Hi
Updated my pc and now int wont boot. Kernel is 5.19.17-2 and I have a GTX 1060 card. Updated a couple of days ago and left my computer. Tried to boot it today and now its stuck at Finished TLP system startup/shutdown. Any tip on how I can fix it?
5.19 is end of life.
Can you access a TTY and install an supported kerne (like 5.15 or 6.1).
I can access a TTY. How do I install a supported kernel? Only done it in gui…
Did some reading and tried sudo mhwd-kernel -i linux515. Rebooted but still stuck at the same place. Confirmed with uname -r that I’m on 5.15.89-1.
rerun update from tty:
sudo pacman -Syyu
any errors?
Starting full system upgrade
warning: sndio: local (20180120-1) is newer than community (1.9.0-1)
there is nothing to do
what de are you running? kde/gnome/xfce?
and can you provide output from:
mhwd -l -li
probably booting into manjaro live usb - chrooting - and providing output from there would be better, we probably will need logs …
i knew it… run this:
startxfce4
and post output from it
ok, post pic of:
cat /var/log/Xorg.0.log
and:
find /etc/X11/ -name "*.conf"
and:
systemctl start lightdm.service
you can delete the first 3 pictures from the xorg log, we need only the last one, where it says, that the nvidia modules failed to load…
uninstall the 5.19 kernel:
sudo mhwd-kernel -r linux519
uninstall nvidia:
sudo mhwd -r pci video-nvidia
install it again:
sudo mhwd -a pci nonfree 0300
reboot, and see if it helped
Will try it tomorrow. Going to bed now
Thanks for you’re help so far
It worked
Thanks a lot for you’re help
