System: Manjaro Linux
Issue: Games running extremely slowly after recent stable update
After the recent stable update, all my games have started running extremely slowly, like a slideshow. The games launch normally but the framerates are so low they’re essentially unplayable. I’m not entirely sure if the culprit is a Manjaro system update or NVIDIA driver update, but the timing coincides with my last update. One thing that I noticed is that when starting games there usually was a characteristic coil noise in my PSU, that does not happen after the update which leads me to assume that the games somehow are not using my GPU, which is weird since my CPU does not have integrated graphics.
KDE loads in the full 3440x1440p resolution, so I think at least part of the drivers are being loaded correctly.
Affected Games Tested
- Clair Obscur: Expedition 33
- GTA IV Complete Edition
- Satisfactory
All three games exhibit the same extreme performance degradation.
Troubleshooting Steps Taken
Timeshift Restore: I performed a Timeshift restore which initially seemed to resolve the issue and games ran normally again.
Update Attempt: After confirming games were working post-restore, I ran updates again and returned to the same Timeshift snapshot, but the performance issue persisted.
Reinstalled NVIDIA drivers: removed and switched between
nvidia-openandnvidia-open-dkmsusing pacman, behavior stays the same.
System Information
Kernel: 6.12.37-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=5805d0d7-c794-4576-9ac0-19460a16bb03 rw rootflags=subvol=@ quiet
splash resume=UUID=f16d6dfc-b7fd-4b53-a882-f38b77671e0a
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.15.0
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASRock model: B450M Steel Legend
serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends v: P10.30 date: 07/09/2024
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201211
desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1734 min/max: 550/4651 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1734 2: 1734 3: 1734
4: 1734 5: 1734 6: 1734 7: 1734 8: 1734 9: 1734 10: 1734 11: 1734 12: 1734
bogomips: 88656
affected
Device-1: NVIDIA GB203 [GeForce RTX 5070 Ti] vendor: Gigabyte driver: nvidia
v: 575.64.03 alternate: nouveau,nvidia_drm non-free: N/A
status: unknown device ID pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max:
gen: 5 speed: 32 GT/s ports: active: none off: DP-2
empty: DP-1,DP-3,HDMI-A-1 bus-ID: 07:00.0 chip-ID: 10de:2c05 class-ID: 0300
Device-2: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4.3:5
chip-ID: 046d:085b class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_x11 driver: X: loaded: nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x333mm (31.57x13.11")
s-diag: 868mm (34.19")
Monitor-1: DP-2 note: disabled model: LG (GoldStar) ULTRAWIDE
serial: <filter> built: 2025 res: mode: 3440x1440 hz: 160 scale: 100% (1)
dpi: 109 gamma: 1.2 size: 800x330mm (31.5x12.99") diag: 867mm (34.1")
modes: max: 3440x1440 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 5070 Ti/PCIe/SSE2
memory: 15.55 GiB
API: Vulkan v: 1.4.313 layers: 2 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 5070 Ti driver: nvidia v: 575.64.03 device-ID: 10de:2c05
surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 5 speed: 32 GT/s bus-ID: 07:00.1 chip-ID: 10de:22e9
class-ID: 0403
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.12.37-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: TP-Link Bluetooth USB Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 2357:0604
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 931.51 GiB used: 374.77 GiB (40.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV3S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: ERFK1N.3 temp: 33.9 C
scheme: GPT
ID-1: / raw-size: 914.12 GiB size: 914.12 GiB (100.00%)
used: 374.77 GiB (41.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 616 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 914.12 GiB size: 914.12 GiB (100.00%)
ID-4: /var/log raw-size: 914.12 GiB size: 914.12 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.1 GiB used: 512 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 54.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB available: 15.54 GiB used: 4.34 GiB (27.9%)
Processes: 359 Power: uptime: 27m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1459 pm: pacman pkgs: 1417 libs: 383 tools: pamac pm: flatpak
pkgs: 42 Compilers: gcc: 15.1.1 alt: 14 Shell: Zsh v: 5.9 running-in: konsole
inxi: 3.3.38
mhwd -li output:
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2024.05.06 true PCI
If you need any additional information, please let me know.
Any help or suggestions would be greatly appreciated!
