PGP error in upgrade "invalid or corrupted package (PGP signature)"
Hi all,
I’m trying to upgrade a VM after a log time and I got this error
[mirto@manjaro ~]$ LANG=C sudo pacman -Syu
[sudo] password for mirto:
 core is up to date
 extra is up to date
 multilib is up to date
:: Replace linux617 with core/linux-meta? [Y/n]
:: Replace vi with extra/ex-vi-compat? [Y/n]
resolving dependencies...
warning: dependency cycle detected:
warning: python-soupsieve will be installed before its python-beautifulsoup4 dependency
warning: xdg-desktop-portal-kde will be installed before its plasma-workspace dependency
warning: mhwd-nvidia will be installed before its mhwd-db dependency
warning: python-poetry-plugin-export will be installed before its python-poetry dependency
Packages (824) alsa-card-profiles-1:1.4.10-1  alsa-lib-1.2.15.3-2  alsa-ucm-conf-1.2.15.3-1  alsa-utils-1.2.15.2-1  amd-ucode-20260110-1  aom-3.13.1-2  apache-orc-2.2.2-1  appstream-1.1.2-1  appstream-glib-0.8.3-3
               appstream-qt-1.1.2-1  archlinux-appstream-data-20260107-1  archlinux-keyring-20260107-2.0  ark-25.12.1-1  arrow-23.0.0-1  at-spi2-core-2.58.3-1  attica-6.22.0-1  audiocd-kio-25.12.1-1  audit-4.1.2-2
               aurorae-6.5.5-1  autoconf-archive-1:2024.10.16-4  avahi-1:0.9rc3-1  aws-c-auth-0.9.5-1  aws-c-compression-0.3.2-1  aws-c-event-stream-0.5.9-1  aws-c-http-0.10.9-1  aws-c-io-0.25.0-1  aws-c-s3-0.11.4-1
               aws-checksums-0.2.8-1  aws-crt-cpp-0.37.0-1  aws-sdk-cpp-core-1.11.725-1  aws-sdk-cpp-iam-1.11.725-1  aws-sdk-cpp-s3-1.11.725-1  baloo-6.22.0-1  baloo-widgets-25.12.1-1  bash-5.3.9-1
               binutils-2.45.1+r35+g12d0a1dbc1b9-1  bluedevil-1:6.5.5-1  blueprint-compiler-0.18.0-2  bluez-qt-6.22.0-1  boost-libs-1.89.0-4  breeze-6.5.5-1  breeze-gtk-6.5.5-1  breeze-icons-6.22.0-1
               breeze5-6.5.5-1  brotli-1.2.0-1  btop-1.4.6-1  btrfs-progs-6.17.1-2  ca-certificates-mozilla-3.120-1  cantarell-fonts-1:0.311-1  capstone-5.0.6-2  chromium-144.0.7559.132-1  clang-21.1.6-3
              vulkan-mesa-implicit-layers-1:25.3.4-1  vulkan-radeon-1:25.3.4-1  vulkan-tools-1.4.335.0-1  wavpack-5.9.0-1  webkit2gtk-2.50.4-1  webkit2gtk-4.1-2.50.4-1  webkitgtk-6.0-2.50.4-1  weston-14.0.2-3
               wireplumber-0.5.13-1  wpa_supplicant-2:2.11-5  xapp-3.2.2-1  xapp-symbolic-icons-1.0.9-0.1  xcb-proto-1.17.0-4  xdg-desktop-portal-kde-6.5.5-1  xfsprogs-6.18.0-1  xorg-xauth-1.1.5-1
               xorg-xkill-1.0.7-1  xorgproto-2025.1-1  xterm-406-1  xz-5.8.2-1  yakuake-25.12.1-1  yt-dlp-2026.01.29-1  yt-dlp-ejs-0.4.0-1  zbar-0.23.93-5
Total Download Size:      0,22 MiB
Total Installed Size:  8963,57 MiB
Net Upgrade Size:        62,07 MiB
:: Retrieving packages...
 libvpl-2.16.0-1-x86_64        227,5 KiB  5,42 MiB/s 00:00 [###############################################################################] 100%
(822/822) checking keys in keyring        [###############################################################################] 100%
(822/822) checking package integrity        [###############################################################################] 100%
error: libvpl: signature from "Daniel Bermond <dbermond@archlinux.org>" is marginal trust
:: File /var/cache/pacman/pkg/libvpl-2.16.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n]
error: failed to commit transaction (invalid or corrupted package)
[mirto@manjaro ~]$
I tried what suggested in another post:
[mirto@manjaro ~]$ LANG=C sudo pacman-key --recv-keys dbermond@archlinux.org
gpg: key 019A7474297D8577: "Daniel Bermond <danielbermond@gmail.com>" not changed
gpg: key E85B8683EB48BC95: "Daniel Bermond <dbermond@archlinux.org>" not changed
gpg: Total number processed: 4
gpg:              unchanged: 4
pub   rsa2048 2016-06-27 [SC]
      3FFA6AB7B69AAE6CCA263DDE019A7474297D8577
uid           [  full  ] Daniel Bermond <danielbermond@gmail.com>
uid           [  full  ] Daniel Bermond <dbermond@archlinux.org>
sub   rsa2048 2016-06-27 [E]
[mirto@manjaro ~]$ LANG=C sudo pacman-key --lsign-key dbermond@archlinux.org
  -> Locally signed 1 key.
==> Updating trust database...
gpg: next trustdb check due at 2026-03-13
[mirto@manjaro ~]$
I also tried
[mirto@manjaro ~]$ LANG=C sudo pacman -S manjaro-keyring
warning: manjaro-keyring-20251003-1 is up to date -- reinstalling
Packages (1) manjaro-keyring-20251003-1
Total Installed Size:  0,09 MiB
Net Upgrade Size:      0,00 MiB
(1/1) checking keys in keyring        [###############################################################################] 100%
(1/1) checking package integrity        [###############################################################################] 100%
(1/1) loading package files        [###############################################################################] 100%
(1/1) checking for file conflicts        [###############################################################################] 100%
(1/1) checking available disk space        [###############################################################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/1) reinstalling manjaro-keyring        [###############################################################################] 100%
==> Appending keys from manjaro.gpg...
==> Locally signing trusted keys in keyring...
  -> Locally signed 2 keys.
==> Importing owner trust values...
(1/1) Arming ConditionNeedsUpdate...
[mirto@manjaro ~]$ LANG=C sudo pacman-key --populate manjaro
[mirto@manjaro ~]$
Still I receive the same error.
What else can I try?
Updating the Manjaro keyring isn’t really going to do much good when the signature at fault is that of an Arch packager. :wink:
Try updating archlinux-keyring instead. You will need -Suu, because the keyring needs to be downgraded.
Maybe I misunderstood your instructions.
I tried
[mirto@manjaro ~]$ LANG=C sudo pacman -S archlinux-keyring
Packages (1) archlinux-keyring-20260107-2.0
Total Installed Size:  1,70 MiB
Net Upgrade Size:      0,01 MiB
(1/1) upgrading archlinux-keyring        [###############################################################################] 100%
==> Appending keys from archlinux.gpg...
(1/3) Reloading system manager configuration...
(2/3) Restarting marked services...
(3/3) Arming ConditionNeedsUpdate...
[mirto@manjaro ~]$ LANG=C sudo pacman-key --populate  archlinux
[mirto@manjaro ~]$
Then I upgraded with
[mirto@manjaro ~]$ LANG=C sudo pacman -Suu
Packages (823) alsa-card-profiles-1:1.4.10-1  alsa-lib-1.2.15.3-2  alsa-ucm-conf-1.2.15.3-1  alsa-utils-1.2.15.2-1  amd-ucode-20260110-1  aom-3.13.1-2  apache-orc-2.2.2-1  appstream-1.1.2-1  appstream-glib-0.8.3-3
               appstream-qt-1.1.2-1  archlinux-appstream-data-20260107-1  ark-25.12.1-1  arrow-23.0.0-1  at-spi2-core-2.58.3-1  attica-6.22.0-1  audiocd-kio-25.12.1-1  audit-4.1.2-2  aurorae-6.5.5-1
               v4l2loopback-dkms-0.15.3-1  vapoursynth-73-2  vi-1:070224-6 [removal]  vim-9.1.2077-1  vim-runtime-9.1.2077-1  virt-install-5.1.0-3  virt-manager-5.1.0-3  virtualbox-guest-utils-7.2.6-1
               vivaldi-7.8.3925.66-1  vivaldi-ffmpeg-codecs-144.0.7559.175-1  volume_key-0.3.12-12  vte-common-0.82.3-1  vte3-0.82.3-1  vulkan-headers-1:1.4.335.0-2  vulkan-icd-loader-1.4.335.0-1
Total Installed Size:  8961,87 MiB
Net Upgrade Size:        62,06 MiB
 libvpl-2.16.0-1-x86_64        227,5 KiB  2,29 MiB/s 00:00 [###############################################################################] 100%
(821/821) checking keys in keyring        [###############################################################################] 100%
(821/821) checking package integrity        [###############################################################################] 100%
[mirto@manjaro ~]$
I got the same error
What I’m doing wrong?
This. :backhand_index_pointing_down:
Try… :backhand_index_pointing_down:
sudo pacman -Sy && sudo pacman -S archlinux-keyring
Tried. No luck
[mirto@manjaro ~]$ LANG=C sudo pacman -Suu archlinux-keyring
warning: archlinux-keyring-20260107-2.0 is up to date -- reinstalling
               xorg-xkill-1.0.7-1  xorgproto-2025.1-1  xterm-406-1  xz-5.8.2-1  yakuake-25.12.1-1  yt-dlp-2026.01.29-1  yt-dlp-ejs-0.4.0-1  zbar-0.23.93-5  archlinux-keyring-20260107-2.0
 libvpl-2.16.0-1-x86_64        227,5 KiB  1711 KiB/s 00:00 [###############################################################################] 100%
[mirto@manjaro ~]$
Is a reboot needed?
He already installed the right keyring (from January).
Maybe cleaning the cach is due, so that the packages are redownloaded?
I’ll try and report here
No, the issue with the keyrings only occurred a few days ago, and @Yochanan downgraded archlinux-keyring in the repos.
No, that’s not necessary.
Worst case scenario, I would try this… :backhand_index_pointing_down:
Or look here - looks very similar and was resolved:
Marginal Trust invalid or corrupt package Error while updating manjaro - #13 by Char
