I’m wondering if any of you gurus here can help make me a little smarter.
What would be the best way to install Phoronix-test-suite, keep-in-mind that I want to remove it after I’m done testing. Running the benchmarking tests is something I would do only once or twice and not need it again. Phoronix-test-suite with its dependencies can take up quite a bit of space on your drive.
- Download installer scripts from " Phoronix Test Suite - Download "
and run the install script with commandsh ./install-sh
or
- Use add/remove software and install the Phoronix-test-suite from the AUR?
if using the 2nd method and you remove that package using add/remove software, will it also remove the tests as well or just the Phoronix-test-suite package?
Or would I still need to use the "locate or find" command and delete all the directories/dependencies that have Phoronix in them?
