hi,
At the top of my screen it says 1 update available perl-spreadsheet.xlsx 0.17-1 to 0.18-1
If I try to install via pacman or the package manager both do not recognize this as an installable package.
any ideas?
Thanks.
Do you mean this AUR package?
https://aur.archlinux.org/packages/perl-spreadsheet-xlsx
If that’s what you mean, pacman
can not update it, since it’s in the AUR. You have to use Pamac
or any other AUR helper to update it to the latest version.
Yes it was -xlsx. So used to seeing this as a windows file name.
Pamac installed it. Thanks for the info.
