Pine phone troubleshooting
I recently got a pine phone, beta edition, the standard pine phone not the pro. This appears to be their most recent revision of the device. I’m have been trying to get it updated, but I’ve had some trouble. Initially, the problem was that the update would have one or two errors as a result of dependencies, and because of those errors the entire update would be canceled. Not just the one or two files. As a result, I could not update anything. When I first started, all commands would work. However, now almost all commands fail to work as a result of “command not found.” The few commands that do seem to work result in
: error while loading shared libraries: libcrypto.so.3: cannot open shared object file: No such file or directory
I looked up this problem and some people said that the right answer is to try idconfig or else to try and find the path. idconfig results in “command not found.”
It should already be installed, but when I try to install idconfig it goves me the Libcrypto.so.3 error. It seems to be a catch 22.
I also thought that I might need to update the Colonel cause I’m not sure if I have the most recent one. But it seemed that the MHWD command was not installed or else it also needs the directory to be sorted out. I tried to use PAMAC, but that also seemed to not be installed. When I tried to install PAM AC, it seemed like it could not be installed as result of some library or dependency issue. I’m new to Manjaro and I’m not extremely skilled in Linix. I’m stumped. I’m looking for someone to hopefully provide strings of code which I need to copy and paste into terminal so I can start fixing everything. Thank you.
I am not familiar with Manjaro. I’m using it because it’s preinstalled on the pine phone.
I’m wishing for someone to hopefully provide the string or commands that I need to put into terminal to make all my commands work again and not come up with “command not found.” Most of the answers to these questions on the web are incomprehensible to me. I wouldn’t know where to begin even to try and find the path. I’m looking for someone who just knows exactly what I can copy and paste to put in to my phone to fix this. For both the “command, not found“ problem as well as the lib.crypto problem. The problems seem to be about libraries, sources Of information, and directories. I don’t know how to fix this, and I don’t even know how to begin to fix it.
Would one of you be able to help provide me the commands to put into my terminal to start fixing things?
I think tow boot is already installed on this model straight from the factory. Pretty soon I need to get a SD card in order to flash a good recent image of Manjaro ARM Plasma and then the problem should be resolved. But I would like first of all to try and fix the problems in the operating system that is already in the device right now.
Manjaro has no military structure.
What I mean to say is – the word is kernel and not “Colonel” :smile_cat:
I have no experience with PinePhones, however, I’m sure someone will assist as soon as they are able.
In the meantime, please provide system information (when possible) according to the instructions given (below).
This will greatly assist those who might wish to help.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
Required reading
Resources - [Manjaro Wiki](https://wiki.manjaro.org/index.php) - [Tutorials](https://forum.manjaro.org/c/contributions/tutorials/40)
Considering that:
  • Manjaro ARM stable has not been updated for several months now,
  • Manjaro ARM unstable is getting updated, but has changed so much from the last stable push and from the factory image that you got with your PinePhone that upgrading to it without errors is hard,
  • even upgrading from the factory image to the current stable branch seems to fail (or is it trying to upgrade to the unstable branch?), though that would not be of all that much use because the stable branch is also severely outdated,
  • you are not familiar with Manjaro,
  • you have just received your PinePhone, so hopefully do not yet have anything important on that Manjaro installation,
I think you are better off trying another distribution, unfortunately. (The most popular ones are postmarketOS and Mobian.)
That (above by Kevin_Kofler) is really bad news! My (regular) PinePhone arrived on Monday of this week. I would like to use it and update it. It seems to work pretty well. I’m happy with it, but I would like to update it.
I’m a Slackware user. When I get some time I’ll try putting Slackware on an SD card for my PinePhone. In the meantime, I will try to hold on and maybe someone can help me? My updates are failing. The error messages say something about Ray Sherwin and “unable to lock database”.
By the way, I really like the PinePhone.
-Joe
P.S. Just now I found the “left behind” script (search on “left behind” then select, "left behind in Tutorials). I have some experience writing and using scripts, so perhaps this would be a good way for me to “crack this nut”? Any comments?
And does anyone think that it is odd, that I’m looking at a “left behind” script when I just got my phone four days ago?
The download images are so old from the Download Page built off the stable branch that my keys had expired. Try moving to the unstable branch and upgrading there. There will be some issues as some programs are not there any more and have been replaced by others and updating keys. You will have to take your time working through the issues but doable.
The unstable branch is the only branch being maintained at the moment. You can also try to build an image off the unstable branch.
Thanks, @Darksky! I wasn’t sure at first, but you seem to be replying to my post, yes? Anyway, your post does talk somewhat about my needs.
Mostly I would like to update the OS that came with my PinePhone. Is that a reasonable thing to do? Or would I be better off trying to download an unstable Manjaro version to an SD card, and later learn to put it on eMMC. Perhaps such a version would be easier to update?
Or perhaps I’m overreacting? I don’t expect much from my cell phone. I’m a simple-minded cellphone user. I could just shrug it off. What’s the harm of using an out of date operating system? Security issues maybe? Maybe missing out on fixes that come along?
-Joe
P.S. I got some help just now from duck.ai “translating” your post. I’m so new to this that I needed help understanding some of the principles, especially the ideas of switching branches and building an image. I understand much better now. Perhaps I will switch to the unstable branch–good idea!
You can try an unstable image. I do not have a pinephone so do not know if it will boot ok or not.
Alpine Linux based https://postmarketos.org is a great replacement for Manjaro on a PinePhone.
Another option is GitHub - dreemurrs-embedded/Pine64-Arch: 🐧 Arch Linux ARM for your PinePhone/Pro and PineTab/2
A third option is to use GitHub - DanctNIX/danctnix: The community that is dedicated to mobile Linux.
