Hi Everyone, thanks in advance for you help and suggestions.
I’ve been running my kvm/qemu virtual machine with an RTX 2080 and a VIA USB 3.0 PCIe controller passed through to Windows 10 for quite some time, but have never been able to get a USB audio device to work with it.
If I select the USB device in Discord, then the whole USB controller stops working until I reboot the host. If I only use a headset as an output device, then it may work for a minute or so, then go all distorted and cause issues in the VM where apps will freeze while it disconnects/connects itself. I’ve tried an Astro A50, a regular audio device with optical output and an Astro A20. The VM behaves the same way for all of them.
Note however, I have a 2.4 GHz wireless adapter, Bluetooth 4.0 and a Serial device all plugged into the USB 3.0 card and they’re working fine.
Google hasn’t offered much success in finding anyone who’s had an issue similar to this so I’m not sure where to begin with troubleshooting.
At this point I’m not sure whate other information I can provide, please let me know if you need to know more.
$ inxi -Fxxxza
System: Kernel: 5.7.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=5c61a5ac-597b-4b5d-9654-fd152c97f14a rw pcie_aspm=off
vfio-pci.ids=8086:1901,1106:3483,10de:1f02,10de:10f9,10de:1ada,10de:1adb,10de:1e82,10de:10f8,10de:1ad8,10de:1ad9
iommu=pt intel_iommu=on quiet apparmor=1 security=apparmor udev.log_priority=3 hugepages=8192
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Desktop System: Gigabyte product: Z370 HD3 v: N/A serial: <filter>
Mobo: Gigabyte model: Z370 HD3-CF v: x.x serial: <filter> UEFI: American Megatrends v: F14b date: 11/28/2019
CPU: Info: 6-Core model: Intel Core i5-9600KF bits: 64 type: MCP arch: Kaby Lake family: 6 model-id: 9E (158)
stepping: C (12) microcode: D6 L2 cache: 9216 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44412
Speed: 4600 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 4600 2: 4594 3: 4264 4: 4600 5: 4600 6: 4600
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Graphics: Device-1: NVIDIA TU104 [GeForce RTX 2080] vendor: ASUSTeK driver: vfio-pci v: 0.2
alternate: nouveau,nvidia_drm,nvidia bus ID: 01:00.0 chip ID: 10de:1e82
Device-2: NVIDIA GP108 [GeForce GT 1030] vendor: Micro-Star MSI driver: nvidia v: 440.100
alternate: nouveau,nvidia_drm bus ID: 08:00.0 chip ID: 10de:1d01
Display: x11 server: X.Org 1.20.9 driver: nvidia display ID: :0.0 screens: 1
Screen-1: 0 s-res: 6400x2160 s-dpi: 96 s-size: 1693x572mm (66.7x22.5") s-diag: 1787mm (70.4")
Monitor-1: DP-0 res: 3840x2160 hz: 60 dpi: 161 size: 607x345mm (23.9x13.6") diag: 698mm (27.5")
Monitor-2: HDMI-0 res: 2560x1440 hz: 144 dpi: 109 size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: GeForce GT 1030/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100 direct render: Yes
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a2f0
Device-2: NVIDIA TU104 HD Audio vendor: ASUSTeK driver: vfio-pci v: 0.2 alternate: snd_hda_intel bus ID: 01:00.1
chip ID: 10de:10f8
Device-3: NVIDIA GP108 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 08:00.1
chip ID: 10de:0fb8
Device-4: Astro Gaming Astro A50 type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-3:2
chip ID: 9886:002c
Sound Server: ALSA v: k5.7.19-2-MANJARO
Network: Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: 3.2.6-k port: f000 bus ID: 00:1f.6
chip ID: 8086:15b8
IF-ID-1: macvtap0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 5.09 TiB used: 2.20 TiB (43.3%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SX8200NP size: 447.13 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: SVN139B scheme: GPT
ID-2: /dev/nvme1n1 vendor: Corsair model: Force MP500 size: 111.79 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: E7FM04.C scheme: GPT
ID-3: /dev/sda vendor: Western Digital model: WD40EFRX-68WT0N0 size: 3.64 TiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0A82 scheme: GPT
ID-4: /dev/sdb vendor: Western Digital model: WDS100T2B0A-00SM50 size: 931.51 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 00WD scheme: GPT
Partition: ID-1: / raw size: 111.49 GiB size: 109.24 GiB (97.98%) used: 54.28 GiB (49.7%) fs: ext4 dev: /dev/nvme1n1p2
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 53.0 C mobo: 16.8 C gpu: nvidia temp: 59 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 45%
Info: Processes: 238 Uptime: 25m Memory: 31.37 GiB used: 21.04 GiB (67.1%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1337 lib: 426 flatpak: 0 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.08
IOMMU groups
IOMMU Group 0:
00:00.0 Host bridge [0600]: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers [8086:3ec2] (rev 0a)
IOMMU Group 1:
00:01.0 PCI bridge [0604]: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) [8086:1901] (rev 0a)
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation TU104 [GeForce RTX 2080] [10de:1e82] (rev a1)
01:00.1 Audio device [0403]: NVIDIA Corporation TU104 HD Audio Controller [10de:10f8] (rev a1)
01:00.2 USB controller [0c03]: NVIDIA Corporation TU104 USB 3.1 Host Controller [10de:1ad8] (rev a1)
01:00.3 Serial bus controller [0c80]: NVIDIA Corporation TU104 USB Type-C UCSI Controller [10de:1ad9] (rev a1)
IOMMU Group 10:
00:1c.0 PCI bridge [0604]: Intel Corporation 200 Series PCH PCI Express Root Port #1 [8086:a290] (rev f0)
IOMMU Group 11:
00:1c.2 PCI bridge [0604]: Intel Corporation 200 Series PCH PCI Express Root Port #3 [8086:a292] (rev f0)
IOMMU Group 12:
00:1c.4 PCI bridge [0604]: Intel Corporation 200 Series PCH PCI Express Root Port #5 [8086:a294] (rev f0)
IOMMU Group 13:
00:1d.0 PCI bridge [0604]: Intel Corporation 200 Series PCH PCI Express Root Port #9 [8086:a298] (rev f0)
IOMMU Group 14:
00:1f.0 ISA bridge [0601]: Intel Corporation Z370 Chipset LPC/eSPI Controller [8086:a2c9]
00:1f.2 Memory controller [0580]: Intel Corporation 200 Series/Z370 Chipset Family Power Management Controller [8086:a2a1]
00:1f.3 Audio device [0403]: Intel Corporation 200 Series PCH HD Audio [8086:a2f0]
00:1f.4 SMBus [0c05]: Intel Corporation 200 Series/Z370 Chipset Family SMBus Controller [8086:a2a3]
IOMMU Group 15:
00:1f.6 Ethernet controller [0200]: Intel Corporation Ethernet Connection (2) I219-V [8086:15b8]
IOMMU Group 16:
03:00.0 USB controller [0c03]: VIA Technologies, Inc. VL805 USB 3.0 Host Controller [1106:3483] (rev 01)
IOMMU Group 17:
05:00.0 Non-Volatile memory controller [0108]: Silicon Motion, Inc. SM2262/SM2262EN SSD Controller [126f:2262] (rev 03)
IOMMU Group 18:
08:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP108 [GeForce GT 1030] [10de:1d01] (rev a1)
08:00.1 Audio device [0403]: NVIDIA Corporation GP108 High Definition Audio Controller [10de:0fb8] (rev a1)
IOMMU Group 19:
09:00.0 Non-Volatile memory controller [0108]: Phison Electronics Corporation E7 NVMe Controller [1987:5007] (rev 01)
IOMMU Group 2:
00:08.0 System peripheral [0880]: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model [8086:1911]
IOMMU Group 3:
00:14.0 USB controller [0c03]: Intel Corporation 200 Series/Z370 Chipset Family USB 3.0 xHCI Controller [8086:a2af]
IOMMU Group 4:
00:16.0 Communication controller [0780]: Intel Corporation 200 Series PCH CSME HECI #1 [8086:a2ba]
IOMMU Group 5:
00:17.0 SATA controller [0106]: Intel Corporation 200 Series PCH SATA controller [AHCI mode] [8086:a282]
IOMMU Group 6:
00:1b.0 PCI bridge [0604]: Intel Corporation 200 Series PCH PCI Express Root Port #17 [8086:a2e7] (rev f0)
IOMMU Group 7:
00:1b.2 PCI bridge [0604]: Intel Corporation 200 Series PCH PCI Express Root Port #19 [8086:a2e9] (rev f0)
IOMMU Group 8:
00:1b.3 PCI bridge [0604]: Intel Corporation 200 Series PCH PCI Express Root Port #20 [8086:a2ea] (rev f0)
IOMMU Group 9:
00:1b.4 PCI bridge [0604]: Intel Corporation 200 Series PCH PCI Express Root Port #21 [8086:a2eb] (rev f0)
Win10 XML
<domain xmlns:qemu="http://libvirt.org/schemas/domain/qemu/1.0" type="kvm">
<name>win10</name>
<uuid>6ebb92e7-bde3-4176-aa69-555550c723f1</uuid>
<metadata>
<libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
<libosinfo:os id="http://microsoft.com/win/10"/>
</libosinfo:libosinfo>
</metadata>
<memory unit="KiB">16777216</memory>
<currentMemory unit="KiB">16777216</currentMemory>
<memoryBacking>
<hugepages/>
</memoryBacking>
<vcpu placement="static">4</vcpu>
<os>
<type arch="x86_64" machine="pc-q35-5.0">hvm</type>
<loader readonly="yes" type="pflash">/usr/share/edk2-ovmf/x64/OVMF_CODE.fd</loader>
<nvram>/var/lib/libvirt/qemu/nvram/win10_VARS.fd</nvram>
<bootmenu enable="no"/>
</os>
<features>
<acpi/>
<apic/>
<hyperv>
<relaxed state="on"/>
<vapic state="on"/>
<spinlocks state="on" retries="8191"/>
<vendor_id state="on" value="123456789ab"/>
</hyperv>
<kvm>
<hidden state="on"/>
</kvm>
<vmport state="off"/>
<ioapic driver="kvm"/>
</features>
<cpu mode="host-passthrough" check="partial" migratable="on">
<topology sockets="1" dies="1" cores="4" threads="1"/>
</cpu>
<clock offset="localtime">
<timer name="hpet" present="yes"/>
<timer name="hypervclock" present="yes"/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled="no"/>
<suspend-to-disk enabled="no"/>
</pm>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<disk type="block" device="disk">
<driver name="qemu" type="raw" cache="none" io="native"/>
<source dev="/dev/sdb"/>
<target dev="vdd" bus="virtio"/>
<address type="pci" domain="0x0000" bus="0x07" slot="0x00" function="0x0"/>
</disk>
<source dev="/dev/nvme0n1"/>
<target dev="vde" bus="virtio"/>
<boot order="1"/>
<address type="pci" domain="0x0000" bus="0x08" slot="0x00" function="0x0"/>
</disk>
<disk type="file" device="cdrom">
<driver name="qemu" type="raw" cache="none"/>
<source file="/home/csthomas/Downloads/virtio-win-0.1.171.iso"/>
<target dev="sda" bus="sata"/>
<readonly/>
<address type="drive" controller="0" bus="0" target="0" unit="0"/>
</disk>
<controller type="usb" index="0" model="qemu-xhci" ports="15">
<address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
</controller>
<controller type="sata" index="0">
<address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
</controller>
<controller type="pci" index="0" model="pcie-root"/>
<controller type="pci" index="1" model="pcie-root-port">
<model name="pcie-root-port"/>
<target chassis="1" port="0x10"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="2" model="pcie-root-port">
<target chassis="2" port="0x11"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/>
</controller>
<controller type="pci" index="3" model="pcie-root-port">
<target chassis="3" port="0x12"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/>
</controller>
<controller type="pci" index="4" model="pcie-root-port">
<target chassis="4" port="0x13"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/>
</controller>
<controller type="pci" index="5" model="pcie-root-port">
<target chassis="5" port="0x14"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/>
</controller>
<controller type="pci" index="6" model="pcie-root-port">
<target chassis="6" port="0x15"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x5"/>
</controller>
<controller type="pci" index="7" model="pcie-root-port">
<target chassis="7" port="0x16"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x6"/>
</controller>
<controller type="pci" index="8" model="pcie-root-port">
<target chassis="8" port="0x17"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x7"/>
</controller>
<controller type="pci" index="9" model="pcie-root-port">
<target chassis="9" port="0x18"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="10" model="pcie-root-port">
<target chassis="10" port="0x19"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x1"/>
</controller>
<controller type="pci" index="11" model="pcie-root-port">
<target chassis="11" port="0x1a"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x2"/>
</controller>
<controller type="pci" index="12" model="pcie-to-pci-bridge">
<model name="pcie-pci-bridge"/>
<address type="pci" domain="0x0000" bus="0x0b" slot="0x00" function="0x0"/>
</controller>
<controller type="pci" index="13" model="pcie-root-port">
<target chassis="13" port="0x1b"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x3"/>
</controller>
<controller type="pci" index="14" model="pcie-root-port">
<target chassis="14" port="0x1c"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x4"/>
</controller>
<controller type="pci" index="15" model="pcie-root-port">
<target chassis="15" port="0x1d"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x5"/>
</controller>
<controller type="virtio-serial" index="0">
<address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
</controller>
<controller type="scsi" index="0" model="virtio-scsi">
<address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/>
</controller>
<interface type="direct">
<mac address="52:54:00:0c:9b:c3"/>
<source dev="eno1" mode="bridge"/>
<model type="virtio"/>
<address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
</interface>
<serial type="pty">
<target type="isa-serial" port="0">
<model name="isa-serial"/>
</target>
</serial>
<console type="pty">
<target type="serial" port="0"/>
</console>
<channel type="spicevmc">
<target type="virtio" name="com.redhat.spice.0"/>
<address type="virtio-serial" controller="0" bus="0" port="2"/>
</channel>
<input type="mouse" bus="virtio">
<address type="pci" domain="0x0000" bus="0x00" slot="0x0e" function="0x0"/>
</input>
<input type="keyboard" bus="virtio">
<address type="pci" domain="0x0000" bus="0x00" slot="0x0f" function="0x0"/>
</input>
<input type="mouse" bus="ps2"/>
<input type="keyboard" bus="ps2"/>
<address type="pci" domain="0x0000" bus="0x0d" slot="0x00" function="0x0"/>
</input>
<graphics type="spice" autoport="yes">
<listen type="address"/>
<image compression="off"/>
</graphics>
<video>
<model type="qxl" ram="65536" vram="65536" vgamem="16384" heads="1" primary="yes"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0"/>
</video>
<hostdev mode="subsystem" type="pci" managed="yes">
<source>
<address domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
</source>
<address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
</source>
<address type="pci" domain="0x0000" bus="0x09" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x01" slot="0x00" function="0x1"/>
</source>
<address type="pci" domain="0x0000" bus="0x0a" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x01" slot="0x00" function="0x2"/>
</source>
<address type="pci" domain="0x0000" bus="0x0e" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x01" slot="0x00" function="0x3"/>
</source>
<address type="pci" domain="0x0000" bus="0x0f" slot="0x00" function="0x0"/>
</hostdev>
<redirdev bus="usb" type="spicevmc">
<address type="usb" bus="0" port="2"/>
</redirdev>
<address type="usb" bus="0" port="3"/>
</redirdev>
<memballoon model="virtio">
<address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
</memballoon>
<shmem name="looking-glass">
<model type="ivshmem-plain"/>
<size unit="M">64</size>
<address type="pci" domain="0x0000" bus="0x0c" slot="0x01" function="0x0"/>
</shmem>
</devices>
<qemu:commandline>
<qemu:arg value="-object"/>
<qemu:arg value="input-linux,id=mouse1,evdev=/dev/input/by-id/usb-Razer_Razer_Basilisk-event-mouse"/>
<qemu:arg value="input-linux,id=kbd1,evdev=/dev/input/by-id/usb-Corsair_Corsair_Gaming_K70_LUX_RGB_Keyboard_08023035AF08984958B76A27F5001941-if01-event-kbd,grab_all=on,repeat=on"/>
</qemu:commandline>
</domain>
