluez/hci0/dev_38_18_4C_7C_CB_3D/sep1/fd9: fd(30) ready
jun 29 20:28:35 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/ldac
jun 29 20:28:35 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1785 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 29 20:28:35 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 29 20:28:35 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/aac
jun 29 20:28:35 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1785 path=/MediaEndpoint/A2DPSink/sbc
jun 29 20:28:35 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1785 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 29 20:28:35 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 29 20:28:35 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 29 20:28:35 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 29 20:28:35 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 29 20:28:35 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 29 20:28:35 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/faststream
jun 29 20:28:35 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1785 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 29 20:28:36 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/ldac
jun 29 20:28:36 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 29 20:28:36 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 29 20:28:36 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aac
jun 29 20:28:36 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/sbc
jun 29 20:28:36 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/sbc
jun 29 20:28:36 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 29 20:28:36 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 29 20:28:36 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 29 20:28:36 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 29 20:28:36 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 29 20:28:36 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 29 20:28:36 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/faststream
jun 29 20:28:36 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 29 20:28:42 bary bluetoothd[1017]: /org/bluez/hci0/dev_38_18_4C_7C_CB_3D/sep1/fd10: fd(33) ready
jun 29 20:28:43 bary bluetoothd[1017]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
jun 29 20:31:49 bary bluetoothd[1017]: plugins/policy.c:reconnect_timeout() Reconnecting services failed: Operation already in progress (114)
jun 29 20:33:06 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.1811" (uid=1000 pid=328271 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 29 20:33:06 bary bluetoothd[1017]: /org/bluez/hci0/dev_38_18_4C_7C_CB_3D/sep1/fd11: fd(27) ready
jun 29 20:57:13 bary bluetoothd[1017]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
jun 29 20:57:13 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.1811" (uid=1000 pid=328271 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 29 23:07:47 bary bluetoothd[1017]: /org/bluez/hci0/dev_38_18_4C_7C_CB_3D/sep1/fd12: fd(29) ready
jun 30 00:01:52 bary bluetoothd[1017]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
jun 30 00:01:52 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.1811" (uid=1000 pid=328271 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 30 10:06:21 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/ldac
jun 30 10:06:21 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 30 10:06:21 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 30 10:06:21 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aac
jun 30 10:06:21 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/sbc
jun 30 10:06:21 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/sbc
jun 30 10:06:21 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 30 10:06:21 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 30 10:06:21 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 30 10:06:21 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 30 10:06:21 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 30 10:06:21 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 30 10:06:21 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/faststream
jun 30 10:06:21 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 30 10:06:21 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.1811" (uid=1000 pid=328271 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="org.bluez.MediaEndpoint1.Error.NotImplemented" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 30 10:06:24 bary bluetoothd[1017]: profiles/audio/avctp.c:avctp_server_socket() setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 10:06:24 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Message Notification: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 10:06:24 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Message Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 10:06:24 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Phone Book Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 10:06:24 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for File Transfer: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 10:06:24 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Object Push: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 10:06:24 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/ldac
jun 30 10:06:24 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 30 10:06:24 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 30 10:06:24 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aac
jun 30 10:06:24 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/sbc
jun 30 10:06:24 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/sbc
jun 30 10:06:24 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 30 10:06:24 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 30 10:06:24 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 30 10:06:24 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 30 10:06:24 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 30 10:06:24 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 30 10:06:24 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/faststream
jun 30 10:06:24 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 30 10:08:34 bary bluetoothd[1017]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Device or resource busy
jun 30 10:08:41 bary bluetoothd[1017]: /org/bluez/hci0/dev_38_18_4C_7C_CB_3D/sep1/fd13: fd(29) ready
jun 30 11:19:15 bary bluetoothd[1017]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
jun 30 11:19:15 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/ldac
jun 30 11:19:15 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 30 11:19:15 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 30 11:19:15 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aac
jun 30 11:19:15 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/sbc
jun 30 11:19:15 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/sbc
jun 30 11:19:15 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 30 11:19:15 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 30 11:19:15 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 30 11:19:15 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 30 11:19:15 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 30 11:19:15 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 30 11:19:15 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/faststream
jun 30 11:19:15 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 30 11:19:15 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.1811" (uid=1000 pid=328271 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 30 11:19:15 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.1811" (uid=1000 pid=328271 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="org.bluez.MediaEndpoint1.Error.NotImplemented" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 30 11:19:18 bary bluetoothd[1017]: profiles/audio/avctp.c:avctp_server_socket() setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 11:19:18 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Message Notification: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 11:19:18 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Message Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 11:19:18 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Phone Book Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 11:19:18 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for File Transfer: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 11:19:18 bary bluetoothd[1017]: src/profile.c:ext_start_servers() L2CAP server failed for Object Push: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 11:19:18 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/ldac
jun 30 11:19:18 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 30 11:19:18 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 30 11:19:18 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aac
jun 30 11:19:18 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/sbc
jun 30 11:19:18 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/sbc
jun 30 11:19:18 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 30 11:19:18 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 30 11:19:18 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 30 11:19:18 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 30 11:19:18 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 30 11:19:18 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 30 11:19:18 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/faststream
jun 30 11:19:18 bary bluetoothd[1017]: Endpoint registered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 30 11:19:54 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/ldac
jun 30 11:19:54 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 30 11:19:54 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 30 11:19:54 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aac
jun 30 11:19:54 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/sbc
jun 30 11:19:54 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/sbc
jun 30 11:19:54 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 30 11:19:54 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 30 11:19:54 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 30 11:19:54 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 30 11:19:54 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 30 11:19:54 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 30 11:19:54 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/faststream
jun 30 11:19:54 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.1811 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 30 11:19:55 bary bluetoothd[1017]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/ldac
jun 30 11:19:55 bary bluetoothd[1017]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 30 11:19:55 bary bluetoothd[1017]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 30 11:19:55 bary bluetoothd[1017]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aac
jun 30 11:19:55 bary bluetoothd[1017]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSink/sbc
jun 30 11:19:55 bary bluetoothd[1017]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/sbc
jun 30 11:19:55 bary bluetoothd[1017]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 30 11:19:55 bary bluetoothd[1017]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 30 11:19:55 bary bluetoothd[1017]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 30 11:19:55 bary bluetoothd[1017]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 30 11:19:55 bary bluetoothd[1017]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 30 11:19:55 bary bluetoothd[1017]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 30 11:19:55 bary bluetoothd[1017]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/faststream
jun 30 11:19:55 bary bluetoothd[1017]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 30 11:20:02 bary bluetoothd[1017]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
jun 30 11:20:17 bary bluetoothd[1017]: Terminating
jun 30 11:20:17 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.2267" (uid=1000 pid=364422 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 30 11:20:17 bary bluetoothd[1017]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
jun 30 11:20:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/ldac
jun 30 11:20:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.2267 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 30 11:20:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 30 11:20:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aac
jun 30 11:20:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.2267 path=/MediaEndpoint/A2DPSink/sbc
jun 30 11:20:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/sbc
jun 30 11:20:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.2267 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 30 11:20:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 30 11:20:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 30 11:20:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 30 11:20:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 30 11:20:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 30 11:20:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/faststream
jun 30 11:20:17 bary bluetoothd[1017]: Endpoint unregistered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 30 11:20:17 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.2267" (uid=1000 pid=364422 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="org.bluez.MediaEndpoint1.Error.NotImplemented" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 30 11:20:17 bary dbus-daemon[645]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.2267" (uid=1000 pid=364422 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="org.bluez.Profile1.Error.NotImplemented" requested_reply="0" destination=":1.14" (uid=0 pid=1017 comm="/usr/lib/bluetooth/bluetoothd")
jun 30 11:20:17 bary bluetoothd[1017]: Stopping SDP server
jun 30 11:20:17 bary bluetoothd[1017]: Exit
jun 30 11:20:17 bary bluetoothd[364483]: Bluetooth daemon 5.64
jun 30 11:20:17 bary bluetoothd[364483]: Starting SDP server
jun 30 11:20:17 bary bluetoothd[364483]: Bluetooth management interface 1.18 initialized
jun 30 11:20:17 bary dbus-daemon[645]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.2276' (uid=0 pid=364483 comm="/usr/lib/bluetooth/bluetoothd")
jun 30 11:20:17 bary bluetoothd[364483]: profiles/audio/avctp.c:avctp_server_socket() setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 11:20:17 bary bluetoothd[364483]: src/profile.c:ext_start_servers() L2CAP server failed for Message Notification: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 11:20:17 bary bluetoothd[364483]: src/profile.c:ext_start_servers() L2CAP server failed for Message Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 11:20:17 bary bluetoothd[364483]: src/profile.c:ext_start_servers() L2CAP server failed for Phone Book Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 11:20:17 bary bluetoothd[364483]: src/profile.c:ext_start_servers() L2CAP server failed for File Transfer: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 11:20:17 bary bluetoothd[364483]: src/profile.c:ext_start_servers() L2CAP server failed for Object Push: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
jun 30 11:20:17 bary bluetoothd[364483]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/ldac
jun 30 11:20:17 bary bluetoothd[364483]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 30 11:20:17 bary bluetoothd[364483]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 30 11:20:17 bary bluetoothd[364483]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aac
jun 30 11:20:17 bary bluetoothd[364483]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSink/sbc
jun 30 11:20:17 bary bluetoothd[364483]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/sbc
jun 30 11:20:17 bary bluetoothd[364483]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSink/sbc_xq
jun 30 11:20:17 bary bluetoothd[364483]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/sbc_xq
jun 30 11:20:17 bary bluetoothd[364483]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jun 30 11:20:17 bary bluetoothd[364483]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jun 30 11:20:17 bary bluetoothd[364483]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jun 30 11:20:17 bary bluetoothd[364483]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jun 30 11:20:17 bary bluetoothd[364483]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/faststream
jun 30 11:20:17 bary bluetoothd[364483]: Endpoint registered: sender=:1.2267 path=/MediaEndpoint/A2DPSource/faststream_duplex
jun 30 11:20:58 bary bluetoothd[364483]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Device or resource busy
jun 30 11:21:02 bary bluetoothd[364483]: /org/bluez/hci0/dev_38_18_4C_7C_CB_3D/sep1/fd0: fd(29) ready
I noticed that it found the other codecs.
means that you wont be able to use LDAC codec on any sinks (headphone), if the headphone supports aptX* codecs they should work though
