Now it boots fine from NVME but if I insert a SD Card which is supposed to take priority over NVME it doesn’t power up and boot until I remove the SD card. I built the SD Card using the Manjaro ARM Flasher utility on the Pinebook Pro running 20.08
Yup, the later one worked and has the added advantage of using the LEDs the same way the factory one did. Amber then Green as opposed to off and then Green.
