Always changes back to 200% after restart instead of what I set to
I opened an issue on gitlab a few days ago
Can change in phoc.ini file, which needs to be copied from share/phosh to etc/phosh. Video with instructions by RTP (Privacy Tech Tips)
I have the same issue, can you share a link to the video?
Can you share a link to the gitlab issue? I have the same problem.
search for Privacy Tech Tips / RTP should find
