After installing Manjaro this week I’ve been stuck with this problem. My machine refuses to use it’s graphics card correctly, only uses it’s base Intel GPU and overuses my I5 to compensate.
When only using the browser and other light applications it is fine, but when trying to use some heavier programs like an substitute for AutoCAD, it barely moves, lags heavily and crashes.
I need my PC to use it’s dedicated GPU.
On the configurations and terminal it recognizes the card, but when using $ lspci -k | grep -A 2 -E “(VGA|3D)” to see what is in use it only shows Intel.
It is not a problem of switching the units since it doesn’t switch and its creating a huge bottleneck on my system.
Let me know if any more information on process is needed.
I really need help solving this, my PC was working very fine until it didn’t no more.
Bloco de Citação
Kernel: 5.4.178-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=2a09f9b0-a5b4-407c-8bcc-3c46cbab41cb rw quiet apparmor=1
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 80GA v: Lenovo G40-70
serial: Chassis: type: 10 v: Lenovo G40-70
serial:
Mobo: LENOVO model: Lancer 4A2 v: SDK0E50515STD
serial: UEFI: LENOVO v: 9ACN32WW date: 07/20/2015
ID-1: BAT0 charge: 0.3 Wh (100.0%) condition: 0.3/31.7 Wh (1.0%)
volts: 16.4 min: 14.4 model: Lenovo IdeaPad type: Unknown serial:
status: Full
Info: model: Intel Core i5-4200U bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2191 high: 2381 min/max: 800/2600 scaling:
driver: intel_pstate governor: powersave cores: 1: 2084 2: 2180 3: 2122
4: 2381 bogomips: 18361
Type: itlb_multihit status: KVM: Vulnerable
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
Device-2: AMD Sun LE [Radeon HD 8550M / R5 M230] vendor: Lenovo
driver: amdgpu v: kernel alternate: radeon bus-ID: 03:00.0
chip-ID: 1002:666f class-ID: 0380
Device-3: Acer Lenovo EasyCamera type: USB driver: uvcvideo bus-ID: 1-6:5
chip-ID: 5986:0652 class-ID: 0e02 serial:
Display: x11 server: Xorg 1.21.1.3 compositor: kwin_x11 driver:
loaded: amdgpu,ati,modesetting alternate: fbdev,vesa
IF: wlp2s0 state: up mac:
type: SSD serial: rev: K1B3 scheme: GPT
