Performance Issues and 'Failed to grab modeset ownership' Error with NVIDIA Driver
Hello everyone,
I am experiencing significant performance issues on my Manjaro system, especially when opening, moving, minimizing, and closing windows. Additionally, I am seeing the following error in the logs:
Log Output (journalctl -p 3 -xb)
jun 14 19:00:42 4k (udev-worker)[462]: event13: Failed to call EVIOCSKEYCODE with scan code 0x7c, and key code 190: Invalid argument
jun 14 19:00:43 4k kernel:
jun 14 19:00:58 4k kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
jun 14 19:00:58 4k org_kde_powerdevil[1817]: busno=5, sleep-multiplier =  1,30. Testing for supported feature 0x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO]
Steps Attempted
  1. System and Driver Updates:
    • Updated the system and NVIDIA drivers to the latest versions.
  2. Reinstall NVIDIA Drivers:
    • Removed and reinstalled NVIDIA drivers.
  3. GRUB and Xorg Configurations:
    • Tested various options in GRUB (nomodeset, nvidia-drm.modeset=1).
    • Adjusted settings in the nvidia.conf file.
  4. Test Different Kernels:
    • Installed and tested different kernels.
  5. Disable and Adjust KDE Compositor:
    • Tried different rendering options (XRender, OpenGL) and disabled VSync.
When I disable the compositor by pressing Alt + Shift + F12, the performance issues are resolved.
Xorg Configuration (/etc/X11/mhwd.d/nvidia.conf)
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 550.90.07
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    Option "NoLogo" "1"
    Option "TripleBuffer" "true"
    Option "metamodes" "nvidia-auto-select +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
    Option "RegistryDwords" "PerfLevelSrc=0x2222; PowerMizerEnable=0x1; PowerMizerDefault=0x1; PowerMizerDefaultAC=0x1"
    Option "Coolbits" "4"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Section "Extensions"
    Option         "COMPOSITE" "Enable"
EndSection
Section "InputClass"
    Identifier          "Keyboard Defaults"
    MatchIsKeyboard     "yes"
    Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
lsmod Output
nvidia_uvm           6696960  0
nvidia_drm            126976  18
nvidia_modeset       1605632  41 nvidia_drm
nvidia              60575744  661 nvidia_uvm,nvidia_modeset
video                  77824  2 asus_wmi,nvidia_modeset
System Information
  • OS: Manjaro 24.0.2 Wynsdey
  • Kernel Version: x86_64 6.9.3-3-MANJARO
  • CPU: AMD Ryzen 7 5700G
  • NVIDIA Driver Version: 550.90.07
  • GPU: NVIDIA GeForce RTX 4070 SUPER
  • DE: KDE
  • VM: KWin
Despite these efforts, the performance issue persists. I would greatly appreciate any guidance or additional suggestions that might help resolve this problem.
Thank you!
inxi -Farz
mhwd -li -l
please.
inxi -Farz
  Kernel: 6.10.0-rc3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
    root=UUID=810216a3-3623-4964-808a-2f725c38c998 rw quiet splash
    resume=UUID=f9bc6c55-8d23-4192-b8e8-5d57ed954cf8 udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
  Mobo: ASUSTeK model: TUF GAMING B550M-PLUS v: Rev X.0x
    UEFI: American Megatrends v: 3607 date: 03/22/2024
  Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
    microcode: 0xA50000F
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1387 high: 3242 min/max: 400/4673 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2992 2: 2989 3: 2988
    4: 400 5: 400 6: 400 7: 3242 8: 2990 9: 400 10: 400 11: 400 12: 400
    13: 2992 14: 400 15: 400 16: 400 bogomips: 121408
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
    affected
  Device-1: NVIDIA AD104 [GeForce RTX 4070 SUPER] vendor: Gigabyte
    driver: nvidia v: 550.90.07 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-04) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: none off: DP-3,HDMI-A-1
    empty: DP-1,DP-2 bus-ID: 01:00.0 chip-ID: 10de:2783 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4480x1080 s-dpi: 81 s-size: 1405x343mm (55.31x13.50")
    s-diag: 1446mm (56.94") monitors: <missing: xrandr>
  Monitor-1: DP-3 model: LG (GoldStar) HDR WFHD serial: <filter> built: 2022
    res: 2560x1080 dpi: 81 gamma: 1.2 size: 798x334mm (31.42x13.15")
    diag: 869mm (34.2") modes: max: 2560x1080 min: 640x480
  Monitor-2: HDMI-A-1 model: LG (GoldStar) E2241 serial: <filter>
    built: 2012 res: 1920x1080 dpi: 102 gamma: 1.2
    size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9 modes:
    max: 1920x1080 min: 640x480
  Monitor-3: Unknown-1 size-res: N/A modes: 2560x1080
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.90.07
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070
    SUPER/PCIe/SSE2 memory: 11.71 GiB
  API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4070 SUPER driver: nvidia v: 550.90.07 device-ID: 10de:2783
    surfaces: xcb,xlib
  Device-1: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
    bus-ID: 01:00.1 chip-ID: 10de:22bc class-ID: 0403
  Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
    link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
    link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Device-4: Astro Gaming MixAmp Pro driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2
    chip-ID: 9886:0038 class-ID: 0300
  API: ALSA v: k6.10.0-rc3-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
  IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: br-85ae7f4a0c1d state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-2: docker0 state: down mac: <filter>
  IF-ID-3: veth64d5be1 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-4: veth668ce84 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-5: veth87e8ee9 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-6: veth905978a state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  Info: services: apache2, NetworkManager, systemd-timesyncd
  Local Storage: total: 1.15 TiB used: 51.3 GiB (4.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup
    model: T-CREATE TM8FPE001T size: 953.87 GiB block-size: physical: 512 B
    fw-rev: VC0S036B temp: 51.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 240GB
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 04RL scheme: MBR
  ID-1: / raw-size: 334.06 GiB size: 327.75 GiB (98.11%)
    used: 29.74 GiB (9.1%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p5 maj-min: 259:5
  System Temperatures: cpu: 51.2 C mobo: N/A gpu: nvidia temp: 43 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Packages: 1126 pm: pacman pkgs: 1122 libs: 312 tools: pamac,yay pm: snap
    pkgs: 4
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    3: https://mirrors2.manjaro.org/stable/$repo/$arch
    4: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    5: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    9: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    10: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    11: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    12: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    13: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    14: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    15: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    16: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    17: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    18: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    19: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    20: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    21: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    22: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    24: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    25: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    26: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    27: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    28: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    29: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    30: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    31: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    32: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    33: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    34: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    35: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    36: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    37: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    38: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    39: https://mirror.init7.net/manjaro/stable/$repo/$arch
❯ inxi -Farz
  Speed (MHz): avg: 2016 high: 2993 min/max: 400/4673 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2992 2: 2993 3: 400
    4: 2988 5: 2992 6: 400 7: 400 8: 2992 9: 2990 10: 2982 11: 400 12: 400
    13: 400 14: 2948 15: 2989 16: 2990 bogomips: 121408
    affected
    surfaces: xcb,xlib
    class-ID: 0403
    class-ID: 0403
    mac: <filter>
    mac: <filter>
    mac: <filter>
    mac: <filter>
    mac: <filter>
    fw-rev: VC0S036B temp: 50.9 C scheme: GPT
  System Temperatures: cpu: 46.2 C mobo: N/A gpu: nvidia temp: 43 C
    pkgs: 4
    40: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    41: https://manjaro.ynh.ovh/stable/$repo/$arch
    42: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    43: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    44: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    45: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    46: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    47: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    48: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    49: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    50: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    51: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    52: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    53: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    54: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    55: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    56: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    57: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    58: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    59: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    60: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
  Memory: total: 32 GiB note: est. available: 31.14 GiB used: 7.88 GiB (25.3%)
  Processes: 416 Power: uptime: 27m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.43 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.26
    running-in: konsole inxi: 3.3.34
mhwd -li -l
> Installed PCI configs:
          video-nvidia            2024.05.03               false            PCI
> 0000:01:00.0 (0300:10de:2783) Display controller nVidia Corporation:
           video-linux            2024.05.06                true            PCI
Interesting.
Have you disabled the iGPU through BIOS?
I have checked the BIOS settings, and it seems like the integrated GPU is disabled. Here is a photo of the BIOS settings I currently have:
  • IGFX Multi-Monitor: Disabled
  • Primary Video Device: PCIe Video
It looks like the iGPU is indeed disabled based on these settings, but I’m not entirely sure if this is the correct configuration.
Have you PEG Graphics ?
After extensive research, it appears that there is an issue with KDE when used with Wayland and the current NVIDIA drivers. I found several mentions of this issue in different forums and bug reports. One specific example is the bug reported here: Bug 487728.
In the report, one of the KDE developers comments: “I looked into this, and it’s hanging in the NVidia driver, which waits for KWin to release a buffer that will only be released once the window is shown. This will need to be fixed in the driver.”
