since I do updates on tty and the output in konsole is very fast, I can’t reed the install log completely, sometimes I check the pacman log but sometimes I forget to check…
yesterday scrolling the log of a old update I found:
warning: directory permissions differ on /root
filesystem: 755 package: 750
should I chmod to 750?
Well, mine is:
$ stat /root
File: /root
Size: 4096 Blocks: 8 IO Block: 4096 directory
Device: 259,2 Inode: 3670017 Links: 19
Access: (0750/drwxr-x---) Uid: ( 0/ root) Gid: ( 0/ root)
Access: 2025-03-31 16:08:41.513514589 +0200
Modify: 2025-05-15 16:06:40.732746583 +0200
Change: 2025-05-15 16:06:40.732746583 +0200
Birth: 2024-10-14 14:13:45.923929445 +0200
So I think that’d be a good idea.
(In any case, it just removes all permissions for some users, so it makes it more secure.z)
Mirdarthos:
Well, mine is:
[tracy@daphne /]$ stat /root
File: /root
Device: 8,2 Inode: 3407873 Links: 8
Access: (0755/drwxr-xr-x) Uid: ( 0/ root) Gid: ( 0/ root)
Access: 2024-08-21 11:19:07.000000000 +1000
Modify: 2025-05-16 10:14:01.001077102 +1000
Change: 2025-05-16 10:14:01.001077102 +1000
Birth: 2024-09-10 20:08:04.722676071 +1000
To either 750
or — better still — to 700
. No one other than the root account should have access to that directory.
mine is like this now
LC_ALL=C stat /root
File: /root
Device: 259,2 Inode: 21757953 Links: 7
Access: 2024-10-12 00:11:07.066647898 +0200
Modify: 2024-11-14 23:05:15.353215527 +0100
Change: 2025-05-16 17:50:58.356197583 +0200
Birth: 2024-07-31 15:11:49.642240905 +0200
with 700 is like this
LC_ALL=C stat /root
File: /root
Access: (0700/drwx------) Uid: ( 0/ root) Gid: ( 0/ root)
Change: 2025-05-16 17:57:50.752737608 +0200
I will stay with 700 for now and see…
system
Closed
19 May 2025 17:50
9
