Hello! I’ve been having problems connecting to my 5G network ever since I got my new PC. Formerly I used an TPLink Archer T9UH, but I changed it for an ANDDEAR - MT761003, since it has native kernel support according to this. However, I’m still getting disconnects and “this device has limited connectivity” warnings when using my 5G network. I’ve tried deleting the network through
sudo nmcli connection add type wifi ifname wlp4s0 con-name wifi-auto ssid "Network_5G"
sudo nmcli connection modify wifi-auto wifi-sec.key-mgmt wpa-psk
sudo nmcli connection modify wifi-auto wifi-sec.psk "password"
sudo systemctl restart NetworkManager
And still no avail. I’ve checked via journalctl -fe and every time I get the warning I get the following output:
journalctl -fe when warning
jun 07 23:52:33 gabriel-gaming NetworkManager[43580]: <info> [1749354753.6624] manager: NetworkManager state is now CONNECTED_SITE
jun 07 23:52:33 gabriel-gaming NetworkManager[43580]: <info> [1749354753.6628] manager: NetworkManager state is now CONNECTED_LOCAL
jun 07 23:52:33 gabriel-gaming NetworkManager[43580]: <info> [1749354753.6629] manager: NetworkManager state is now CONNECTED_SITE
jun 07 23:52:33 gabriel-gaming NetworkManager[43580]: <info> [1749354753.6629] policy: set 'Meme_5G' (wlan1) as default for IPv4 routing and DNS
jun 07 23:52:33 gabriel-gaming systemd[1]: Starting Network Manager Script Dispatcher Service...
jun 07 23:52:33 gabriel-gaming systemd[1]: Started Network Manager Script Dispatcher Service.
jun 07 23:52:43 gabriel-gaming plasmashell[894]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
jun 07 23:52:43 gabriel-gaming systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
jun 07 23:52:49 gabriel-gaming wpa_supplicant[50307]: wlan1: CTRL-EVENT-BEACON-LOSS
jun 07 23:53:10 gabriel-gaming NetworkManager[43580]: <info> [1749354790.2272] manager: NetworkManager state is now CONNECTED_GLOBAL
jun 07 23:53:10 gabriel-gaming NetworkManager[43580]: <info> [1749354790.2277] policy: set 'Meme' (wlan0) as default for IPv4 routing and DNS
jun 07 23:53:10 gabriel-gaming systemd[1]: Starting Network Manager Script Dispatcher Service...
jun 07 23:53:10 gabriel-gaming systemd[1]: Started Network Manager Script Dispatcher Service.
jun 07 23:53:20 gabriel-gaming systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
jun 07 23:53:38 gabriel-gaming wpa_supplicant[50307]: wlan1: CTRL-EVENT-BEACON-LOSS
jun 07 23:53:46 gabriel-gaming wpa_supplicant[50307]: wlan1: CTRL-EVENT-BEACON-LOSS
Those “CRTL-EVENT-BEACON-LOSS” apparently have something to do with distance optimization as stated here, though I’m not sure how to implement the fix (and I’m not sure that’s the problem I have anyways, since this is a desktop). I’m at a bit of a loss on what to look for or do next, so I’m recurring to you.
inxi -bnNz
Kernel: 6.12.28-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.3.5 Distro: Manjaro Linux
Mobo: ASUSTeK model: PRIME A520M-K v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3607
date: 03/22/2024
Info: 6-core AMD Ryzen 5 5500 [MT MCP] speed (MHz): avg: 2994
min/max: 400/4267
Device-1: NVIDIA GA107 [GeForce RTX 3050 6GB] driver: nvidia v: 570.144
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6 driver: X:
loaded: nvidia gpu: nvidia,nvidia-nvswitch resolution: 1920x1080~60Hz
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.144
renderer: NVIDIA GeForce RTX 3050/PCIe/SSE2
driver: r8169
IF: enp4s0 state: down mac: <filter>
Device-2: Realtek RTL8192EE PCIe Wireless Network Adapter
driver: rtl8192ee
Device-3: MediaTek WiFi driver: mt76x0u type: USB
IF: wlan1 state: up mac: <filter>
Local Storage: total: 2.38 TiB used: 1.52 TiB (63.7%)
Memory: total: 16 GiB note: est. available: 15.41 GiB used: 7.34 GiB (47.6%)
Processes: 377 Uptime: 12h 43m Shell: Zsh inxi: 3.3.38
Maybe the PCIe card is running interference with the Anddear dongle? I was thinking on just buying a small router and just plugging it into my PC via ethernet cable as a sort of antenna, but I’d rather exhaust other options before I do that.
