draz
8 August 2024 20:05
1
After upgrade I got :
:: installing pipewire-alsa (1:1.2.2-1) breaks dependency 'pulseaudio-alsa' required by zoom
Any assistance would be greatly appreciated.
cscs
8 August 2024 20:12
2
Zoom is an AUR package.
It is your responsibility.
But I will mention … zoom does not rely on pulseaudio-alsa.
It is an optional dependency.
So whatever you are doing … is not actually required. Maybe this is an outcome related to the use of pamac ?
draz
8 August 2024 23:45
3
I deleted zoom, in order to proceed the installation, but then I got
gpg: error while loading shared libraries: libassuan.so.0: cannot open shared object file: No such file or directory
After
$find /usr/lib -name 'libassuan.so*' -exec ls -l {} \;
-rwxr-xr-x 1 root root 80048 Jul 17 12:54 /usr/lib/libassuan.so.9.0.0
lrwxrwxrwx 1 root root 18 Jul 17 12:54 /usr/lib/libassuan.so -> libassuan.so.9.0.0
lrwxrwxrwx 1 root root 18 Jul 17 12:54 /usr/lib/libassuan.so.9 -> libassuan.so.9.0.0
To resolve the issue, I created a symbolic link:
sudo ln -s /usr/lib/libassuan.so.9 /usr/lib/libassuan.so.0
The problems continued with
error: GPGME error: Invalid crypto engine
I continued with
$sudo pacman-mirrors -c Global #I reconfigured my mirrors
$sudo rm -r /etc/pacman.d/gnupg/ #delete the keys needed for verification
$sudo pacman-key --init #reinitialize the gpg key ring
$sudo pacman-key --populate #import the default GPG keys
Finally, I updated my system,
$sudo pacman -Syu
and reinstalled zoom.
However, I’m puzzled as to why these issues occurred.
philm
9 August 2024 05:10
4
draz:
This sounds like this bug: gpg: error while loading shared libraries: libassuan.so.0: cannot open shared object file: No such file or directory
