There are several issues on this forum related crackling sound. However, none related PipeWire. I’m using PipeWire on my system now and unfortunately, crackling sound is an issue. Does anyone have any experience with this?
Is there a tsched=0 that can be added to a load-module command for PipeWire as well?
After trying out miscellaneous things I was about to give up. However, as my speakers are connected using a USB-hub I decided to change the hub as well. After having done that the sound is back to normal again. So, it seems like a bad connection of some sort was the cause of this.
