PGP signature for mit-scheme package
I have this problem with the mit-scheme package on the AUR.
When i run pamac build mit-scheme I get this:
==> Verifying source file signatures with gpg... mit-scheme-11.2-x86-64.tar.gz ... FAILED (invalid public key 8F664EF430167B808170D35AC9E40BAAFD0CB132) ==> ERROR: One or more PGP signatures could not be verified! Error: Failed to build mit-scheme
I already tried doing gpg --recv-key 8F664EF430167B808170D35AC9E40BAAFD0CB132 and I get this result
gpg: key C9E40BAAFD0CB132: "Chris Hanson <cph@chris-hanson.org>" not changed gpg: Total number processed: 1 gpg: unchanged: 1
Anyway it doesn’t change the problem with pamac.
Anybody can point me to the right path please?
Thanks for your time!
When encountering issues with AUR packages, always check the latest comments on the package’s AUR page. :wink:
I actually tried it, but it didn’t change the result:
[sicro@sicro ~]$ gpg --keyserver hkps://keys.openpgp.org/ --recv-keys 8F664EF430167B808170D35AC9E40BAAFD0CB132
gpg:              unchanged: 1
[sicro@sicro ~]$ pamac build mit-scheme
Preparing...
Cloning mit-scheme build files...
Checking mit-scheme dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (1):
  mit-scheme  11.2-2    AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Building mit-scheme...
==> Making package: mit-scheme 11.2-2 (Sun 01 Aug 2021 10:22:24 PM -03)
==> Retrieving sources...
  -> Found mit-scheme-11.2-x86-64.tar.gz
  -> Found mit-scheme-11.2-x86-64.tar.gz.sig
    mit-scheme-11.2-x86-64.tar.gz ... Passed
    mit-scheme-11.2-x86-64.tar.gz.sig ... Skipped
What’s the contents of your gpg.conf?
cat ~/.gnupg/gpg.conf
You might have an old server in there. I recommend adding the following server:
keyserver hkps://keyserver.ubuntu.com
I actually can’t find that file:
[sicro@sicro ~]$ ls ~/.gnupg/
crls.d  private-keys-v1.d  pubring.kbx  pubring.kbx~  trustdb.gpg
Is it normal?
Yes, it’s not created by default.
I just created the file and added that keyserver you suggested, but the result it’s still negative with pamac
It works for me after manually importing the key, not sure what else to try.
❯ pamac build mit-scheme
Preparing...
To build (1):
==> Making package: mit-scheme 11.2-2 (Mon 02 Aug 2021 04:00:06 PM MDT)
  -> Downloading mit-scheme-11.2-x86-64.tar.gz...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 76.5M  100 76.5M    0     0  6514k      0  0:00:12  0:00:12 --:--:-- 6880k
  -> Downloading mit-scheme-11.2-x86-64.tar.gz.sig...
100   566  100   566    0     0   2247      0 --:--:-- --:--:-- --:--:--  2246
    mit-scheme-11.2-x86-64.tar.gz ... FAILED (unknown public key C9E40BAAFD0CB132)
❯ gpg --recv-keys C9E40BAAFD0CB132
gpg: key C9E40BAAFD0CB132: public key "Chris Hanson <cph@chris-hanson.org>" imported
gpg:               imported: 1
Preparing...
To build (1):
Could it be a keyring issue? Maybe I should reinstall manjaro-keyring or arch-keyring
Your personal keyring is not related to the system keyring.
Since then, have you done:
gpg --recv-keys 8F664EF430167B808170D35AC9E40BAAFD0CB132
Yes, I tried it a couple of times, with no luck. The stange thing is that a month ago I was able to install the package
