Hi! I’m currently using pipewire (version 0.3.40). I change from pulseaudio a month ago and I really never used the jack port on my laptop but it seems that pipewire is not detecting the device at all. I have done some research without any luck.
I’ve seen that in some similar topics some people ask to run this command pactl list sinks that outputs this:
Summary
Sink #44
State: SUSPENDED
Description: SteelSeries Arctis 7 Chat
Driver: PipeWire
Sample Specification: s16le 1ch 48000Hz
Channel Map: mono
Owner Module: 4294967295
Mute: no
Volume: mono: 68501 / 105% / 1.15 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.usb-SteelSeries_SteelSeries_Arctis_7-00.mono-chat.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
object.path = "alsa:pcm:1:hw:1,0,0:playback"
api.alsa.path = "hw:1,0,0"
api.alsa.pcm.card = "1"
api.alsa.pcm.stream = "playback"
audio.channels = "1"
audio.position = "MONO"
device.routes = "1"
device.intended_roles = "phone"
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "USB Audio"
alsa.id = "USB Audio"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "1"
alsa.card_name = "SteelSeries Arctis 7"
alsa.long_card_name = "SteelSeries SteelSeries Arctis 7 at usb-0000:00:14.0-3.2, full speed"
alsa.driver_name = "snd_usb_audio"
device.profile.name = "mono-chat"
device.profile.description = "Chat"
card.profile.device = "0"
device.id = "43"
factory.name = "api.alsa.pcm.sink"
priority.driver = "936"
priority.session = "936"
media.class = "Audio/Sink"
node.nick = "SteelSeries Arctis 7"
node.name = "alsa_output.usb-SteelSeries_SteelSeries_Arctis_7-00.mono-chat"
device.description = "SteelSeries Arctis 7 Chat"
device.icon_name = "audio-card"
device.bus = "usb"
device.bus_path = "pci-0000:00:14.0-usb-0:3.2:1.0"
node.pause-on-idle = "false"
factory.id = "18"
client.id = "32"
node.driver = "true"
factory.mode = "merge"
audio.adapt.follower = ""
library.name = "audioconvert/libspa-audioconvert"
object.id = "44"
node.max-latency = "131072/48000"
Ports:
usb-gaming-headset-output-mono: Headphones Mono Output (type: Headphones, priority: 0, availability unknown)
Active Port: usb-gaming-headset-output-mono
Formats:
pcm
Sink #45
State: SUSPENDED
Description: SteelSeries Arctis 7 Game
Driver: PipeWire
Sample Specification: s16le 2ch 48000Hz
Channel Map: front-left,front-right
Mute: no
Volume: front-left: 48287 / 74% / -7.96 dB, front-right: 48287 / 74% / -7.96 dB
balance 0.00
Monitor Source: alsa_output.usb-SteelSeries_SteelSeries_Arctis_7-00.stereo-game.monitor
Properties:
object.path = "alsa:pcm:1:hw:1,1,0:playback"
api.alsa.path = "hw:1,1,0"
audio.channels = "2"
audio.position = "FL,FR"
device.routes = "1"
device.api = "alsa"
alsa.name = "USB Audio #1"
alsa.device = "1"
alsa.card = "1"
device.profile.name = "stereo-game"
device.profile.description = "Game"
card.profile.device = "1"
device.id = "43"
priority.driver = "920"
priority.session = "920"
node.name = "alsa_output.usb-SteelSeries_SteelSeries_Arctis_7-00.stereo-game"
device.description = "SteelSeries Arctis 7 Game"
device.bus = "usb"
factory.id = "18"
client.id = "32"
object.id = "45"
Ports:
usb-gaming-headset-output-stereo: Headphones (type: Headphones, priority: 0, availability unknown)
Active Port: usb-gaming-headset-output-stereo
Formats:
pcm
Sink #56
State: RUNNING
Description: EasyEffects Sink
Driver: PipeWire
Sample Specification: float32le 2ch 48000Hz
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Monitor Source: easyeffects_sink.monitor
Flags: DECIBEL_VOLUME LATENCY
Properties:
node.name = "easyeffects_sink"
device.description = "EasyEffects Sink"
factory.name = "support.null-audio-sink"
monitor.channel-volumes = "true"
factory.id = "18"
client.id = "55"
object.id = "56"
Formats:
pcm
Sink #98
State: RUNNING
Description: Echo Dot-D85
Driver: PipeWire
Mute: no
Volume: front-left: 78702 / 120% / 4.77 dB, front-right: 78702 / 120% / 4.77 dB
balance 0.00
Monitor Source: bluez_output.EC_0D_E4_FB_F2_FD.a2dp-sink.monitor
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Properties:
api.bluez5.transport = ""
api.bluez5.profile = "a2dp-sink"
api.bluez5.codec = "sbc_xq"
api.bluez5.address = "EC:0D:E4:FB:F2:FD"
device.routes = "1"
device.form_factor = "speaker"
device.bus = "bluetooth"
device.id = "80"
device.description = "Echo Dot-D85"
node.name = "bluez_output.EC_0D_E4_FB_F2_FD.a2dp-sink"
factory.name = "api.bluez5.a2dp.sink"
priority.driver = "1010"
priority.session = "1010"
device.icon_name = "audio-speakers-bluetooth"
factory.id = "8"
device.api = "bluez5"
node.latency = "512/48000"
object.id = "98"
client.id = "31"
Ports:
speaker-output: Speaker (type: Speaker, priority: 0, available)
Active Port: speaker-output
Formats:
pcm
The exact model of my laptop is: OMEN Laptop 15-ek1xxx
I’m really clueless about what can I do to solve this, does anyone know some workaround or happens to be the same problem?
