Hi, I have run both the plasma and the phosh versions of the Manjaro pinephone images and have found that I cannot connect my phone over USB using sftp/ssh.
I contacted the developer of the megi kernels and found that the g_cdc module is likely not built/enabled in the configuration for the pinephone kernel.
I have tried to search for a good place to raise this issue, and decided the forum was a good place to start.
I know @philm mentioned this in “[Kernel] PinePhone Megi-config based kernel build” and I was wondering what the progress was in enabling this specific module.
Also, thanks for such a fun mobile computing experience!
