Hi there.
After messing up installing python via pip it wasn’t possible to update and upgrade the system anymore.
Suggested solution was to run:
sudo pacman -S manjaro-system
sudo pacman -Syu --overwrite "*"
Problems with:
:: Replace breath2-icon-themes with community/plasma5-themes-breath? [Y/n] y
:: Replace plasma5-themes-breath2 with community/plasma5-themes-breath? [Y/n] y
:: Replace sddm-breath2-theme with community/sddm-breath-theme? [Y/n] y
Then tried:
:: Replace breath2-icon-themes with community/plasma5-themes-breath? [Y/n] n
:: Replace plasma5-themes-breath2 with community/plasma5-themes-breath? [Y/n] n
:: Replace sddm-breath2-theme with community/sddm-breath-theme? [Y/n] n
Done! Successfully updated/upgrated.
…But:
$ systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
● postgresql.service loaded failed failed PostgreSQL database server
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
1 loaded units listed.
$ journalctl -p 3 -b
Oct 20 09:42:31 lxm kernel: rockchip-dp ff970000.edp: no DP phy configured
Oct 20 09:42:32 lxm kernel: brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9
Oct 20 09:42:32 lxm kernel: brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/9 wl0: Feb 11 2020 11:54:51 version 7.45.96.61 (be7af2d@>
Oct 20 09:42:32 lxm systemd-udevd[303]: event7: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Oct 20 09:42:32 lxm systemd-udevd[303]: event7: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Oct 20 09:42:32 lxm systemd-udevd[303]: event7: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Oct 20 09:42:32 lxm systemd-udevd[307]: event8: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Oct 20 09:42:32 lxm systemd-udevd[307]: event8: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Oct 20 09:42:32 lxm systemd-udevd[307]: event8: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Oct 20 09:42:32 lxm systemd-udevd[333]: event4: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Oct 20 09:42:32 lxm systemd-udevd[333]: event4: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Oct 20 09:42:32 lxm systemd-udevd[333]: event4: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Oct 20 09:42:33 lxm systemd-udevd[320]: event6: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Oct 20 09:42:33 lxm systemd-udevd[320]: event6: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Oct 20 09:42:33 lxm systemd-udevd[320]: event6: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Oct 20 09:42:33 lxm systemd-udevd[305]: event5: Failed to call EVIOCSKEYCODE with scan code 0x70066, and key code 142: Invalid argument
Oct 20 09:42:33 lxm systemd-udevd[305]: event5: Failed to call EVIOCSKEYCODE with scan code 0x700a5, and key code 224: Invalid argument
Oct 20 09:42:33 lxm systemd-udevd[305]: event5: Failed to call EVIOCSKEYCODE with scan code 0x700a6, and key code 225: Invalid argument
Oct 20 09:42:34 lxm systemd[1]: Failed to start PostgreSQL database server.
Oct 20 09:43:00 lxm pulseaudio[775]: module-rescue-stream is obsolete and should no longer be loaded. Please remove it from your config>
How to get rid of the above mentioned issues and get the system running smoothly?
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
