PdaNet for wifi-direct hotspot
This isn’t looking promising. :frowning:
You need to read the NetworkManager journal messages and find out which DNS server you get from your Phone.
You wound get a connection as long as DNS isn’t working on the shell. Or you use only IPs.
Yes nothing is getting a connection but firefox. I will have to learn to get the NetworkManager journal. Never had to look at it before.
It is for every service unit the same.
journalctl -u NetworkManager.service -b --no-pager
-b shows only messages since the last boot.
I don’t know what I’m looking for. Here is a large portion of the journal, and I do have the script running right now. With default DNS settings.
Apr 19 07:38:17 ltp NetworkManager[268849]: <info>  [1618835897.2014] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.1.235
Apr 19 07:38:17 ltp NetworkManager[268849]: <info>  [1618835897.2028] device (wlp4s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Apr 19 07:38:17 ltp NetworkManager[268849]: <info>  [1618835897.2045] device (wlp4s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Apr 19 07:38:17 ltp NetworkManager[268849]: <info>  [1618835897.2048] device (wlp4s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Apr 19 07:38:17 ltp NetworkManager[268849]: <info>  [1618835897.2053] manager: NetworkManager state is now CONNECTED_LOCAL
Apr 19 07:38:17 ltp NetworkManager[268849]: <info>  [1618835897.2068] manager: NetworkManager state is now CONNECTED_SITE
Apr 19 07:38:17 ltp NetworkManager[268849]: <info>  [1618835897.2070] policy: set 'Chapa313 1' (wlp4s0) as default for IPv4 routing and DNS
Apr 19 07:38:17 ltp NetworkManager[268849]: <info>  [1618835897.2577] device (wlp4s0): Activation: successful, device activated.
Apr 19 07:38:22 ltp NetworkManager[268849]: <info>  [1618835902.5406] manager: NetworkManager state is now CONNECTED_GLOBAL
Apr 19 07:38:23 ltp NetworkManager[268849]: <info>  [1618835903.0109] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 07:38:23 ltp NetworkManager[268849]: <info>  [1618835903.0119] policy: set 'Chapa313 1' (wlp4s0) as default for IPv6 routing and DNS
Apr 19 07:38:23 ltp NetworkManager[268849]: <info>  [1618835903.0847] dhcp6 (wlp4s0): state changed unknown -> bound, address=2600:1700:31:1150::14
Apr 19 07:41:21 ltp NetworkManager[268849]: <info>  [1618836081.0372] device (wlp4s0): state change: activated -> deactivating (reason 'user-requested', sys-iface-state: 'managed')
Apr 19 07:41:21 ltp NetworkManager[268849]: <info>  [1618836081.0375] manager: NetworkManager state is now DISCONNECTING
Apr 19 07:41:21 ltp NetworkManager[268849]: <info>  [1618836081.0387] audit: op="device-disconnect" interface="wlp4s0" ifindex=3 pid=1564 uid=1000 result="success"
Apr 19 07:41:21 ltp NetworkManager[268849]: <info>  [1618836081.1969] device (wlp4s0): state change: deactivating -> disconnected (reason 'user-requested', sys-iface-state: 'managed')
Apr 19 07:41:21 ltp NetworkManager[268849]: <info>  [1618836081.2280] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 07:41:21 ltp NetworkManager[268849]: <info>  [1618836081.2280] dhcp4 (wlp4s0): state changed bound -> done
Apr 19 07:41:21 ltp NetworkManager[268849]: <info>  [1618836081.2285] dhcp6 (wlp4s0): canceled DHCP transaction
Apr 19 07:41:21 ltp NetworkManager[268849]: <info>  [1618836081.2285] dhcp6 (wlp4s0): state changed bound -> done
Apr 19 07:41:21 ltp NetworkManager[268849]: <info>  [1618836081.2485] device (wlp4s0): set-hw-addr: set MAC address to 0E:18:6D:D2:6F:1D (scanning)
Apr 19 07:41:21 ltp NetworkManager[268849]: <info>  [1618836081.6076] manager: NetworkManager state is now DISCONNECTED
Apr 19 07:41:21 ltp NetworkManager[268849]: <info>  [1618836081.6114] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 19 07:41:21 ltp NetworkManager[268849]: <info>  [1618836081.6115] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Apr 19 07:41:21 ltp NetworkManager[268849]: <info>  [1618836081.6170] device (wlp4s0): supplicant interface state: disconnected -> interface_disabled
Apr 19 07:41:21 ltp NetworkManager[268849]: <info>  [1618836081.6170] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> interface_disabled
Apr 19 07:41:21 ltp NetworkManager[268849]: <info>  [1618836081.6171] device (wlp4s0): supplicant interface state: interface_disabled -> disconnected
Apr 19 07:41:21 ltp NetworkManager[268849]: <info>  [1618836081.6171] device (p2p-dev-wlp4s0): supplicant management interface state: interface_disabled -> disconnected
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.0052] device (wlp4s0): Activation: starting connection 'DIRECT-03-moto g pro-PdaNet' (07f162b9-05f7-412a-9be3-6c65fbfa71cb)
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.0053] audit: op="connection-activate" uuid="07f162b9-05f7-412a-9be3-6c65fbfa71cb" name="DIRECT-03-moto g pro-PdaNet" pid=1564 uid=1000 result="success"
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.0054] device (wlp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.0058] manager: NetworkManager state is now CONNECTING
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.0250] device (wlp4s0): set-hw-addr: reset MAC address to 5C:51:4F:F6:B7:DD (preserve)
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.2560] device (wlp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.2563] device (wlp4s0): Activation: (wifi) access point 'DIRECT-03-moto g pro-PdaNet' has security, but secrets are required.
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.2563] device (wlp4s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.2566] sup-iface[4981f8f080b0e70f,4,wlp4s0]: wps: type pbc start...
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.2633] device (wlp4s0): supplicant interface state: disconnected -> interface_disabled
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.2633] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> interface_disabled
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.2664] device (wlp4s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.2667] device (wlp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.2669] device (wlp4s0): Activation: (wifi) connection 'DIRECT-03-moto g pro-PdaNet' has security, and secrets exist.  No new secrets needed.
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.2669] Config: added 'ssid' value 'DIRECT-03-moto g pro-PdaNet'
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.2669] Config: added 'scan_ssid' value '1'
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.2669] Config: added 'bgscan' value 'simple:30:-70:86400'
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.2670] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.2670] Config: added 'psk' value '<hidden>'
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.3498] device (wlp4s0): supplicant interface state: interface_disabled -> disconnected
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.3499] device (p2p-dev-wlp4s0): supplicant management interface state: interface_disabled -> disconnected
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.3598] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 07:41:47 ltp NetworkManager[268849]: <info>  [1618836107.3598] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 07:41:50 ltp NetworkManager[268849]: <info>  [1618836110.6306] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 07:41:50 ltp NetworkManager[268849]: <info>  [1618836110.6307] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 07:41:50 ltp NetworkManager[268849]: <info>  [1618836110.6772] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 07:41:50 ltp NetworkManager[268849]: <info>  [1618836110.6772] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 07:41:50 ltp NetworkManager[268849]: <info>  [1618836110.7056] device (wlp4s0): supplicant interface state: associating -> associated
Apr 19 07:41:50 ltp NetworkManager[268849]: <info>  [1618836110.7057] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> associated
Apr 19 07:41:50 ltp NetworkManager[268849]: <info>  [1618836110.7133] device (wlp4s0): supplicant interface state: associated -> completed
Apr 19 07:41:50 ltp NetworkManager[268849]: <info>  [1618836110.7133] device (wlp4s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "DIRECT-03-moto g pro-PdaNet"
Apr 19 07:41:50 ltp NetworkManager[268849]: <info>  [1618836110.7133] device (p2p-dev-wlp4s0): supplicant management interface state: associated -> completed
Apr 19 07:41:50 ltp NetworkManager[268849]: <info>  [1618836110.7135] device (wlp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Apr 19 07:41:50 ltp NetworkManager[268849]: <info>  [1618836110.7138] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 07:41:52 ltp NetworkManager[268849]: <info>  [1618836112.9418] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.49.90
Apr 19 07:41:52 ltp NetworkManager[268849]: <info>  [1618836112.9431] device (wlp4s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Apr 19 07:41:52 ltp NetworkManager[268849]: <info>  [1618836112.9452] device (wlp4s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Apr 19 07:41:52 ltp NetworkManager[268849]: <info>  [1618836112.9453] device (wlp4s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Apr 19 07:41:52 ltp NetworkManager[268849]: <info>  [1618836112.9457] manager: NetworkManager state is now CONNECTED_LOCAL
Apr 19 07:41:52 ltp NetworkManager[268849]: <info>  [1618836112.9472] manager: NetworkManager state is now CONNECTED_SITE
Apr 19 07:41:52 ltp NetworkManager[268849]: <info>  [1618836112.9473] policy: set 'DIRECT-03-moto g pro-PdaNet' (wlp4s0) as default for IPv4 routing and DNS
Apr 19 07:41:52 ltp NetworkManager[268849]: <info>  [1618836112.9982] device (wlp4s0): Activation: successful, device activated.
Apr 19 08:03:18 ltp NetworkManager[268849]: <info>  [1618837398.8843] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 19 08:03:18 ltp NetworkManager[268849]: <info>  [1618837398.8844] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Apr 19 08:03:18 ltp NetworkManager[268849]: <info>  [1618837398.9580] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 08:03:18 ltp NetworkManager[268849]: <info>  [1618837398.9580] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 08:03:21 ltp NetworkManager[268849]: <info>  [1618837401.9703] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 08:03:21 ltp NetworkManager[268849]: <info>  [1618837401.9703] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 08:03:21 ltp NetworkManager[268849]: <info>  [1618837401.9743] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 08:03:21 ltp NetworkManager[268849]: <info>  [1618837401.9743] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 08:03:21 ltp NetworkManager[268849]: <info>  [1618837401.9911] device (wlp4s0): supplicant interface state: associating -> associated
Apr 19 08:03:21 ltp NetworkManager[268849]: <info>  [1618837401.9911] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> associated
Apr 19 08:03:21 ltp NetworkManager[268849]: <info>  [1618837401.9911] device (wlp4s0): DHCPv4 lease renewal requested
Apr 19 08:03:22 ltp NetworkManager[268849]: <info>  [1618837402.0151] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 08:03:22 ltp NetworkManager[268849]: <info>  [1618837402.0152] dhcp4 (wlp4s0): state changed bound -> done
Apr 19 08:03:22 ltp NetworkManager[268849]: <info>  [1618837402.0159] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 08:03:22 ltp NetworkManager[268849]: <info>  [1618837402.0166] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 19 08:03:22 ltp NetworkManager[268849]: <info>  [1618837402.0167] device (p2p-dev-wlp4s0): supplicant management interface state: associated -> 4way_handshake
Apr 19 08:03:22 ltp NetworkManager[268849]: <info>  [1618837402.0317] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 19 08:03:22 ltp NetworkManager[268849]: <info>  [1618837402.0321] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
Apr 19 08:03:24 ltp NetworkManager[268849]: <info>  [1618837404.1313] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.49.90
Apr 19 08:33:24 ltp NetworkManager[268849]: <info>  [1618839204.1803] dhcp4 (wlp4s0): state changed bound -> extended, address=192.168.49.90
Apr 19 09:00:30 ltp NetworkManager[268849]: <info>  [1618840830.1018] dhcp4 (wlp4s0): state changed extended -> extended, address=192.168.49.90
Apr 19 09:12:52 ltp NetworkManager[268849]: <info>  [1618841572.6714] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 19 09:12:52 ltp NetworkManager[268849]: <info>  [1618841572.6714] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Apr 19 09:12:52 ltp NetworkManager[268849]: <info>  [1618841572.7195] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 09:12:52 ltp NetworkManager[268849]: <info>  [1618841572.7195] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 09:12:55 ltp NetworkManager[268849]: <info>  [1618841575.8064] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 09:12:55 ltp NetworkManager[268849]: <info>  [1618841575.8064] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 09:12:55 ltp NetworkManager[268849]: <info>  [1618841575.8143] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 09:12:55 ltp NetworkManager[268849]: <info>  [1618841575.8144] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 09:12:55 ltp NetworkManager[268849]: <info>  [1618841575.8841] device (wlp4s0): supplicant interface state: associating -> 4way_handshake
Apr 19 09:12:55 ltp NetworkManager[268849]: <info>  [1618841575.8841] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> 4way_handshake
Apr 19 09:12:55 ltp NetworkManager[268849]: <info>  [1618841575.8841] device (wlp4s0): DHCPv4 lease renewal requested
Apr 19 09:12:55 ltp NetworkManager[268849]: <info>  [1618841575.8842] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 09:12:55 ltp NetworkManager[268849]: <info>  [1618841575.8842] dhcp4 (wlp4s0): state changed extended -> done
Apr 19 09:12:55 ltp NetworkManager[268849]: <info>  [1618841575.8846] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 09:12:55 ltp NetworkManager[268849]: <info>  [1618841575.9116] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 19 09:12:55 ltp NetworkManager[268849]: <info>  [1618841575.9120] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
Apr 19 09:13:05 ltp NetworkManager[268849]: <info>  [1618841585.8703] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.49.90
Apr 19 09:13:20 ltp NetworkManager[268849]: <info>  [1618841600.3138] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 19 09:13:20 ltp NetworkManager[268849]: <info>  [1618841600.3139] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Apr 19 09:13:20 ltp NetworkManager[268849]: <info>  [1618841600.3840] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 09:13:20 ltp NetworkManager[268849]: <info>  [1618841600.3841] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 09:13:23 ltp NetworkManager[268849]: <info>  [1618841603.3125] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 09:13:23 ltp NetworkManager[268849]: <info>  [1618841603.3125] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 09:13:23 ltp NetworkManager[268849]: <info>  [1618841603.3191] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 09:13:23 ltp NetworkManager[268849]: <info>  [1618841603.3191] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 09:13:23 ltp NetworkManager[268849]: <info>  [1618841603.3423] device (wlp4s0): supplicant interface state: associating -> 4way_handshake
Apr 19 09:13:23 ltp NetworkManager[268849]: <info>  [1618841603.3423] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> 4way_handshake
Apr 19 09:13:23 ltp NetworkManager[268849]: <info>  [1618841603.3423] device (wlp4s0): DHCPv4 lease renewal requested
Apr 19 09:13:23 ltp NetworkManager[268849]: <info>  [1618841603.3779] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 09:13:23 ltp NetworkManager[268849]: <info>  [1618841603.3780] dhcp4 (wlp4s0): state changed bound -> done
Apr 19 09:13:23 ltp NetworkManager[268849]: <info>  [1618841603.3783] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 09:13:23 ltp NetworkManager[268849]: <info>  [1618841603.3791] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 19 09:13:23 ltp NetworkManager[268849]: <info>  [1618841603.3793] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
Apr 19 09:13:23 ltp NetworkManager[268849]: <info>  [1618841603.4694] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.49.90
Apr 19 09:13:24 ltp NetworkManager[268849]: <info>  [1618841604.0239] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 19 09:13:24 ltp NetworkManager[268849]: <info>  [1618841604.0240] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Apr 19 09:13:24 ltp NetworkManager[268849]: <info>  [1618841604.1031] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 09:13:24 ltp NetworkManager[268849]: <info>  [1618841604.1032] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 09:13:27 ltp NetworkManager[268849]: <info>  [1618841607.0184] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 09:13:27 ltp NetworkManager[268849]: <info>  [1618841607.0185] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 09:13:27 ltp NetworkManager[268849]: <info>  [1618841607.0220] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 09:13:27 ltp NetworkManager[268849]: <info>  [1618841607.0220] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 09:13:27 ltp NetworkManager[268849]: <info>  [1618841607.0399] device (wlp4s0): supplicant interface state: associating -> 4way_handshake
Apr 19 09:13:27 ltp NetworkManager[268849]: <info>  [1618841607.0399] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> 4way_handshake
Apr 19 09:13:27 ltp NetworkManager[268849]: <info>  [1618841607.0399] device (wlp4s0): DHCPv4 lease renewal requested
Apr 19 09:13:27 ltp NetworkManager[268849]: <info>  [1618841607.0627] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 09:13:27 ltp NetworkManager[268849]: <info>  [1618841607.0627] dhcp4 (wlp4s0): state changed bound -> done
Apr 19 09:13:27 ltp NetworkManager[268849]: <info>  [1618841607.0632] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 09:13:27 ltp NetworkManager[268849]: <info>  [1618841607.0643] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 19 09:13:27 ltp NetworkManager[268849]: <info>  [1618841607.0645] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
Apr 19 09:13:29 ltp NetworkManager[268849]: <info>  [1618841609.1624] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.49.90
Apr 19 09:18:47 ltp NetworkManager[268849]: <info>  [1618841927.8092] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 19 09:18:47 ltp NetworkManager[268849]: <info>  [1618841927.8093] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Apr 19 09:18:47 ltp NetworkManager[268849]: <info>  [1618841927.8790] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 09:18:47 ltp NetworkManager[268849]: <info>  [1618841927.8790] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 09:18:50 ltp NetworkManager[268849]: <info>  [1618841930.8914] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 09:18:50 ltp NetworkManager[268849]: <info>  [1618841930.8914] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 09:18:50 ltp NetworkManager[268849]: <info>  [1618841930.8958] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 09:18:50 ltp NetworkManager[268849]: <info>  [1618841930.8958] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 09:18:50 ltp NetworkManager[268849]: <info>  [1618841930.9175] device (wlp4s0): supplicant interface state: associating -> associated
Apr 19 09:18:50 ltp NetworkManager[268849]: <info>  [1618841930.9176] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> associated
Apr 19 09:18:50 ltp NetworkManager[268849]: <info>  [1618841930.9176] device (wlp4s0): DHCPv4 lease renewal requested
Apr 19 09:18:50 ltp NetworkManager[268849]: <info>  [1618841930.9425] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 09:18:50 ltp NetworkManager[268849]: <info>  [1618841930.9426] dhcp4 (wlp4s0): state changed bound -> done
Apr 19 09:18:50 ltp NetworkManager[268849]: <info>  [1618841930.9430] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 09:18:50 ltp NetworkManager[268849]: <info>  [1618841930.9437] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 19 09:18:50 ltp NetworkManager[268849]: <info>  [1618841930.9438] device (p2p-dev-wlp4s0): supplicant management interface state: associated -> 4way_handshake
Apr 19 09:18:50 ltp NetworkManager[268849]: <info>  [1618841930.9438] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 19 09:18:50 ltp NetworkManager[268849]: <info>  [1618841930.9441] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
Apr 19 09:18:51 ltp NetworkManager[268849]: <info>  [1618841931.1183] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.49.90
Apr 19 09:18:51 ltp NetworkManager[268849]: <info>  [1618841931.6471] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 19 09:18:51 ltp NetworkManager[268849]: <info>  [1618841931.6472] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Apr 19 09:18:51 ltp NetworkManager[268849]: <info>  [1618841931.7166] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 09:18:51 ltp NetworkManager[268849]: <info>  [1618841931.7167] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 09:18:54 ltp NetworkManager[268849]: <info>  [1618841934.7091] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 09:18:54 ltp NetworkManager[268849]: <info>  [1618841934.7092] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 09:18:54 ltp NetworkManager[268849]: <info>  [1618841934.7165] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 09:18:54 ltp NetworkManager[268849]: <info>  [1618841934.7166] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 09:18:54 ltp NetworkManager[268849]: <info>  [1618841934.7360] device (wlp4s0): supplicant interface state: associating -> associated
Apr 19 09:18:54 ltp NetworkManager[268849]: <info>  [1618841934.7360] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> associated
Apr 19 09:18:54 ltp NetworkManager[268849]: <info>  [1618841934.7361] device (wlp4s0): DHCPv4 lease renewal requested
Apr 19 09:18:54 ltp NetworkManager[268849]: <info>  [1618841934.7607] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 09:18:54 ltp NetworkManager[268849]: <info>  [1618841934.7607] dhcp4 (wlp4s0): state changed bound -> done
Apr 19 09:18:54 ltp NetworkManager[268849]: <info>  [1618841934.7611] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 09:18:54 ltp NetworkManager[268849]: <info>  [1618841934.7620] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 19 09:18:54 ltp NetworkManager[268849]: <info>  [1618841934.7620] device (p2p-dev-wlp4s0): supplicant management interface state: associated -> 4way_handshake
Apr 19 09:18:54 ltp NetworkManager[268849]: <info>  [1618841934.7621] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 19 09:18:54 ltp NetworkManager[268849]: <info>  [1618841934.7623] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
Apr 19 09:18:54 ltp NetworkManager[268849]: <info>  [1618841934.8470] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.49.90
Apr 19 09:19:31 ltp NetworkManager[268849]: <info>  [1618841971.6608] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 19 09:19:31 ltp NetworkManager[268849]: <info>  [1618841971.6608] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Apr 19 09:19:31 ltp NetworkManager[268849]: <info>  [1618841971.7304] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 09:19:31 ltp NetworkManager[268849]: <info>  [1618841971.7304] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 09:19:34 ltp NetworkManager[268849]: <info>  [1618841974.6311] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 09:19:34 ltp NetworkManager[268849]: <info>  [1618841974.6311] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 09:19:34 ltp NetworkManager[268849]: <info>  [1618841974.6356] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 09:19:34 ltp NetworkManager[268849]: <info>  [1618841974.6357] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 09:19:34 ltp NetworkManager[268849]: <info>  [1618841974.6496] device (wlp4s0): supplicant interface state: associating -> 4way_handshake
Apr 19 09:19:34 ltp NetworkManager[268849]: <info>  [1618841974.6496] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> 4way_handshake
Apr 19 09:19:34 ltp NetworkManager[268849]: <info>  [1618841974.6497] device (wlp4s0): DHCPv4 lease renewal requested
Apr 19 09:19:34 ltp NetworkManager[268849]: <info>  [1618841974.6700] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 09:19:34 ltp NetworkManager[268849]: <info>  [1618841974.6701] dhcp4 (wlp4s0): state changed bound -> done
Apr 19 09:19:34 ltp NetworkManager[268849]: <info>  [1618841974.6704] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 09:19:35 ltp NetworkManager[268849]: <info>  [1618841975.6593] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 19 09:19:35 ltp NetworkManager[268849]: <info>  [1618841975.6596] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
Apr 19 09:19:37 ltp NetworkManager[268849]: <info>  [1618841977.8373] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 19 09:19:37 ltp NetworkManager[268849]: <info>  [1618841977.8373] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Apr 19 09:19:37 ltp NetworkManager[268849]: <info>  [1618841977.9169] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 09:19:37 ltp NetworkManager[268849]: <info>  [1618841977.9169] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 09:19:40 ltp NetworkManager[268849]: <info>  [1618841980.7341] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 09:19:40 ltp NetworkManager[268849]: <info>  [1618841980.7342] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 09:19:40 ltp NetworkManager[268849]: <info>  [1618841980.7372] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 09:19:40 ltp NetworkManager[268849]: <info>  [1618841980.7372] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 09:19:40 ltp NetworkManager[268849]: <info>  [1618841980.7896] device (wlp4s0): supplicant interface state: associating -> 4way_handshake
Apr 19 09:19:40 ltp NetworkManager[268849]: <info>  [1618841980.7896] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> 4way_handshake
Apr 19 09:19:40 ltp NetworkManager[268849]: <info>  [1618841980.7897] device (wlp4s0): DHCPv4 lease renewal requested
Apr 19 09:19:40 ltp NetworkManager[268849]: <info>  [1618841980.8088] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 09:19:40 ltp NetworkManager[268849]: <info>  [1618841980.8088] dhcp4 (wlp4s0): state changed unknown -> done
Apr 19 09:19:40 ltp NetworkManager[268849]: <info>  [1618841980.8092] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 09:19:40 ltp NetworkManager[268849]: <info>  [1618841980.8100] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 19 09:19:40 ltp NetworkManager[268849]: <info>  [1618841980.8104] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
Apr 19 09:19:40 ltp NetworkManager[268849]: <info>  [1618841980.8858] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.49.90
Apr 19 09:19:41 ltp NetworkManager[268849]: <info>  [1618841981.5005] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 19 09:19:41 ltp NetworkManager[268849]: <info>  [1618841981.5005] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Apr 19 09:19:41 ltp NetworkManager[268849]: <info>  [1618841981.5566] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 09:19:41 ltp NetworkManager[268849]: <info>  [1618841981.5567] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 09:19:44 ltp NetworkManager[268849]: <info>  [1618841984.3739] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 09:19:44 ltp NetworkManager[268849]: <info>  [1618841984.3739] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 09:19:44 ltp NetworkManager[268849]: <info>  [1618841984.3796] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 09:19:44 ltp NetworkManager[268849]: <info>  [1618841984.3796] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 09:19:44 ltp NetworkManager[268849]: <info>  [1618841984.4015] device (wlp4s0): supplicant interface state: associating -> associated
Apr 19 09:19:44 ltp NetworkManager[268849]: <info>  [1618841984.4015] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> associated
Apr 19 09:19:44 ltp NetworkManager[268849]: <info>  [1618841984.4016] device (wlp4s0): DHCPv4 lease renewal requested
Apr 19 09:19:44 ltp NetworkManager[268849]: <info>  [1618841984.4279] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 09:19:44 ltp NetworkManager[268849]: <info>  [1618841984.4280] dhcp4 (wlp4s0): state changed bound -> done
Apr 19 09:19:44 ltp NetworkManager[268849]: <info>  [1618841984.4285] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 09:19:44 ltp NetworkManager[268849]: <info>  [1618841984.4293] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 19 09:19:44 ltp NetworkManager[268849]: <info>  [1618841984.4293] device (p2p-dev-wlp4s0): supplicant management interface state: associated -> 4way_handshake
Apr 19 09:19:44 ltp NetworkManager[268849]: <info>  [1618841984.4293] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 19 09:19:44 ltp NetworkManager[268849]: <info>  [1618841984.4296] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
Apr 19 09:19:44 ltp NetworkManager[268849]: <info>  [1618841984.5146] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.49.90
Apr 19 09:19:55 ltp NetworkManager[268849]: <info>  [1618841995.1638] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 19 09:19:55 ltp NetworkManager[268849]: <info>  [1618841995.1638] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Apr 19 09:19:55 ltp NetworkManager[268849]: <info>  [1618841995.2403] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 09:19:55 ltp NetworkManager[268849]: <info>  [1618841995.2403] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 09:19:58 ltp NetworkManager[268849]: <info>  [1618841998.0952] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 09:19:58 ltp NetworkManager[268849]: <info>  [1618841998.0952] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 09:19:58 ltp NetworkManager[268849]: <info>  [1618841998.1722] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 09:19:58 ltp NetworkManager[268849]: <info>  [1618841998.1722] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 09:19:58 ltp NetworkManager[268849]: <info>  [1618841998.1938] device (wlp4s0): supplicant interface state: associating -> associated
Apr 19 09:19:58 ltp NetworkManager[268849]: <info>  [1618841998.1939] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> associated
Apr 19 09:19:58 ltp NetworkManager[268849]: <info>  [1618841998.1939] device (wlp4s0): DHCPv4 lease renewal requested
Apr 19 09:19:58 ltp NetworkManager[268849]: <info>  [1618841998.2078] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 09:19:58 ltp NetworkManager[268849]: <info>  [1618841998.2079] dhcp4 (wlp4s0): state changed bound -> done
Apr 19 09:19:58 ltp NetworkManager[268849]: <info>  [1618841998.2082] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 09:19:58 ltp NetworkManager[268849]: <info>  [1618841998.2090] device (wlp4s0): supplicant interface state: associated -> completed
Apr 19 09:19:58 ltp NetworkManager[268849]: <info>  [1618841998.2094] device (p2p-dev-wlp4s0): supplicant management interface state: associated -> completed
Apr 19 09:19:58 ltp NetworkManager[268849]: <info>  [1618841998.2962] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.49.90
Apr 19 09:19:58 ltp NetworkManager[268849]: <info>  [1618841998.8471] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 19 09:19:58 ltp NetworkManager[268849]: <info>  [1618841998.8472] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Apr 19 09:19:58 ltp NetworkManager[268849]: <info>  [1618841998.9035] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 09:19:58 ltp NetworkManager[268849]: <info>  [1618841998.9036] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 09:20:14 ltp NetworkManager[268849]: <warn>  [1618842014.1045] device (wlp4s0): link timed out.
Apr 19 09:20:14 ltp NetworkManager[268849]: <info>  [1618842014.1050] device (wlp4s0): state change: activated -> failed (reason 'ssid-not-found', sys-iface-state: 'managed')
Apr 19 09:20:14 ltp NetworkManager[268849]: <info>  [1618842014.1053] manager: NetworkManager state is now CONNECTED_LOCAL
Apr 19 09:20:14 ltp NetworkManager[268849]: <info>  [1618842014.1056] manager: NetworkManager state is now DISCONNECTED
Apr 19 09:20:14 ltp NetworkManager[268849]: <info>  [1618842014.1252] device (wlp4s0): set-hw-addr: set MAC address to 3A:33:8C:23:87:23 (scanning)
Apr 19 09:20:14 ltp NetworkManager[268849]: <warn>  [1618842014.4204] device (wlp4s0): Activation: failed for connection 'DIRECT-03-moto g pro-PdaNet'
Apr 19 09:20:14 ltp NetworkManager[268849]: <info>  [1618842014.4264] device (wlp4s0): supplicant interface state: scanning -> interface_disabled
Apr 19 09:20:14 ltp NetworkManager[268849]: <info>  [1618842014.4265] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> interface_disabled
Apr 19 09:20:14 ltp NetworkManager[268849]: <info>  [1618842014.4313] device (wlp4s0): supplicant interface state: interface_disabled -> scanning
Apr 19 09:20:14 ltp NetworkManager[268849]: <info>  [1618842014.4314] device (p2p-dev-wlp4s0): supplicant management interface state: interface_disabled -> scanning
Apr 19 09:20:14 ltp NetworkManager[268849]: <info>  [1618842014.4319] device (wlp4s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Apr 19 09:20:14 ltp NetworkManager[268849]: <info>  [1618842014.4513] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 09:20:14 ltp NetworkManager[268849]: <info>  [1618842014.4513] dhcp4 (wlp4s0): state changed bound -> done
Apr 19 09:20:17 ltp NetworkManager[268849]: <info>  [1618842017.6258] device (wlp4s0): supplicant interface state: scanning -> disconnected
Apr 19 09:20:17 ltp NetworkManager[268849]: <info>  [1618842017.6259] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> disconnected
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.5422] device (wlp4s0): supplicant interface state: disconnected -> inactive
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.5423] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> inactive
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.5458] policy: auto-activating connection 'DIRECT-03-moto g pro-PdaNet' (07f162b9-05f7-412a-9be3-6c65fbfa71cb)
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.5462] device (wlp4s0): Activation: starting connection 'DIRECT-03-moto g pro-PdaNet' (07f162b9-05f7-412a-9be3-6c65fbfa71cb)
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.5463] device (wlp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.5466] manager: NetworkManager state is now CONNECTING
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.5672] device (wlp4s0): set-hw-addr: reset MAC address to 5C:51:4F:F6:B7:DD (preserve)
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8007] device (wlp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8011] device (wlp4s0): Activation: (wifi) access point 'DIRECT-03-moto g pro-PdaNet' has security, but secrets are required.
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8011] device (wlp4s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8014] sup-iface[4981f8f080b0e70f,4,wlp4s0]: wps: type pbc start...
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8049] device (wlp4s0): supplicant interface state: inactive -> interface_disabled
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8049] device (p2p-dev-wlp4s0): supplicant management interface state: inactive -> interface_disabled
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8095] device (wlp4s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8098] device (wlp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8101] device (wlp4s0): Activation: (wifi) connection 'DIRECT-03-moto g pro-PdaNet' has security, and secrets exist.  No new secrets needed.
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8101] Config: added 'ssid' value 'DIRECT-03-moto g pro-PdaNet'
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8101] Config: added 'scan_ssid' value '1'
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8101] Config: added 'bgscan' value 'simple:30:-70:86400'
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8102] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8102] Config: added 'psk' value '<hidden>'
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8500] device (wlp4s0): supplicant interface state: interface_disabled -> inactive
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8500] device (p2p-dev-wlp4s0): supplicant management interface state: interface_disabled -> inactive
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8598] device (wlp4s0): supplicant interface state: inactive -> scanning
Apr 19 09:20:20 ltp NetworkManager[268849]: <info>  [1618842020.8599] device (p2p-dev-wlp4s0): supplicant management interface state: inactive -> scanning
Apr 19 09:20:24 ltp NetworkManager[268849]: <info>  [1618842024.0784] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 09:20:24 ltp NetworkManager[268849]: <info>  [1618842024.0784] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 09:20:24 ltp NetworkManager[268849]: <info>  [1618842024.0822] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 09:20:24 ltp NetworkManager[268849]: <info>  [1618842024.0822] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 09:20:24 ltp NetworkManager[268849]: <info>  [1618842024.1470] device (wlp4s0): supplicant interface state: associating -> completed
Apr 19 09:20:24 ltp NetworkManager[268849]: <info>  [1618842024.1470] device (wlp4s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "DIRECT-03-moto g pro-PdaNet"
Apr 19 09:20:24 ltp NetworkManager[268849]: <info>  [1618842024.1470] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> completed
Apr 19 09:20:24 ltp NetworkManager[268849]: <info>  [1618842024.1482] device (wlp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Apr 19 09:20:24 ltp NetworkManager[268849]: <info>  [1618842024.1486] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 09:20:24 ltp NetworkManager[268849]: <info>  [1618842024.2740] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.49.90
Apr 19 09:20:24 ltp NetworkManager[268849]: <info>  [1618842024.2754] device (wlp4s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Apr 19 09:20:24 ltp NetworkManager[268849]: <info>  [1618842024.2771] device (wlp4s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Apr 19 09:20:24 ltp NetworkManager[268849]: <info>  [1618842024.2773] device (wlp4s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Apr 19 09:20:24 ltp NetworkManager[268849]: <info>  [1618842024.2777] manager: NetworkManager state is now CONNECTED_LOCAL
Apr 19 09:20:24 ltp NetworkManager[268849]: <info>  [1618842024.2791] manager: NetworkManager state is now CONNECTED_SITE
Apr 19 09:20:24 ltp NetworkManager[268849]: <info>  [1618842024.2792] policy: set 'DIRECT-03-moto g pro-PdaNet' (wlp4s0) as default for IPv4 routing and DNS
Apr 19 09:20:24 ltp NetworkManager[268849]: <info>  [1618842024.3304] device (wlp4s0): Activation: successful, device activated.
Apr 19 09:50:24 ltp NetworkManager[268849]: <info>  [1618843824.2491] dhcp4 (wlp4s0): state changed bound -> extended, address=192.168.49.90
Apr 19 10:16:42 ltp NetworkManager[268849]: <info>  [1618845402.2486] dhcp4 (wlp4s0): state changed extended -> extended, address=192.168.49.90
Apr 19 10:19:57 ltp NetworkManager[268849]: <info>  [1618845597.6137] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 19 10:19:57 ltp NetworkManager[268849]: <info>  [1618845597.6138] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Apr 19 10:19:57 ltp NetworkManager[268849]: <info>  [1618845597.6629] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 10:19:57 ltp NetworkManager[268849]: <info>  [1618845597.6629] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 10:20:08 ltp NetworkManager[268849]: <info>  [1618845608.5820] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 10:20:08 ltp NetworkManager[268849]: <info>  [1618845608.5820] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 10:20:08 ltp NetworkManager[268849]: <info>  [1618845608.7208] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 10:20:08 ltp NetworkManager[268849]: <info>  [1618845608.7209] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 10:20:08 ltp NetworkManager[268849]: <info>  [1618845608.7428] device (wlp4s0): supplicant interface state: associating -> 4way_handshake
Apr 19 10:20:08 ltp NetworkManager[268849]: <info>  [1618845608.7429] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> 4way_handshake
Apr 19 10:20:08 ltp NetworkManager[268849]: <info>  [1618845608.7429] device (wlp4s0): DHCPv4 lease renewal requested
Apr 19 10:20:08 ltp NetworkManager[268849]: <info>  [1618845608.7429] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 10:20:08 ltp NetworkManager[268849]: <info>  [1618845608.7429] dhcp4 (wlp4s0): state changed extended -> done
Apr 19 10:20:08 ltp NetworkManager[268849]: <info>  [1618845608.7433] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 10:20:08 ltp NetworkManager[268849]: <info>  [1618845608.8220] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 19 10:20:08 ltp NetworkManager[268849]: <info>  [1618845608.8224] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
Apr 19 10:20:10 ltp NetworkManager[268849]: <info>  [1618845610.9188] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.49.90
Apr 19 10:21:29 ltp NetworkManager[268849]: <info>  [1618845689.2109] caught SIGTERM, shutting down normally.
Apr 19 10:21:29 ltp systemd[1]: Stopping Network Manager...
Apr 19 10:21:29 ltp NetworkManager[268849]: <info>  [1618845689.2121] device (wlp4s0): state change: activated -> deactivating (reason 'unmanaged', sys-iface-state: 'managed')
Apr 19 10:21:29 ltp NetworkManager[268849]: <info>  [1618845689.2123] manager: NetworkManager state is now DISCONNECTING
Apr 19 10:21:29 ltp NetworkManager[268849]: <info>  [1618845689.2226] device (wlp4s0): state change: deactivating -> unmanaged (reason 'removed', sys-iface-state: 'managed')
Apr 19 10:21:29 ltp NetworkManager[268849]: <info>  [1618845689.2414] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 10:21:29 ltp NetworkManager[268849]: <info>  [1618845689.2414] dhcp4 (wlp4s0): state changed bound -> done
Apr 19 10:21:29 ltp NetworkManager[268849]: <info>  [1618845689.3996] manager: NetworkManager state is now DISCONNECTED
Apr 19 10:21:29 ltp NetworkManager[268849]: <info>  [1618845689.4039] device (p2p-dev-wlp4s0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Apr 19 10:21:29 ltp NetworkManager[268849]: <info>  [1618845689.5693] exiting (success)
Apr 19 10:21:29 ltp systemd[1]: NetworkManager.service: Succeeded.
Apr 19 10:21:29 ltp systemd[1]: Stopped Network Manager.
Apr 19 10:21:29 ltp systemd[1]: Starting Network Manager...
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.5901] NetworkManager (version 1.30.2-1) is starting... (after a restart)
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.5901] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
Apr 19 10:21:29 ltp systemd[1]: Started Network Manager.
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.5919] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.5962] manager[0x55f5a5953090]: monitoring kernel firmware directory '/lib/firmware'.
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6515] hostname: hostname: using hostnamed
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6515] hostname: hostname changed from (none) to "ltp"
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6518] dns-mgr[0x55f5a5923110]: init: dns=default,systemd-resolved rc-manager=symlink
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6527] rfkill1: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.1/0000:04:00.0/ieee80211/phy0/rfkill1) (driver iwlwifi)
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6530] manager[0x55f5a5953090]: rfkill: Wi-Fi hardware radio set enabled
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6530] manager[0x55f5a5953090]: rfkill: WWAN hardware radio set enabled
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6562] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.30.2-1/libnm-device-plugin-bluetooth.so)
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6563] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.30.2-1/libnm-device-plugin-wwan.so)
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6608] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.30.2-1/libnm-device-plugin-team.so)
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6611] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.30.2-1/libnm-device-plugin-wifi.so)
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6614] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.30.2-1/libnm-device-plugin-ovs.so)
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6617] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.30.2-1/libnm-device-plugin-adsl.so)
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6621] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6622] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6623] manager: Networking is enabled by state file
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6624] dhcp-init: Using DHCP client 'internal'
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6625] settings: Loaded settings plugin: keyfile (internal)
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6668] device (lo): carrier: link connected
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6670] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6678] manager: (enp0s25): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6685] device (enp0s25): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6699] device (wlp4s0): driver supports Access Point (AP) mode
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6703] manager: (wlp4s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.6710] device (wlp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Apr 19 10:21:29 ltp NetworkManager[301543]: <info>  [1618845689.9236] device (wlp4s0): set-hw-addr: set MAC address to DA:F2:AC:22:0C:46 (scanning)
Apr 19 10:21:30 ltp NetworkManager[301543]: <info>  [1618845690.1713] modem-manager: ModemManager available
Apr 19 10:21:30 ltp NetworkManager[301543]: <info>  [1618845690.1727] agent-manager: agent[e6f8ee09d5f9e374,:1.42/org.freedesktop.nm-applet/1000]: agent registered
Apr 19 10:21:30 ltp NetworkManager[301543]: <info>  [1618845690.1728] ovsdb: Could not connect: No such file or directory
Apr 19 10:21:30 ltp NetworkManager[301543]: <info>  [1618845690.1728] ovsdb: disconnected from ovsdb
Apr 19 10:21:30 ltp NetworkManager[301543]: <info>  [1618845690.2135] device (wlp4s0): supplicant interface state: internal-starting -> disconnected
Apr 19 10:21:30 ltp NetworkManager[301543]: <info>  [1618845690.2136] Wi-Fi P2P device controlled by interface wlp4s0 created
Apr 19 10:21:30 ltp NetworkManager[301543]: <info>  [1618845690.2139] manager: (p2p-dev-wlp4s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Apr 19 10:21:30 ltp NetworkManager[301543]: <info>  [1618845690.2141] device (p2p-dev-wlp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Apr 19 10:21:30 ltp NetworkManager[301543]: <info>  [1618845690.2149] device (wlp4s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Apr 19 10:21:30 ltp NetworkManager[301543]: <info>  [1618845690.2155] device (p2p-dev-wlp4s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Apr 19 10:21:30 ltp NetworkManager[301543]: <warn>  [1618845690.2180] sup-iface[fa26be05cc741e01,5,wlp4s0]: call-p2p-cancel: failed with P2P cancel failed
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3410] policy: auto-activating connection 'DIRECT-03-moto g pro-PdaNet' (07f162b9-05f7-412a-9be3-6c65fbfa71cb)
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3415] device (wlp4s0): Activation: starting connection 'DIRECT-03-moto g pro-PdaNet' (07f162b9-05f7-412a-9be3-6c65fbfa71cb)
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3417] device (wlp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3421] manager: NetworkManager state is now CONNECTING
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3436] device (wlp4s0): set-hw-addr: reset MAC address to 5C:51:4F:F6:B7:DD (preserve)
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3454] device (wlp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3457] device (wlp4s0): Activation: (wifi) access point 'DIRECT-03-moto g pro-PdaNet' has security, but secrets are required.
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3457] device (wlp4s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3459] sup-iface[fa26be05cc741e01,5,wlp4s0]: wps: type pbc start...
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3548] device (wlp4s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3553] device (wlp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3555] device (wlp4s0): Activation: (wifi) connection 'DIRECT-03-moto g pro-PdaNet' has security, and secrets exist.  No new secrets needed.
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3556] Config: added 'ssid' value 'DIRECT-03-moto g pro-PdaNet'
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3556] Config: added 'scan_ssid' value '1'
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3556] Config: added 'bgscan' value 'simple:30:-70:86400'
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3556] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3556] Config: added 'psk' value '<hidden>'
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3997] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 10:21:33 ltp NetworkManager[301543]: <info>  [1618845693.3997] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.1179] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.1180] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.1805] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.1805] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.2104] device (wlp4s0): supplicant interface state: associating -> associated
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.2104] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> associated
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.2157] device (wlp4s0): supplicant interface state: associated -> completed
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.2157] device (wlp4s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "DIRECT-03-moto g pro-PdaNet"
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.2157] device (p2p-dev-wlp4s0): supplicant management interface state: associated -> completed
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.2159] device (wlp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.2165] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.3393] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.49.90
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.3408] device (wlp4s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.3510] device (wlp4s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.3513] device (wlp4s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.3521] manager: NetworkManager state is now CONNECTED_LOCAL
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.3539] manager: NetworkManager state is now CONNECTED_SITE
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.3543] policy: set 'DIRECT-03-moto g pro-PdaNet' (wlp4s0) as default for IPv4 routing and DNS
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.4067] device (wlp4s0): Activation: successful, device activated.
Apr 19 10:21:44 ltp NetworkManager[301543]: <info>  [1618845704.4078] manager: startup complete
Apr 19 10:26:28 ltp NetworkManager[301543]: <info>  [1618845988.3880] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 19 10:26:28 ltp NetworkManager[301543]: <info>  [1618845988.3881] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Apr 19 10:26:28 ltp NetworkManager[301543]: <info>  [1618845988.4464] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 10:26:28 ltp NetworkManager[301543]: <info>  [1618845988.4464] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 10:26:31 ltp NetworkManager[301543]: <info>  [1618845991.3883] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 10:26:31 ltp NetworkManager[301543]: <info>  [1618845991.3884] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 10:26:31 ltp NetworkManager[301543]: <info>  [1618845991.4601] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 10:26:31 ltp NetworkManager[301543]: <info>  [1618845991.4602] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 10:26:31 ltp NetworkManager[301543]: <info>  [1618845991.4985] device (wlp4s0): supplicant interface state: associating -> 4way_handshake
Apr 19 10:26:31 ltp NetworkManager[301543]: <info>  [1618845991.4986] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> 4way_handshake
Apr 19 10:26:31 ltp NetworkManager[301543]: <info>  [1618845991.4986] device (wlp4s0): DHCPv4 lease renewal requested
Apr 19 10:26:31 ltp NetworkManager[301543]: <info>  [1618845991.5274] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 10:26:31 ltp NetworkManager[301543]: <info>  [1618845991.5275] dhcp4 (wlp4s0): state changed bound -> done
Apr 19 10:26:31 ltp NetworkManager[301543]: <info>  [1618845991.5278] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 10:26:31 ltp NetworkManager[301543]: <info>  [1618845991.5286] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 19 10:26:31 ltp NetworkManager[301543]: <info>  [1618845991.5288] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
Apr 19 10:26:31 ltp NetworkManager[301543]: <info>  [1618845991.6682] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.49.90
Apr 19 10:27:04 ltp NetworkManager[301543]: <info>  [1618846024.1537] caught SIGTERM, shutting down normally.
Apr 19 10:27:04 ltp systemd[1]: Stopping Network Manager...
Apr 19 10:27:04 ltp NetworkManager[301543]: <info>  [1618846024.1549] device (wlp4s0): state change: activated -> deactivating (reason 'unmanaged', sys-iface-state: 'managed')
Apr 19 10:27:04 ltp NetworkManager[301543]: <info>  [1618846024.1552] manager: NetworkManager state is now DISCONNECTING
Apr 19 10:27:04 ltp NetworkManager[301543]: <info>  [1618846024.1655] device (wlp4s0): state change: deactivating -> unmanaged (reason 'removed', sys-iface-state: 'managed')
Apr 19 10:27:04 ltp NetworkManager[301543]: <info>  [1618846024.1942] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 10:27:04 ltp NetworkManager[301543]: <info>  [1618846024.1943] dhcp4 (wlp4s0): state changed bound -> done
Apr 19 10:27:04 ltp NetworkManager[301543]: <info>  [1618846024.3153] manager: NetworkManager state is now DISCONNECTED
Apr 19 10:27:04 ltp NetworkManager[301543]: <info>  [1618846024.3180] device (p2p-dev-wlp4s0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Apr 19 10:27:04 ltp NetworkManager[301543]: <info>  [1618846024.4816] exiting (success)
Apr 19 10:27:04 ltp systemd[1]: NetworkManager.service: Succeeded.
Apr 19 10:27:04 ltp systemd[1]: Stopped Network Manager.
Apr 19 10:27:04 ltp systemd[1]: Starting Network Manager...
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5012] NetworkManager (version 1.30.2-1) is starting... (after a restart)
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5012] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
Apr 19 10:27:04 ltp systemd[1]: Started Network Manager.
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5029] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5071] manager[0x5644c265a090]: monitoring kernel firmware directory '/lib/firmware'.
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5616] hostname: hostname: using hostnamed
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5616] hostname: hostname changed from (none) to "ltp"
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5618] dns-mgr[0x5644c262b130]: init: dns=default,systemd-resolved rc-manager=symlink
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5625] rfkill1: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.1/0000:04:00.0/ieee80211/phy0/rfkill1) (driver iwlwifi)
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5627] manager[0x5644c265a090]: rfkill: Wi-Fi hardware radio set enabled
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5628] manager[0x5644c265a090]: rfkill: WWAN hardware radio set enabled
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5655] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.30.2-1/libnm-device-plugin-bluetooth.so)
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5657] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.30.2-1/libnm-device-plugin-wwan.so)
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5697] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.30.2-1/libnm-device-plugin-team.so)
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5699] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.30.2-1/libnm-device-plugin-wifi.so)
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5703] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.30.2-1/libnm-device-plugin-ovs.so)
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5705] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.30.2-1/libnm-device-plugin-adsl.so)
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5708] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5709] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5709] manager: Networking is enabled by state file
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5710] dhcp-init: Using DHCP client 'internal'
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5711] settings: Loaded settings plugin: keyfile (internal)
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5752] device (lo): carrier: link connected
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5754] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5764] manager: (enp0s25): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5771] device (enp0s25): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5785] device (wlp4s0): driver supports Access Point (AP) mode
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5791] manager: (wlp4s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.5800] device (wlp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Apr 19 10:27:04 ltp NetworkManager[302416]: <info>  [1618846024.8352] device (wlp4s0): set-hw-addr: set MAC address to DA:D5:BA:A5:FF:67 (scanning)
Apr 19 10:27:05 ltp NetworkManager[302416]: <info>  [1618846025.0813] modem-manager: ModemManager available
Apr 19 10:27:05 ltp NetworkManager[302416]: <info>  [1618846025.0817] agent-manager: agent[1b1f3627e3012eec,:1.42/org.freedesktop.nm-applet/1000]: agent registered
Apr 19 10:27:05 ltp NetworkManager[302416]: <info>  [1618846025.0828] ovsdb: Could not connect: No such file or directory
Apr 19 10:27:05 ltp NetworkManager[302416]: <info>  [1618846025.0828] ovsdb: disconnected from ovsdb
Apr 19 10:27:05 ltp NetworkManager[302416]: <info>  [1618846025.1274] device (wlp4s0): supplicant interface state: internal-starting -> disconnected
Apr 19 10:27:05 ltp NetworkManager[302416]: <info>  [1618846025.1275] Wi-Fi P2P device controlled by interface wlp4s0 created
Apr 19 10:27:05 ltp NetworkManager[302416]: <info>  [1618846025.1277] manager: (p2p-dev-wlp4s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Apr 19 10:27:05 ltp NetworkManager[302416]: <info>  [1618846025.1280] device (p2p-dev-wlp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Apr 19 10:27:05 ltp NetworkManager[302416]: <info>  [1618846025.1287] device (wlp4s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Apr 19 10:27:05 ltp NetworkManager[302416]: <info>  [1618846025.1293] device (p2p-dev-wlp4s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Apr 19 10:27:05 ltp NetworkManager[302416]: <warn>  [1618846025.1329] sup-iface[4011028244080b8c,6,wlp4s0]: call-p2p-cancel: failed with P2P cancel failed
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3011] policy: auto-activating connection 'DIRECT-03-moto g pro-PdaNet' (07f162b9-05f7-412a-9be3-6c65fbfa71cb)
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3018] device (wlp4s0): Activation: starting connection 'DIRECT-03-moto g pro-PdaNet' (07f162b9-05f7-412a-9be3-6c65fbfa71cb)
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3019] device (wlp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3022] manager: NetworkManager state is now CONNECTING
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3033] device (wlp4s0): set-hw-addr: reset MAC address to 5C:51:4F:F6:B7:DD (preserve)
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3045] device (wlp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3048] device (wlp4s0): Activation: (wifi) access point 'DIRECT-03-moto g pro-PdaNet' has security, but secrets are required.
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3048] device (wlp4s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3050] sup-iface[4011028244080b8c,6,wlp4s0]: wps: type pbc start...
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3160] device (wlp4s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3164] device (wlp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3167] device (wlp4s0): Activation: (wifi) connection 'DIRECT-03-moto g pro-PdaNet' has security, and secrets exist.  No new secrets needed.
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3167] Config: added 'ssid' value 'DIRECT-03-moto g pro-PdaNet'
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3167] Config: added 'scan_ssid' value '1'
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3167] Config: added 'bgscan' value 'simple:30:-70:86400'
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3168] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3168] Config: added 'psk' value '<hidden>'
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3589] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 10:27:08 ltp NetworkManager[302416]: <info>  [1618846028.3589] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.3712] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.3713] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.4264] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.4265] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.4496] device (wlp4s0): supplicant interface state: associating -> 4way_handshake
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.4496] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> 4way_handshake
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.4580] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.4580] device (wlp4s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "DIRECT-03-moto g pro-PdaNet"
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.4580] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.4581] device (wlp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.4585] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.5950] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.49.90
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.5963] device (wlp4s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.5984] device (wlp4s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.5986] device (wlp4s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.5990] manager: NetworkManager state is now CONNECTED_LOCAL
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.6004] manager: NetworkManager state is now CONNECTED_SITE
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.6005] policy: set 'DIRECT-03-moto g pro-PdaNet' (wlp4s0) as default for IPv4 routing and DNS
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.6514] device (wlp4s0): Activation: successful, device activated.
Apr 19 10:27:11 ltp NetworkManager[302416]: <info>  [1618846031.6535] manager: startup complete
Apr 19 10:35:47 ltp NetworkManager[302416]: <info>  [1618846547.8987] audit: op="connection-update" uuid="07f162b9-05f7-412a-9be3-6c65fbfa71cb" name="DIRECT-03-moto g pro-PdaNet" args="802-11-wireless.seen-bssids,connection.timestamp,ipv6.ignore-auto-dns,ipv6.dns,ipv4.ignore-auto-dns,ipv4.dns" pid=303697 uid=1000 result="success"
Apr 19 10:37:16 ltp NetworkManager[302416]: <info>  [1618846636.3467] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 19 10:37:16 ltp NetworkManager[302416]: <info>  [1618846636.3467] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Apr 19 10:37:16 ltp NetworkManager[302416]: <info>  [1618846636.4293] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 10:37:16 ltp NetworkManager[302416]: <info>  [1618846636.4294] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 10:37:19 ltp NetworkManager[302416]: <info>  [1618846639.5053] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 10:37:19 ltp NetworkManager[302416]: <info>  [1618846639.5053] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 10:37:19 ltp NetworkManager[302416]: <info>  [1618846639.5129] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 10:37:19 ltp NetworkManager[302416]: <info>  [1618846639.5130] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 10:37:19 ltp NetworkManager[302416]: <info>  [1618846639.5763] device (wlp4s0): supplicant interface state: associating -> associated
Apr 19 10:37:19 ltp NetworkManager[302416]: <info>  [1618846639.5764] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> associated
Apr 19 10:37:19 ltp NetworkManager[302416]: <info>  [1618846639.5764] device (wlp4s0): DHCPv4 lease renewal requested
Apr 19 10:37:19 ltp NetworkManager[302416]: <info>  [1618846639.6075] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 10:37:19 ltp NetworkManager[302416]: <info>  [1618846639.6075] dhcp4 (wlp4s0): state changed bound -> done
Apr 19 10:37:19 ltp NetworkManager[302416]: <info>  [1618846639.6080] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 10:37:19 ltp NetworkManager[302416]: <info>  [1618846639.6086] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 19 10:37:19 ltp NetworkManager[302416]: <info>  [1618846639.6086] device (p2p-dev-wlp4s0): supplicant management interface state: associated -> 4way_handshake
Apr 19 10:37:19 ltp NetworkManager[302416]: <info>  [1618846639.6087] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 19 10:37:19 ltp NetworkManager[302416]: <info>  [1618846639.6090] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
Apr 19 10:37:19 ltp NetworkManager[302416]: <info>  [1618846639.6943] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.49.90
Apr 19 10:40:36 ltp NetworkManager[302416]: <info>  [1618846836.6600] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 19 10:40:36 ltp NetworkManager[302416]: <info>  [1618846836.6600] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Apr 19 10:40:36 ltp NetworkManager[302416]: <info>  [1618846836.7428] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 10:40:36 ltp NetworkManager[302416]: <info>  [1618846836.7428] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.5960] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.5961] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.6495] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.6495] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.6670] device (wlp4s0): supplicant interface state: associating -> associated
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.6671] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> associated
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.6671] device (wlp4s0): DHCPv4 lease renewal requested
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.6908] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.6909] dhcp4 (wlp4s0): state changed bound -> done
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.6914] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.6923] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.6923] device (p2p-dev-wlp4s0): supplicant management interface state: associated -> 4way_handshake
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.6927] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.6936] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.8751] device (wlp4s0): supplicant interface state: completed -> disconnected
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.8751] device (p2p-dev-wlp4s0): supplicant management interface state: completed -> disconnected
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.9444] device (wlp4s0): supplicant interface state: disconnected -> scanning
Apr 19 10:40:47 ltp NetworkManager[302416]: <info>  [1618846847.9445] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> scanning
Apr 19 10:40:50 ltp NetworkManager[302416]: <info>  [1618846850.8607] device (wlp4s0): supplicant interface state: scanning -> authenticating
Apr 19 10:40:50 ltp NetworkManager[302416]: <info>  [1618846850.8607] device (p2p-dev-wlp4s0): supplicant management interface state: scanning -> authenticating
Apr 19 10:40:50 ltp NetworkManager[302416]: <info>  [1618846850.9209] device (wlp4s0): supplicant interface state: authenticating -> associating
Apr 19 10:40:50 ltp NetworkManager[302416]: <info>  [1618846850.9210] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Apr 19 10:40:50 ltp NetworkManager[302416]: <info>  [1618846850.9418] device (wlp4s0): supplicant interface state: associating -> associated
Apr 19 10:40:50 ltp NetworkManager[302416]: <info>  [1618846850.9418] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> associated
Apr 19 10:40:50 ltp NetworkManager[302416]: <info>  [1618846850.9419] device (wlp4s0): DHCPv4 lease renewal requested
Apr 19 10:40:50 ltp NetworkManager[302416]: <info>  [1618846850.9674] dhcp4 (wlp4s0): canceled DHCP transaction
Apr 19 10:40:50 ltp NetworkManager[302416]: <info>  [1618846850.9675] dhcp4 (wlp4s0): state changed unknown -> done
Apr 19 10:40:50 ltp NetworkManager[302416]: <info>  [1618846850.9678] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 19 10:40:50 ltp NetworkManager[302416]: <info>  [1618846850.9685] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Apr 19 10:40:50 ltp NetworkManager[302416]: <info>  [1618846850.9685] device (p2p-dev-wlp4s0): supplicant management interface state: associated -> 4way_handshake
Apr 19 10:40:50 ltp NetworkManager[302416]: <info>  [1618846850.9686] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Apr 19 10:40:50 ltp NetworkManager[302416]: <info>  [1618846850.9695] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
Apr 19 10:40:51 ltp NetworkManager[302416]: <info>  [1618846851.1139] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.49.90
When I asked this question I thought there would be a way to enter 192.168.49.1:8000 as proxy and be done. I didn’t mean to take so much of anyone’s time, but I thank you for your help. Whenever you’ve had enough, I’ll understand. But as long as you’re willing, I’ll do what you ask. Or if it would be easier to run pdanet yourself I have a way if you shoot me a pm @xabbu . And if you have an Android with data, of course.
I noticed, I was wrong. The client needs to send the URL to the proxy and doesn’t need to have a working DNS.
Connect to the the wifi-direct hotspot. Do nothing else. Open a Terminal and execute just this 4 commands. The http in the https variable is not an error.
export http_proxy='http://192.168.49.1:8000/'
export https_proxy='http://192.168.49.1:8000/'
echo $https_proxy
wget https://raw.githubusercontent.com/arkansawdave74/andronix/master/repofixfix.sh
Ok I will reboot to clear everything, and My DNS is still default
Hahaha!!!
[user@ltp ~]$ export http_proxy='http://192.168.49.1:8000/'
[user@ltp ~]$ export https_proxy='http://192.168.49.1:8000/'
[user@ltp ~]$ echo $https_proxy
[user@ltp ~]$ wget https://raw.githubusercontent.com/arkansawdave74/andronix/master/repofixfix.sh
--2021-04-19 12:00:11--  https://raw.githubusercontent.com/arkansawdave74/andronix/master/repofixfix.sh
Loaded CA certificate '/etc/ssl/certs/ca-certificates.crt'
Connecting to 192.168.49.1:8000... connected.
Proxy request sent, awaiting response... 200 OK
Length: 930 [text/plain]
Saving to: ‘repofixfix.sh’
repofixfix.sh                                           100%[==============================================================================================================================>]     930  --.-KB/s    in 0s
2021-04-19 12:00:12 (24.4 MB/s) - ‘repofixfix.sh’ saved [930/930]
[user@ltp ~]$
Pacman fails, which I expected. I will read the link up there on that.
[user@ltp vendetta]$ sudo -E pacman -Syy
[sudo] password for user:
 core        166.0 KiB   254 KiB/s 00:01 [##################################################################################] 100%
 extra        1961.0 KiB   494 KiB/s 00:04 [##################################################################################] 100%
 community        6.6 MiB   530 KiB/s 00:13 [##################################################################################] 100%
 multilib        179.5 KiB   372 KiB/s 00:00 [##################################################################################] 100%
:laughing: :laughing: :laughing:
And is there any chance you could link me to instructions for configuring GUIs for using the proxy? I’m not sure how I would DDG that…
Actually, I may have it…I will do some reading…Thank you so much @xabbu . I have been wishing for this for years!!
https://duckduckgo.com/?t=ffab&q=arch+linux+configure+GUI+programs+to+use+proxy&ia=web
And let me know as soon as you’re done making us an opensource PdaNet!! :wink:
Just kidding…
Unfortunately you probably have to do it for every GUI application you want to use.
On the terminal, make sure you set and export the two variables. Always use the echo command the check if they are set.
The profile script from the Arch Wiki is nice, but it seems it didn’t worked for you.
That’s okay…I only use a handful of GUIs. I haven’t figured out yay but pamac (idk about pamac gui yet) is working and I just updated my system including stuff from AUR. I found that chrome works automatically if I launch it from a terminal, but not from a launcher, not even an edited launcher (other GUIs don’t seem to do that) and I haven’t found info on configuring the GUIs to use the proxy environment yet, like Kodi. And I’m dying to get kodi working.
Pamac gui is working straight from the launcher.
Nevermind about Kodi. It works just by launching it from a terminal!! I’m so excited. I can’t thank you enough, @xabbu !!
Configuring Kodi now…
Figured I should correct something I said up there. I guess pamac didn’t update my AUR packages. It’s having trouble reaching aur in both the cli and the gui.
[user@ltp ~]$ pamac search gkrellm
** (pamac:67889): WARNING **: 16:45:34.393: aur.vala:60: Error resolving “aur.archlinux.org”: Name or service not known
Failed to query https://aur.archlinux.org/rpc/?v=5&type=info&arg[]=gkrellm-nvidia&arg[]=gkrellm-themes from AUR
** (pamac:67889): WARNING **: 16:45:34.402: aur.vala:60: Error resolving “aur.archlinux.org”: Name or service not known
Failed to query https://aur.archlinux.org/rpc/?v=5&type=search&arg=gkrellm from AUR
gkrellm-themes                                                              [Installed] 20030109-1
    Themes from muhri.net for GKrellM
gkrellm-nvidia                                                    [user@ltp ~]$ pamac search gkrellm
gkrellm-nvidia                                                              [Installed] 1.0-1
    A plugin for gkrellm2 which displays nVidia GPU status
gkrellm        [Installed] 2.3.11-2    community
    System monitor package for GTK2          [Installed] 1.0-1
Resolve error. I’ll try setting cloudflare DNS and see what happens. After this movie…lol.
EDIT: After looking at /etc/resolv.conf and seeing only the proxy address 192.168.49.1, I decided not to change the DNS in manjaro. Instead, I fixed it by changing my DNS in Android to Cloudflare. For me, being rooted, I just installed the Cloudfare and Cloudflare ipv6 Magisk Modules. Now pamac cli is connecting to AUR. Yay can now search AUR with -Ss but yay -Syu won’t refresh databases. The pamac gui still cannot access AUR nor refresh databases, so it’s only good for searching official repos and won’t install anything, but that’s fine with me.
I learned a lot in this thread.
