Pine Phone Manjaro with Phosh won't start after update
I ran updates yesterday and now the phone won’t start: there’s an error screen with:
Ooops! something went wrong.
I have the system installed on the eMMc. When I chroot into it and run updates:
pacman -Syyu
there’s nothing major being pulled and system still won’t start.
Looking at the journalctl -b -1 logs there’s this line repeated over and over:
gnome-software (...) gdk_monitor_get_scale_factor: assertion 'GDK_IS_MONITOR (monitor)' failed
If I recall correctly the last update had something to do with libhandy1 and/or pinephone-manjaro-tweaks.
I could do with some advice on how to fix this
[edit]
looks like not chrooting and instead running:
packman -Ss --sysroot /dev/mmcblahblah and packman -Su --sysroot /dev/mmcblahblah
fixed it? System starts now… (but how?)
I’ve edited your post a bit for readability and re-classified it under the #arm topic so the right people can have a look at this.
:+1:
I think you’d just want:
pacman -Syyu
to replace the above commands.
Done. I was wondering why myself, but left it in for OP to verify…
