Has anyone tried antennas other than the one in the PBP already, to get a better signal?
Could placing an antenna behind the display panel, like in most conventional laptops, result in a better signal?
Has anyone gone so far as to drill a hole in the case for a SMA (or similar) connector for use with an external antenna? If so, where did you place the connector?
