Basically, every time PC boots, I have to go to bios and manually change TPM setting from firmware to discrete or PC won’t boot.
This happened after I swapped mobo, cpu and ram.
Found similar case, but without answer: Question - Windows won't boot unless change "Firmware TPM" to "Discrete TPM" in the BIOS ? | Tom's Hardware Forum
What do I do so my pc would start without me going through bios and changing TPM setting?
The problem is, it resets back to firmware on every boot, so i have to change it.
Are you sure you did
andreas85:
save configuration
…this? Because, this:
…doesn’t quite sound like it…
Yes, I’m sure. Things like xmp and OC settings wouldn’t even be present if I didn’t save changes before exit.
Kobold
2 February 2024 10:57
6
I personally would disable Secureboot/TPM and install win10 that won’t require TPM, problem solved. Optionally use rufus and create a new usb stick for win11 to install it without TPM.
Never forget your free Anaconda after you landet on Hutton Orbital
o7 cmrd
There is several topics around the web on how to bypass windows 11 requirements
disable windows%2011 tpm requirement - sx.nix.dk
Problem solved by purely updating bios.
system
Closed
18 March 2024 22:39
9
