Pinephone dialer
The dialer on my pinephone has a problem with ring tones. After a boot it rings ok. When i have been doing some things, it rings very quietly as if it thinks it’s not on the speaker but a headset. using the volume buttons does display "volume change for internal headset " (along those lines). this makes the phone basically useless since I’d never know i was called.
Any ideas?
Thanks
It’s an issue with audio profile switching and it is being worked on.
It’s because of some combination of picking up a call and making a call and afterwards either ended the call or the other person ending the call, that does not correctly turn the profile back to speakers.
Thanks for the info, appreciate it!
