Pinebook Pro not detecting Dell U2720Q USB-C external display
I have a new Pinebook Pro running Manjaro 5.7.19-1-MANJARO-ARM #1 SMP Wed Sep 2 20:43:09 +03 2020 aarch64 GNU/Linux. I am unable to get it to detect a Dell UltraSharp 27 4K USB-C Monitor - U2720Q external display plugged in via the included USB-C cable. Charging works, but video out does not.
The user manual says the monitor supports: 1 x USB Type-C (Alternate mode with DisplayPort 1.4, USB 3.0 upstream port, Power Delivery PD up to 90 W).
When I plug the cable into the Pinebook Pro, dmesg shows the following:
[Mon Sep 21 10:39:06 2020] usb 7-1.5: USB disconnect, device number 11
[Mon Sep 21 10:39:06 2020] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[Mon Sep 21 10:39:30 2020] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
[Mon Sep 21 10:39:30 2020] typec_displayport port0-partner.0: No compatible pin configuration found:0000 -> 0014, 001c <- 0000
[Mon Sep 21 10:39:30 2020] usb 7-1: new high-speed USB device number 12 using xhci-hcd
[Mon Sep 21 10:39:30 2020] usb 7-1: New USB device found, idVendor=0451, idProduct=8442, bcdDevice= 1.00
[Mon Sep 21 10:39:30 2020] usb 7-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[Mon Sep 21 10:39:30 2020] usb 7-1: SerialNumber: 52010851800D
[Mon Sep 21 10:39:30 2020] hub 7-1:1.0: USB hub found
[Mon Sep 21 10:39:30 2020] hub 7-1:1.0: 6 ports detected
[Mon Sep 21 10:39:30 2020] usb 8-1: new SuperSpeed Gen 1 USB device number 6 using xhci-hcd
[Mon Sep 21 10:39:30 2020] usb 8-1: New USB device found, idVendor=0451, idProduct=8440, bcdDevice= 1.10
[Mon Sep 21 10:39:30 2020] usb 8-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[Mon Sep 21 10:39:30 2020] hub 8-1:1.0: USB hub found
[Mon Sep 21 10:39:30 2020] hub 8-1:1.0: 4 ports detected
[Mon Sep 21 10:39:31 2020] usb 7-1.5: new high-speed USB device number 13 using xhci-hcd
[Mon Sep 21 10:39:31 2020] usb 7-1.5: New USB device found, idVendor=0451, idProduct=82ff, bcdDevice= 2.00
[Mon Sep 21 10:39:31 2020] usb 7-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[Mon Sep 21 10:39:31 2020] hid-generic 0003:0451:82FF.000A: hiddev97,hidraw2: USB HID v1.11 Device [HID 0451:82ff] on usb-xhci-hcd.1.auto-1.5/input0
I have seen the post about the 5.8 kernel issue with DP-Alt on the Pinebook Pro but this seems to be related to the 5.8 kernel, and I am on 5.7. Any suggestions for how to debug this?
Is the screen not detected at all?
Try turning the USB-C plug upside down.
Nothing seems to be detected. Same thing either way the USB is plugged in.
Got any phone’s that have USB C? So you can plug in the display…
:rofl:
I was about to add an meme but went Na,
The display works fine - I can plug it into a Macbook Air (2018) via USB-C without any issues.
have you try to boot pinebook Pro and switch on Screen Dell with USB-c ?
Some USB-C displays simply don’t work with the Pinebook Pro. There’s a reason there are compatability lists around.
Yeah, rebooting with it connected makes no difference.
Fine, but there must be a reason. What steps do you suggest to try and debug it?
To be honest I dont know.
The hack we had placed in kernel 5.7 was just that. A hack. And it even stopped working, for no apparent reason, in 5.8.
usb 3.x ( stack) has been rebuild in this version linux ( for securities reasons )
I’ve posted this over on the Pine64 forums as several people are also having the same problem.
