Pendrive not showing up
Pendrive doesn’t mount but appears on lsusb. Please help
Hi and welcome.
Can you provide more information?
Such as the output of a failed mount?
Example:
lsblk
sudo mount /dev/sdb1 /mnt
(of course use device path correct for your system)
I will also include a guide with tips like how to format code
It may also be helpful to have
journalctl --follow
running in a terminal
while you plug in the drive and remove it
and look at what it prints when you do …
It will tell you what the system sees and does when you do this.
exFAT ?
