Hoped it fix it self if I wait some time, but it didn’t. Since more than a month, I can’t upgrade kirigami-addons but got an error in discover:
I know how I could disable this “no metadata” message, it’s if you go to settings and disable vendor-directories:
But I’m not sure if this prevent other packages from upgrading too.
So how can I solve this issue in a solid way without take the risk that other important components will not be updated?
First of all you should know we do not support third party repositories like archlinuxcn
There is nowhere in our main repositories, nor on arch linux the kirigami-addons
1.0.1-1 version, all have the 0.8.0-1 version
https://archlinux.org/packages/?sort=&repo=Extra&q=kirigami&maintainer=&flagged=
https://packages.manjaro.org/?query=kirigami-addons
On manjaro Kde-Unstable
repo there is kirigami-addons
1:0.8.0.R… depending of the branch, so is quite unclear how you ended up like this. I suggest to get back to our default pacman.conf. Refresh the mirrors and update from terminal.
sudo pacman-mirrors -f5 && sudo pacman -Syyu
Having similar problem. This package only shows up in KDE Discover. It doesn’t show up in PamacGUI or pacman.
This problem exists at least 6 months now. No errors or anything, just not updating
I did tried to run sudo pacman-mirrors -f5 && sudo pacman -Syyu
$ sudo pacman-mirrors -f5 && sudo pacman -Syyu INT ✘
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
REDACTED REDACTED : https://repo.REDACTED/manjaro/
::INFO Writing mirror list
::REDACTED : https://repo.REDACTED/manjaro/testing/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
core 145.8 KiB 286 KiB/s 00:01 [##################################################################################################################################################################] 100%
extra 8.6 MiB 14.3 MiB/s 00:01 [##################################################################################################################################################################] 100%
community 29.0 B 483 B/s 00:00 [##################################################################################################################################################################] 100%
multilib 144.5 KiB 2.24 MiB/s 00:00 [##################################################################################################################################################################] 100%
there is nothing to do
[2023-07-03T22:24:16+0300] [ALPM-SCRIPTLET] Using system disk as snapshot device for creating snapshots in BTRFS mode
[2023-07-03T22:24:16+0300] [ALPM-SCRIPTLET] Mounted '/dev/dm-0 (nvme0n1p2)' at '/run/timeshift/601610/backup'
[2023-07-03T22:24:16+0300] [ALPM-SCRIPTLET] btrfs: Quotas are not enabled
[2023-07-03T22:24:16+0300] [ALPM-SCRIPTLET] Creating new backup...(BTRFS)
[2023-07-03T22:24:16+0300] [ALPM-SCRIPTLET] Saving to device: /dev/dm-0, mounted at path: /run/timeshift/601610/backup
[2023-07-03T22:24:16+0300] [ALPM-SCRIPTLET] Created directory: /run/timeshift/601610/backup/timeshift-btrfs/snapshots/2023-07-03_22-24-16
[2023-07-03T22:24:16+0300] [ALPM-SCRIPTLET] Created subvolume snapshot: /run/timeshift/601610/backup/timeshift-btrfs/snapshots/2023-07-03_22-24-16/@
[2023-07-03T22:24:16+0300] [ALPM-SCRIPTLET] Created subvolume snapshot: /run/timeshift/601610/backup/timeshift-btrfs/snapshots/2023-07-03_22-24-16/@home
[2023-07-03T22:24:16+0300] [ALPM-SCRIPTLET] Created control file: /run/timeshift/601610/backup/timeshift-btrfs/snapshots/2023-07-03_22-24-16/info.json
[2023-07-03T22:24:16+0300] [ALPM-SCRIPTLET] BTRFS Snapshot saved successfully (0s)
[2023-07-03T22:24:16+0300] [ALPM-SCRIPTLET] Tagged snapshot '2023-07-03_22-24-16': ondemand
[2023-07-03T22:24:16+0300] [ALPM-SCRIPTLET] ------------------------------------------------------------------------------
[2023-07-03T22:24:16+0300] [ALPM-SCRIPTLET] Maximum backups exceeded for backup level 'weekly'
[2023-07-03T22:24:16+0300] [ALPM-SCRIPTLET] Maximum backups exceeded for backup level 'monthly'
[2023-07-03T22:24:17+0300] [ALPM-SCRIPTLET] Mounted '/dev/dm-0 (nvme0n1p2)' at '/run/timeshift/601752/backup'
[2023-07-03T22:24:17+0300] [ALPM-SCRIPTLET] btrfs: Quotas are not enabled
[2023-07-03T22:24:17+0300] [ALPM-SCRIPTLET] ------------------------------------------------------------------------------
[2023-07-03T22:24:17+0300] [ALPM-SCRIPTLET] Removing snapshot: 2023-07-03_20-23-50
[2023-07-03T22:24:17+0300] [ALPM-SCRIPTLET] Deleting subvolume: @home (Id:14882)
[2023-07-03T22:24:17+0300] [ALPM-SCRIPTLET] Deleted subvolume: @home (Id:14882)
[2023-07-03T22:24:17+0300] [ALPM-SCRIPTLET] Deleting subvolume: @ (Id:14881)
[2023-07-03T22:24:17+0300] [ALPM-SCRIPTLET] Deleted subvolume: @ (Id:14881)
[2023-07-03T22:24:17+0300] [ALPM-SCRIPTLET] Deleted directory: /run/timeshift/601752/backup/timeshift-btrfs/snapshots/2023-07-03_20-23-50
[2023-07-03T22:24:17+0300] [ALPM-SCRIPTLET] Removed snapshot: 2023-07-03_20-23-50
[2023-07-03T22:24:18+0300] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2023-07-03T22:24:18+0300] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2023-07-03T22:24:18+0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.4-x86_64
[2023-07-03T22:24:18+0300] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.4-x86_64.img
[2023-07-03T22:24:18+0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.4-x86_64-fallback.img
[2023-07-03T22:24:18+0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.1-x86_64
[2023-07-03T22:24:18+0300] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.1-x86_64.img
[2023-07-03T22:24:18+0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
[2023-07-03T22:24:18+0300] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2023-07-03T22:24:18+0300] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2023-07-03T22:24:19+0300] [ALPM-SCRIPTLET] Found Manjaro Linux on /dev/mapper/luks-3a22928e-04fb-4262-b6a7-2b8911eac64b
[2023-07-03T22:24:21+0300] [ALPM-SCRIPTLET] Found Alpine Linux v3.15 on /dev/mapper/luks-3a22928e-04fb-4262-b6a7-2b8911eac64b
[2023-07-03T22:24:22+0300] [ALPM-SCRIPTLET] Found Ubuntu 20.04.4 LTS on /dev/mapper/luks-3a22928e-04fb-4262-b6a7-2b8911eac64b
[2023-07-03T22:24:23+0300] [ALPM-SCRIPTLET] Found Debian GNU/Linux 10 (buster) on /dev/mapper/luks-3a22928e-04fb-4262-b6a7-2b8911eac64b
[2023-07-03T22:24:24+0300] [ALPM-SCRIPTLET] Found Debian GNU/Linux 11 (bullseye) on /dev/mapper/luks-3a22928e-04fb-4262-b6a7-2b8911eac64b
[2023-07-03T22:24:25+0300] [ALPM-SCRIPTLET] Found Debian GNU/Linux 11 (bullseye) on /dev/mapper/luks-3a22928e-04fb-4262-b6a7-2b8911eac64b
[2023-07-03T22:24:26+0300] [ALPM-SCRIPTLET] Found Alpine Linux v3.16 on /dev/mapper/luks-3a22928e-04fb-4262-b6a7-2b8911eac64b
[2023-07-03T22:24:27+0300] [ALPM-SCRIPTLET] Found Alpine Linux v3.15 on /dev/mapper/luks-3a22928e-04fb-4262-b6a7-2b8911eac64b
[2023-07-03T22:24:28+0300] [ALPM-SCRIPTLET] Found Debian GNU/Linux 11 (bullseye) on /dev/mapper/luks-3a22928e-04fb-4262-b6a7-2b8911eac64b
[2023-07-03T22:24:29+0300] [ALPM-SCRIPTLET] Found Debian GNU/Linux 11 (bullseye) on /dev/mapper/luks-3a22928e-04fb-4262-b6a7-2b8911eac64b
[2023-07-03T22:24:31+0300] [ALPM-SCRIPTLET] Found Ubuntu 18.04.6 LTS on /dev/mapper/luks-3a22928e-04fb-4262-b6a7-2b8911eac64b
[2023-07-03T22:24:32+0300] [ALPM-SCRIPTLET] Found Ubuntu 20.04.5 LTS on /dev/mapper/luks-3a22928e-04fb-4262-b6a7-2b8911eac64b
[2023-07-03T22:24:33+0300] [ALPM-SCRIPTLET] Found Debian GNU/Linux 11 (bullseye) on /dev/mapper/luks-3a22928e-04fb-4262-b6a7-2b8911eac64b
[2023-07-03T22:24:34+0300] [ALPM-SCRIPTLET] Found Ubuntu 18.04.6 LTS on /dev/mapper/luks-3a22928e-04fb-4262-b6a7-2b8911eac64b
[2023-07-03T22:24:35+0300] [ALPM-SCRIPTLET] Found Debian GNU/Linux 10 (buster) on /dev/mapper/luks-3a22928e-04fb-4262-b6a7-2b8911eac64b
[2023-07-03T22:24:36+0300] [ALPM-SCRIPTLET] Found Debian GNU/Linux 11 (bullseye) on /dev/mapper/luks-3a22928e-04fb-4262-b6a7-2b8911eac64b
[2023-07-03T22:24:37+0300] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2023-07-03T22:24:37+0300] [ALPM-SCRIPTLET] Detecting snapshots ...
[2023-07-03T22:24:37+0300] [ALPM-SCRIPTLET] Found snapshot: 2023-07-03 22:24:16 | timeshift-btrfs/snapshots/2023-07-03_22-24-16/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
[2023-07-03T22:24:37+0300] [ALPM-SCRIPTLET] Found snapshot: 2023-07-03 22:02:03 | timeshift-btrfs/snapshots/2023-07-03_22-02-03/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
[2023-07-03T22:24:37+0300] [ALPM-SCRIPTLET] Found snapshot: 2023-07-03 22:00:38 | timeshift-btrfs/snapshots/2023-07-03_22-00-38/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
[2023-07-03T22:24:37+0300] [ALPM-SCRIPTLET] Found snapshot: 2023-07-03 18:15:04 | timeshift-btrfs/snapshots/2023-07-03_18-15-03/@ | boot | N/A |
[2023-07-03T22:24:37+0300] [ALPM-SCRIPTLET] Found snapshot: 2023-07-03 12:09:28 | timeshift-btrfs/snapshots/2023-07-03_12-09-27/@ | boot | N/A |
[2023-07-03T22:24:37+0300] [ALPM-SCRIPTLET] Found snapshot: 2023-07-03 12:00:03 | timeshift-btrfs/snapshots/2023-07-03_12-00-02/@ | daily weekly monthly | N/A |
[2023-07-03T22:24:37+0300] [ALPM-SCRIPTLET] Found snapshot: 2023-04-14 23:12:15 | timeshift-btrfs/snapshots/2023-04-14_23-12-15/@ | ondemand | N/A |
[2023-07-03T22:24:38+0300] [ALPM-SCRIPTLET] Found 7 snapshot(s)
[2023-07-03T22:24:38+0300] [ALPM-SCRIPTLET] Unmount /tmp/grub-btrfs.Rhu8fwWxBC .. Success
[2023-07-03T22:24:38+0300] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2023-07-03T22:24:38+0300] [ALPM-SCRIPTLET] done
Can’t confirm, but i assume is because i’m on unstable branch
Also
pacman -Qi kirigami-addons
Version : 0.9.0-1
Description : Add-ons for the Kirigami framework
Architecture : x86_64
URL : https://invent.kde.org/libraries/kirigami-addons
Licenses : GPL LGPL
Groups : None
Provides : None
Depends On : kirigami2
Optional Deps : None
Required By : kdeconnect kweather
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 501,74 KiB
Packager : Antonio Rojas <arojas@archlinux.org>
Build Date : Vi 30 iun 2023 19:01:52 +0300
Install Date : Du 02 iul 2023 16:34:19 +0300
Install Reason : Explicitly installed
Install Script : No
Validated By : Signature
Then i can confirm from our webpage search Packages
The thing is, on stable branch was not done yet the merger to extra
from community
Merger of [community] repository in [extras] is not done in this update … right?
and all looks still a bit funky to me … Probably you could sort it out by switching branches and update mirrors first.
vini
18 July 2023 10:52
5
Changing branches doesn’t help.
$ pacman -Qi kirigami-addons ✔
Version : 0.9.0-1
Licenses : GPL LGPL
Groups : None
Provides : None
Required By : kalendar kdeconnect
Optional For : None
Replaces : None
Installed Size : 501.74 KiB
Build Date : Fri Jun 30 19:01:52 2023
Install Date : Sat Jul 8 11:18:20 2023
Install Reason : Installed as a dependency for another package
Install Script : No
$ pacman-mirrors -G
stable
$ pacman-mirrors -G
unstable
It seems I do have the same problem - there’s a kirigami update in Discover which doesn’t work though. The update doesn’t show up in pamac or pacman though. Any idea how to get rid of it (the constant notification about it is a bit annoying…)?
vini
4 August 2023 05:11
7
No, the issue are still active.
cscs
4 August 2023 05:34
8
Using discover (or packagekit any other way) to handle system packages is not supported … while problems are very expected.
See the note/link here:
https://wiki.archlinux.org/title/Pacman/Tips_and_tricks#Graphical
packages.manjaro.org - kirigami-addons shows version 0.10.0-1 available on all 3 branches
software.manjaro.org/package/kirigami-addons and pamac info kirigami-addons
also show version 0.10.0-1
responds with:error: package 'kirigami-addons' was not found
but sudo pacman -S kirigami-addons
can find kirigami-addons-0.10.0-1
So Manjaro users should be able to update using either pacman
or pamac
cscs
5 August 2023 08:52
10
-Qi
only searches iocal (installed) packages…
system
Closed
7 August 2023 22:53
11
