error: linux515: signature from "Manjaro Build Server <build@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/linux515-5.15.75-1-x86_64.pkg.tar.zst is corrupte
d (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] n
error: linux515-nvidia: signature from "Manjaro Build Server <build@manjaro.org
" is unknown trust
:: File /var/cache/pacman/pkg/linux515-nvidia-520.56.06-5-x86_64.pkg.tar.zst is
corrupted (invalid or corrupted package (PGP signature)).
After scouring the forums for solutions and trying a bunch, nothing working I attempted the wiki fix which seemed promising, but I just ended up getting the same errors regarding these 2 packages:
It’s worth noting that I am on the testing branch of Manjaro.
All I want to know if this is an issue on my side or not. I haven’t fiddled with the mirrors before except for changing to the testing branch as per the wiki.
I don’t know. Anyway, rerun your update, but first maybe make sure mirrors are all updated sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
then if it asks to delete any invalid or corrupted package (PGP signature) - select Y (yes).
Sadly I get the same error after doing this, as stated above I tried many solutions for the errors, tried the Wiki solution which seemed most promising.
I guess I’ll have to wait and see a bit later if something comes of it.
error: linux419: signature from "Manjaro Build Server <build@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/linux419-4.19.261-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: linux419-r8168: signature from "Manjaro Build Server <build@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/linux419-r8168-8.050.03-10-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
I just updated and there is an update for manjaro-keyring, perhaps that fixes your issue? Although I’m on unstable branch it’s available for all branches now. Packages
