Hi,
Running Manjaro KDE fully updated on the “Testing” branch.
My new desktop is as follows:
- Desktop Code Name: “Megatron”
- Desktop Class: Mid-Range
- Build Date: June 11th, 2022
- Genuine Manjaro KDE 64Bit Linux OS
- Silverstone Tek ATX Mid Tower Case
- EVGA Supernova 650 GT 80 Plus Gold 650W Power Supply
- ASUS AM4 TUF Gaming X570-Plus (Wi-Fi) Motherboard
- AMD Ryzen 7 5800X 4.7GHz 8-Core CPU
- Noctua NH-U12S chromax.Black 120mm CPU Cooler
- Corsair Vengeance LPX 32GB (2X16GB) DDR4 3200 RAM Memory
- MSI Gaming nVidia GeForce RTX 3060 12GB GDDR6 OC GPU
- SAMSUNG 980 PRO 2TB PCIe NVMe Gen 4 M.2 Drive
- Seagate FireCuda 4TB 3.5 Inch Hard Drive
Running below network adapter:
Network adapter works fine under Linux.
Only issue is the status lights are not working?
All I see is red?
Any ideas?
Thanks!
Jesse
~ > inxi -Fazy
Kernel: 5.18.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=c7377da2-42c0-45e0-8f7f-24fa640cb365 rw quiet
cryptdevice=UUID=440db0cd-b663-44ee-ab79-06933f85b48c:luks-440db0cd-b663-44ee-ab79-06933f85b48c
root=/dev/mapper/luks-440db0cd-b663-44ee-ab79-06933f85b48c apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4403
date: 04/27/2022
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 gen: 4
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x21 (33)
stepping: 2 microcode: 0xA20120A
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3778 high: 4632 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4375 2: 3430
3: 3505 4: 4632 5: 3621 6: 4197 7: 3207 8: 3390 9: 3751 10: 3146 11: 4553
12: 4502 13: 3347 14: 3880 15: 3965 16: 2949 bogomips: 121659
STIBP: always-on, RSB filling
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate]
vendor: Micro-Star MSI driver: nvidia v: 515.48.07
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 0a:00.0 chip-ID: 10de:2504 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.87x11.85")
s-diag: 610mm (24")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
v: 4.6.0 NVIDIA 515.48.07 direct render: Yes
Device-1: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 10de:228e
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.18.6-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp5s0 state: down mac: <filter>
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 3-5:2 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 5.46 TiB used: 708.27 GiB (12.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DX005-3GH101
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: FC01 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 708.27 GiB (38.7%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-440db0cd-b663-44ee-ab79-06933f85b48c
used: 440 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 35.5 C mobo: 38.0 C gpu: nvidia temp: 43 C
Fan Speeds (RPM): fan-1: 0 fan-2: 799 fan-3: 0 fan-4: 0 fan-5: 2561
fan-6: 0 fan-7: 1370 gpu: nvidia fan: 0%
Processes: 423 Uptime: 13h 56m wakeups: 0 Memory: 31.26 GiB
used: 7.05 GiB (22.6%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1619
pacman: 1599 lib: 448 flatpak: 13 snap: 7 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.19
