PC will no longer boot after following interrupted upgrade/update instructions
post output of all of these commands:
manjaro-chroot -a
mhwd-kernel -li
and the install grub and the pacman -Syyu were without errors?
I ran them all again.
This is the output. I just copied and pasted it
[manjaro@manjaro-cinnamon ~]$ manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdb1.  Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sda5]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
 --> mount: [/mnt/home]
 --> mount: [/mnt/WINDOWS]
The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Falling back to read-only mount because the NTFS partition is in an
unsafe state. Please resume and shutdown Windows fully (no hibernation
or fast restarting.)
Could not mount read-write, trying read-only
[manjaro-cinnamon /]# mhwd-kernel -li
Currently running: 6.1.1-1-MANJARO (linux61)
   * linux414
   * linux59
[manjaro-cinnamon /]# pacman-mirrors -f 5 & pacman -Syyu
[1] 12
error: failed retrieving file 'core.db' from ftp.snt.utwente.nl : Could not resolve host: ftp.snt.utwente.nl
error: failed retrieving file 'core.db' from ba.mirror.garr.it : Could not resolve host: ba.mirror.garr.it
error: failed retrieving file 'core.db' from mirror.2degrees.nz : Could not resolve host: mirror.2degrees.nz
error: failed retrieving file 'core.db' from mirror.math.princeton.edu : Could not resolve host: mirror.math.princeton.edu
error: failed retrieving file 'core.db' from manjaro.kyberorg.fi : Could not resolve host: manjaro.kyberorg.fi
error: failed retrieving file 'core.db' from manjaro.ipacct.com : Could not resolve host: manjaro.ipacct.com
error: failed retrieving file 'core.db' from ziply.mm.fcix.net : Could not resolve host: ziply.mm.fcix.net
error: failed retrieving file 'core.db' from mirror.albony.xyz : Could not resolve host: mirror.albony.xyz
error: failed retrieving file 'core.db' from mirror.tarnkappe.info : Could not resolve host: mirror.tarnkappe.info
error: failed retrieving file 'core.db' from repo.ialab.dsu.edu : Could not resolve host: repo.ialab.dsu.edu
error: failed retrieving file 'core.db' from manjaro.dcc.uchile.cl : Could not resolve host: manjaro.dcc.uchile.cl
error: failed retrieving file 'core.db' from mirror.truenetwork.ru : Could not resolve host: mirror.truenetwork.ru
error: failed retrieving file 'core.db' from coresite.mm.fcix.net : Could not resolve host: coresite.mm.fcix.net
error: failed retrieving file 'core.db' from mirrors.tuna.tsinghua.edu.cn : Could not resolve host: mirrors.tuna.tsinghua.edu.cn
error: failed retrieving file 'core.db' from mirrors.sjtug.sjtu.edu.cn : Could not resolve host: mirrors.sjtug.sjtu.edu.cn
error: failed retrieving file 'core.db' from ftp.belnet.be : Could not resolve host: ftp.belnet.be
error: failed retrieving file 'core.db' from ftpmirror1.infania.net : Could not resolve host: ftpmirror1.infania.net
error: failed retrieving file 'core.db' from mirror.netcologne.de : Could not resolve host: mirror.netcologne.de
error: failed retrieving file 'core.db' from manjaro.mirror.liquidtelecom.com : Could not resolve host: manjaro.mirror.liquidtelecom.com
error: failed retrieving file 'core.db' from ftp.nluug.nl : Could not resolve host: ftp.nluug.nl
error: failed retrieving file 'core.db' from ftp.tu-chemnitz.de : Could not resolve host: ftp.tu-chemnitz.de
error: failed retrieving file 'core.db' from ftp.psnc.pl : Could not resolve host: ftp.psnc.pl
error: failed retrieving file 'core.db' from download.nus.edu.sg : Could not resolve host: download.nus.edu.sg
error: failed retrieving file 'core.db' from ftp.riken.jp : Could not resolve host: ftp.riken.jp
error: failed retrieving file 'core.db' from ftp.halifax.rwth-aachen.de : Could not resolve host: ftp.halifax.rwth-aachen.de
error: failed retrieving file 'core.db' from fastmirror.pp.ua : Could not resolve host: fastmirror.pp.ua
error: failed retrieving file 'core.db' from muug.ca : Could not resolve host: muug.ca
error: failed retrieving file 'core.db' from mirrors.nic.cz : Could not resolve host: mirrors.nic.cz
error: failed retrieving file 'core.db' from manjaro.mirrors.lavatech.top : Could not resolve host: manjaro.mirrors.lavatech.top
error: failed retrieving file 'core.db' from mirrors.ucr.ac.cr : Could not resolve host: mirrors.ucr.ac.cr
error: failed retrieving file 'core.db' from repo.skni.umcs.pl : Could not resolve host: repo.skni.umcs.pl
error: failed retrieving file 'core.db' from mirrors.huaweicloud.com : Could not resolve host: mirrors.huaweicloud.com
error: failed retrieving file 'core.db' from uvermont.mm.fcix.net : Could not resolve host: uvermont.mm.fcix.net
error: failed retrieving file 'core.db' from mirror.moson.org : Could not resolve host: mirror.moson.org
error: failed retrieving file 'core.db' from mirrors.manjaro.org : Could not resolve host: mirrors.manjaro.org
error: failed retrieving file 'core.db' from manjaro.osmir.ch : Could not resolve host: manjaro.osmir.ch
error: failed retrieving file 'core.db' from mirror.easyname.at : Could not resolve host: mirror.easyname.at
error: failed retrieving file 'core.db' from mirror.xenyth.net : Could not resolve host: mirror.xenyth.net
error: failed retrieving file 'core.db' from mirror.fcix.net : Could not resolve host: mirror.fcix.net
error: failed retrieving file 'core.db' from ftp.gwdg.de : Could not resolve host: ftp.gwdg.de
error: failed retrieving file 'core.db' from ftp.cc.uoc.gr : Could not resolve host: ftp.cc.uoc.gr
error: failed retrieving file 'core.db' from manjaro.c3sl.ufpr.br : Could not resolve host: manjaro.c3sl.ufpr.br
error: failed retrieving file 'core.db' from mirror.terrahost.no : Could not resolve host: mirror.terrahost.no
error: failed retrieving file 'core.db' from mirrors.gethosted.online : Could not resolve host: mirrors.gethosted.online
error: failed retrieving file 'core.db' from mirror.xeonbd.com : Could not resolve host: mirror.xeonbd.com
error: failed retrieving file 'core.db' from ftp.lysator.liu.se : Could not resolve host: ftp.lysator.liu.se
error: failed retrieving file 'core.db' from mirrors.dotsrc.org : Could not resolve host: mirrors.dotsrc.org
error: failed retrieving file 'core.db' from mirror.koddos.net : Could not resolve host: mirror.koddos.net
error: failed retrieving file 'core.db' from mirror.rise.ph : Could not resolve host: mirror.rise.ph
error: failed retrieving file 'core.db' from mirror.alwyzon.net : Could not resolve host: mirror.alwyzon.net
error: failed retrieving file 'core.db' from manjaro.lucassymons.net : Could not resolve host: manjaro.lucassymons.net
error: failed retrieving file 'core.db' from quantum-mirror.hu : Could not resolve host: quantum-mirror.hu
error: failed retrieving file 'core.db' from manjaro.repo.cure.edu.uy : Could not resolve host: manjaro.repo.cure.edu.uy
error: failed retrieving file 'core.db' from mirror.alpix.eu : Could not resolve host: mirror.alpix.eu
error: failed retrieving file 'core.db' from codingflyboy.mm.fcix.net : Could not resolve host: codingflyboy.mm.fcix.net
error: failed retrieving file 'core.db' from mirrors.netix.net : Could not resolve host: mirrors.netix.net
error: failed retrieving file 'core.db' from ftp.icm.edu.pl : Could not resolve host: ftp.icm.edu.pl
error: failed retrieving file 'core.db' from mirror.futureweb.be : Could not resolve host: mirror.futureweb.be
error: failed retrieving file 'core.db' from ridgewireless.mm.fcix.net : Could not resolve host: ridgewireless.mm.fcix.net
error: failed retrieving file 'core.db' from bd.mirror.vanehost.com : Could not resolve host: bd.mirror.vanehost.com
error: failed retrieving file 'core.db' from mirror.dkm.cz : Could not resolve host: mirror.dkm.cz
error: failed retrieving file 'core.db' from ct.mirror.garr.it : Could not resolve host: ct.mirror.garr.it
error: failed retrieving file 'core.db' from mirror.kku.ac.th : Could not resolve host: mirror.kku.ac.th
error: failed retrieving file 'core.db' from mirror.informatik.tu-freiberg.de : Could not resolve host: mirror.informatik.tu-freiberg.de
error: failed retrieving file 'core.db' from ftp.free.org : Could not resolve host: ftp.free.org
error: failed retrieving file 'core.db' from mirrors.ft.uam.es : Could not resolve host: mirrors.ft.uam.es
error: failed retrieving file 'core.db' from mirror.kamtv.ru : Could not resolve host: mirror.kamtv.ru
error: failed retrieving file 'core.db' from mirrors.xtom.de : Could not resolve host: mirrors.xtom.de
error: failed retrieving file 'core.db' from manjaro.mirror.ac.za : Could not resolve host: manjaro.mirror.ac.za
error: failed retrieving file 'core.db' from repos.silknet.com : Could not resolve host: repos.silknet.com
error: failed retrieving file 'core.db' from forksystems.mm.fcix.net : Could not resolve host: forksystems.mm.fcix.net
error: failed retrieving file 'core.db' from mirror2.sandyriver.net : Could not resolve host: mirror2.sandyriver.net
error: failed retrieving file 'core.db' from manjaro.mirrors.uk2.net : Could not resolve host: manjaro.mirrors.uk2.net
error: failed retrieving file 'core.db' from mirror.23m.com : Could not resolve host: mirror.23m.com
error: failed retrieving file 'core.db' from ftp.caliu.cat : Could not resolve host: ftp.caliu.cat
error: failed retrieving file 'core.db' from mirror.zetup.net : Could not resolve host: mirror.zetup.net
error: failed retrieving file 'core.db' from mirror.ufro.cl : Could not resolve host: mirror.ufro.cl
error: failed retrieving file 'core.db' from mirrors.fossho.st : Could not resolve host: mirrors.fossho.st
error: failed retrieving file 'core.db' from mirror.bardia.tech : Could not resolve host: mirror.bardia.tech
error: failed retrieving file 'core.db' from mirrors.ustc.edu.cn : Could not resolve host: mirrors.ustc.edu.cn
error: failed retrieving file 'core.db' from mirror.csclub.uwaterloo.ca : Could not resolve host: mirror.csclub.uwaterloo.ca
error: failed retrieving file 'core.db' from mirror.archlinux.tw : Could not resolve host: mirror.archlinux.tw
error: failed retrieving file 'core.db' from ftp.tsukuba.wide.ad.jp : Could not resolve host: ftp.tsukuba.wide.ad.jp
error: failed retrieving file 'core.db' from irltoolkit.mm.fcix.net : Could not resolve host: irltoolkit.mm.fcix.net
error: failed retrieving file 'core.db' from manjaro.mirror.garr.it : Could not resolve host: manjaro.mirror.garr.it
error: failed retrieving file 'core.db' from mirror.telepoint.bg : Could not resolve host: mirror.telepoint.bg
error: failed retrieving file 'core.db' from mirror.is.co.za : Could not resolve host: mirror.is.co.za
error: failed retrieving file 'core.db' from mirror.aarnet.edu.au : Could not resolve host: mirror.aarnet.edu.au
error: failed retrieving file 'core.db' from mirrors.xtom.ee : Could not resolve host: mirrors.xtom.ee
error: failed retrieving file 'core.db' from mirrors.ocf.berkeley.edu : Could not resolve host: mirrors.ocf.berkeley.edu
error: failed retrieving file 'core.db' from mirrors.pku.edu.cn : Could not resolve host: mirrors.pku.edu.cn
error: failed retrieving file 'core.db' from repo.iut.ac.ir : Could not resolve host: repo.iut.ac.ir
error: failed retrieving file 'core.db' from mirrors.xtom.jp : Could not resolve host: mirrors.xtom.jp
error: failed retrieving file 'core.db' from manjaro.ynh.ovh : Could not resolve host: manjaro.ynh.ovh
error: failed retrieving file 'core.db' from mirror.funami.tech : Could not resolve host: mirror.funami.tech
error: failed retrieving file 'core.db' from mirrors.up.pt : Could not resolve host: mirrors.up.pt
error: failed retrieving file 'core.db' from manjaro.astra.in.ua : Could not resolve host: manjaro.astra.in.ua
error: failed retrieving file 'core.db' from osmirror.org : Could not resolve host: osmirror.org
error: failed retrieving file 'core.db' from mirror1.cl.netactuate.com : Could not resolve host: mirror1.cl.netactuate.com
error: failed retrieving file 'core.db' from www.mirrorservice.org : Could not resolve host: www.mirrorservice.org
error: failed retrieving file 'core.db' from mirror.nju.edu.cn : Could not resolve host: mirror.nju.edu.cn
error: failed retrieving file 'core.db' from mirrors.sonic.net : Could not resolve host: mirrors.sonic.net
error: failed retrieving file 'core.db' from mirror.cyberhost.uk : Could not resolve host: mirror.cyberhost.uk
error: failed retrieving file 'core.db' from mirror.init7.net : Could not resolve host: mirror.init7.net
error: failed retrieving file 'core.db' from mirrors.colocall.net : Could not resolve host: mirrors.colocall.net
error: failed retrieving file 'core.db' from mirror.datacenter.by : Could not resolve host: mirror.datacenter.by
error: failed retrieving file 'core.db' from mnvoip.mm.fcix.net : Could not resolve host: mnvoip.mm.fcix.net
error: failed retrieving file 'core.db' from manjaro.grena.ge : Could not resolve host: manjaro.grena.ge
error: failed retrieving file 'core.db' from ftp.linux.org.tr : Could not resolve host: ftp.linux.org.tr
error: failed retrieving file 'core.db' from mirror.yandex.ru : Could not resolve host: mirror.yandex.ru
error: failed retrieving file 'core.db' from ftp.dei.uc.pt : Could not resolve host: ftp.dei.uc.pt
error: failed retrieving file 'core.db' from ossmirror.mycloud.services : Could not resolve host: ossmirror.mycloud.services
error: failed to update core (invalid url for server)
error: failed retrieving file 'extra.db' from ftp.snt.utwente.nl : Could not resolve host: ftp.snt.utwente.nl
error: failed retrieving file 'extra.db' from ba.mirror.garr.it : Could not resolve host: ba.mirror.garr.it
error: failed retrieving file 'extra.db' from mirror.2degrees.nz : Could not resolve host: mirror.2degrees.nz
error: failed retrieving file 'extra.db' from mirror.math.princeton.edu : Could not resolve host: mirror.math.princeton.edu
error: failed retrieving file 'extra.db' from manjaro.kyberorg.fi : Could not resolve host: manjaro.kyberorg.fi
error: failed retrieving file 'extra.db' from manjaro.ipacct.com : Could not resolve host: manjaro.ipacct.com
error: failed retrieving file 'extra.db' from ziply.mm.fcix.net : Could not resolve host: ziply.mm.fcix.net
error: failed retrieving file 'extra.db' from mirror.albony.xyz : Could not resolve host: mirror.albony.xyz
error: failed retrieving file 'extra.db' from mirror.tarnkappe.info : Could not resolve host: mirror.tarnkappe.info
error: failed retrieving file 'extra.db' from repo.ialab.dsu.edu : Could not resolve host: repo.ialab.dsu.edu
error: failed retrieving file 'extra.db' from manjaro.dcc.uchile.cl : Could not resolve host: manjaro.dcc.uchile.cl
error: failed retrieving file 'extra.db' from mirror.truenetwork.ru : Could not resolve host: mirror.truenetwork.ru
error: failed retrieving file 'extra.db' from coresite.mm.fcix.net : Could not resolve host: coresite.mm.fcix.net
error: failed retrieving file 'extra.db' from mirrors.tuna.tsinghua.edu.cn : Could not resolve host: mirrors.tuna.tsinghua.edu.cn
error: failed retrieving file 'extra.db' from mirrors.sjtug.sjtu.edu.cn : Could not resolve host: mirrors.sjtug.sjtu.edu.cn
error: failed retrieving file 'extra.db' from ftp.belnet.be : Could not resolve host: ftp.belnet.be
error: failed retrieving file 'extra.db' from ftpmirror1.infania.net : Could not resolve host: ftpmirror1.infania.net
error: failed retrieving file 'extra.db' from mirror.netcologne.de : Could not resolve host: mirror.netcologne.de
error: failed retrieving file 'extra.db' from manjaro.mirror.liquidtelecom.com : Could not resolve host: manjaro.mirror.liquidtelecom.com
error: failed retrieving file 'extra.db' from ftp.nluug.nl : Could not resolve host: ftp.nluug.nl
error: failed retrieving file 'extra.db' from ftp.tu-chemnitz.de : Could not resolve host: ftp.tu-chemnitz.de
error: failed retrieving file 'extra.db' from ftp.psnc.pl : Could not resolve host: ftp.psnc.pl
error: failed retrieving file 'extra.db' from download.nus.edu.sg : Could not resolve host: download.nus.edu.sg
error: failed retrieving file 'extra.db' from ftp.riken.jp : Could not resolve host: ftp.riken.jp
error: failed retrieving file 'extra.db' from ftp.halifax.rwth-aachen.de : Could not resolve host: ftp.halifax.rwth-aachen.de
error: failed retrieving file 'extra.db' from fastmirror.pp.ua : Could not resolve host: fastmirror.pp.ua
error: failed retrieving file 'extra.db' from muug.ca : Could not resolve host: muug.ca
error: failed retrieving file 'extra.db' from mirrors.nic.cz : Could not resolve host: mirrors.nic.cz
error: failed retrieving file 'extra.db' from manjaro.mirrors.lavatech.top : Could not resolve host: manjaro.mirrors.lavatech.top
error: failed retrieving file 'extra.db' from mirrors.ucr.ac.cr : Could not resolve host: mirrors.ucr.ac.cr
error: failed retrieving file 'extra.db' from repo.skni.umcs.pl : Could not resolve host: repo.skni.umcs.pl
error: failed retrieving file 'extra.db' from mirrors.huaweicloud.com : Could not resolve host: mirrors.huaweicloud.com
error: failed retrieving file 'extra.db' from uvermont.mm.fcix.net : Could not resolve host: uvermont.mm.fcix.net
error: failed retrieving file 'extra.db' from mirror.moson.org : Could not resolve host: mirror.moson.org
error: failed retrieving file 'extra.db' from mirrors.manjaro.org : Could not resolve host: mirrors.manjaro.org
error: failed retrieving file 'extra.db' from manjaro.osmir.ch : Could not resolve host: manjaro.osmir.ch
error: failed retrieving file 'extra.db' from mirror.easyname.at : Could not resolve host: mirror.easyname.at
error: failed retrieving file 'extra.db' from mirror.xenyth.net : Could not resolve host: mirror.xenyth.net
error: failed retrieving file 'extra.db' from mirror.fcix.net : Could not resolve host: mirror.fcix.net
error: failed retrieving file 'extra.db' from ftp.gwdg.de : Could not resolve host: ftp.gwdg.de
error: failed retrieving file 'extra.db' from ftp.cc.uoc.gr : Could not resolve host: ftp.cc.uoc.gr
error: failed retrieving file 'extra.db' from manjaro.c3sl.ufpr.br : Could not resolve host: manjaro.c3sl.ufpr.br
error: failed retrieving file 'extra.db' from mirror.terrahost.no : Could not resolve host: mirror.terrahost.no
error: failed retrieving file 'extra.db' from mirrors.gethosted.online : Could not resolve host: mirrors.gethosted.online
error: failed retrieving file 'extra.db' from mirror.xeonbd.com : Could not resolve host: mirror.xeonbd.com
error: failed retrieving file 'extra.db' from ftp.lysator.liu.se : Could not resolve host: ftp.lysator.liu.se
error: failed retrieving file 'extra.db' from mirrors.dotsrc.org : Could not resolve host: mirrors.dotsrc.org
error: failed retrieving file 'extra.db' from mirror.koddos.net : Could not resolve host: mirror.koddos.net
error: failed retrieving file 'extra.db' from mirror.rise.ph : Could not resolve host: mirror.rise.ph
error: failed retrieving file 'extra.db' from mirror.alwyzon.net : Could not resolve host: mirror.alwyzon.net
error: failed retrieving file 'extra.db' from manjaro.lucassymons.net : Could not resolve host: manjaro.lucassymons.net
error: failed retrieving file 'extra.db' from quantum-mirror.hu : Could not resolve host: quantum-mirror.hu
error: failed retrieving file 'extra.db' from manjaro.repo.cure.edu.uy : Could not resolve host: manjaro.repo.cure.edu.uy
error: failed retrieving file 'extra.db' from mirror.alpix.eu : Could not resolve host: mirror.alpix.eu
error: failed retrieving file 'extra.db' from codingflyboy.mm.fcix.net : Could not resolve host: codingflyboy.mm.fcix.net
error: failed retrieving file 'extra.db' from mirrors.netix.net : Could not resolve host: mirrors.netix.net
error: failed retrieving file 'extra.db' from ftp.icm.edu.pl : Could not resolve host: ftp.icm.edu.pl
error: failed retrieving file 'extra.db' from mirror.futureweb.be : Could not resolve host: mirror.futureweb.be
error: failed retrieving file 'extra.db' from ridgewireless.mm.fcix.net : Could not resolve host: ridgewireless.mm.fcix.net
error: failed retrieving file 'extra.db' from bd.mirror.vanehost.com : Could not resolve host: bd.mirror.vanehost.com
error: failed retrieving file 'extra.db' from mirror.dkm.cz : Could not resolve host: mirror.dkm.cz
error: failed retrieving file 'extra.db' from ct.mirror.garr.it : Could not resolve host: ct.mirror.garr.it
error: failed retrieving file 'extra.db' from mirror.kku.ac.th : Could not resolve host: mirror.kku.ac.th
error: failed retrieving file 'extra.db' from mirror.informatik.tu-freiberg.de : Could not resolve host: mirror.informatik.tu-freiberg.de
error: failed retrieving file 'extra.db' from ftp.free.org : Could not resolve host: ftp.free.org
error: failed retrieving file 'extra.db' from mirrors.ft.uam.es : Could not resolve host: mirrors.ft.uam.es
error: failed retrieving file 'extra.db' from mirror.kamtv.ru : Could not resolve host: mirror.kamtv.ru
error: failed retrieving file 'extra.db' from mirrors.xtom.de : Could not resolve host: mirrors.xtom.de
error: failed retrieving file 'extra.db' from manjaro.mirror.ac.za : Could not resolve host: manjaro.mirror.ac.za
error: failed retrieving file 'extra.db' from repos.silknet.com : Could not resolve host: repos.silknet.com
error: failed retrieving file 'extra.db' from forksystems.mm.fcix.net : Could not resolve host: forksystems.mm.fcix.net
error: failed retrieving file 'extra.db' from mirror2.sandyriver.net : Could not resolve host: mirror2.sandyriver.net
error: failed retrieving file 'extra.db' from manjaro.mirrors.uk2.net : Could not resolve host: manjaro.mirrors.uk2.net
error: failed retrieving file 'extra.db' from mirror.23m.com : Could not resolve host: mirror.23m.com
error: failed retrieving file 'extra.db' from ftp.caliu.cat : Could not resolve host: ftp.caliu.cat
error: failed retrieving file 'extra.db' from mirror.zetup.net : Could not resolve host: mirror.zetup.net
error: failed retrieving file 'extra.db' from mirror.ufro.cl : Could not resolve host: mirror.ufro.cl
error: failed retrieving file 'extra.db' from mirrors.fossho.st : Could not resolve host: mirrors.fossho.st
error: failed retrieving file 'extra.db' from mirror.bardia.tech : Could not resolve host: mirror.bardia.tech
error: failed retrieving file 'extra.db' from mirrors.ustc.edu.cn : Could not resolve host: mirrors.ustc.edu.cn
error: failed retrieving file 'extra.db' from mirror.csclub.uwaterloo.ca : Could not resolve host: mirror.csclub.uwaterloo.ca
error: failed retrieving file 'extra.db' from mirror.archlinux.tw : Could not resolve host: mirror.archlinux.tw
error: failed retrieving file 'extra.db' from ftp.tsukuba.wide.ad.jp : Could not resolve host: ftp.tsukuba.wide.ad.jp
error: failed retrieving file 'extra.db' from irltoolkit.mm.fcix.net : Could not resolve host: irltoolkit.mm.fcix.net
error: failed retrieving file 'extra.db' from manjaro.mirror.garr.it : Could not resolve host: manjaro.mirror.garr.it
error: failed retrieving file 'extra.db' from mirror.telepoint.bg : Could not resolve host: mirror.telepoint.bg
error: failed retrieving file 'extra.db' from mirror.is.co.za : Could not resolve host: mirror.is.co.za
error: failed retrieving file 'extra.db' from mirror.aarnet.edu.au : Could not resolve host: mirror.aarnet.edu.au
error: failed retrieving file 'extra.db' from mirrors.xtom.ee : Could not resolve host: mirrors.xtom.ee
error: failed retrieving file 'extra.db' from mirrors.ocf.berkeley.edu : Could not resolve host: mirrors.ocf.berkeley.edu
error: failed retrieving file 'extra.db' from mirrors.pku.edu.cn : Could not resolve host: mirrors.pku.edu.cn
error: failed retrieving file 'extra.db' from repo.iut.ac.ir : Could not resolve host: repo.iut.ac.ir
error: failed retrieving file 'extra.db' from mirrors.xtom.jp : Could not resolve host: mirrors.xtom.jp
error: failed retrieving file 'extra.db' from manjaro.ynh.ovh : Could not resolve host: manjaro.ynh.ovh
error: failed retrieving file 'extra.db' from mirror.funami.tech : Could not resolve host: mirror.funami.tech
error: failed retrieving file 'extra.db' from mirrors.up.pt : Could not resolve host: mirrors.up.pt
error: failed retrieving file 'extra.db' from manjaro.astra.in.ua : Could not resolve host: manjaro.astra.in.ua
error: failed retrieving file 'extra.db' from osmirror.org : Could not resolve host: osmirror.org
error: failed retrieving file 'extra.db' from mirror1.cl.netactuate.com : Could not resolve host: mirror1.cl.netactuate.com
error: failed retrieving file 'extra.db' from www.mirrorservice.org : Could not resolve host: www.mirrorservice.org
error: failed retrieving file 'extra.db' from mirror.nju.edu.cn : Could not resolve host: mirror.nju.edu.cn
error: failed retrieving file 'extra.db' from mirrors.sonic.net : Could not resolve host: mirrors.sonic.net
error: failed retrieving file 'extra.db' from mirror.cyberhost.uk : Could not resolve host: mirror.cyberhost.uk
error: failed retrieving file 'extra.db' from mirror.init7.net : Could not resolve host: mirror.init7.net
error: failed retrieving file 'extra.db' from mirrors.colocall.net : Could not resolve host: mirrors.colocall.net
error: failed retrieving file 'extra.db' from mirror.datacenter.by : Could not resolve host: mirror.datacenter.by
error: failed retrieving file 'extra.db' from mnvoip.mm.fcix.net : Could not resolve host: mnvoip.mm.fcix.net
error: failed retrieving file 'extra.db' from manjaro.grena.ge : Could not resolve host: manjaro.grena.ge
error: failed retrieving file 'extra.db' from ftp.linux.org.tr : Could not resolve host: ftp.linux.org.tr
error: failed retrieving file 'extra.db' from mirror.yandex.ru : Could not resolve host: mirror.yandex.ru
error: failed retrieving file 'extra.db' from ftp.dei.uc.pt : Could not resolve host: ftp.dei.uc.pt
error: failed retrieving file 'extra.db' from ossmirror.mycloud.services : Could not resolve host: ossmirror.mycloud.services
error: failed to update extra (invalid url for server)
error: failed retrieving file 'community.db' from ftp.snt.utwente.nl : Could not resolve host: ftp.snt.utwente.nl
error: failed retrieving file 'community.db' from ba.mirror.garr.it : Could not resolve host: ba.mirror.garr.it
error: failed retrieving file 'community.db' from mirror.2degrees.nz : Could not resolve host: mirror.2degrees.nz
error: failed retrieving file 'community.db' from mirror.math.princeton.edu : Could not resolve host: mirror.math.princeton.edu
error: failed retrieving file 'community.db' from manjaro.kyberorg.fi : Could not resolve host: manjaro.kyberorg.fi
error: failed retrieving file 'community.db' from manjaro.ipacct.com : Could not resolve host: manjaro.ipacct.com
error: failed retrieving file 'community.db' from ziply.mm.fcix.net : Could not resolve host: ziply.mm.fcix.net
error: failed retrieving file 'community.db' from mirror.albony.xyz : Could not resolve host: mirror.albony.xyz
error: failed retrieving file 'community.db' from mirror.tarnkappe.info : Could not resolve host: mirror.tarnkappe.info
error: failed retrieving file 'community.db' from repo.ialab.dsu.edu : Could not resolve host: repo.ialab.dsu.edu
error: failed retrieving file 'community.db' from manjaro.dcc.uchile.cl : Could not resolve host: manjaro.dcc.uchile.cl
error: failed retrieving file 'community.db' from mirror.truenetwork.ru : Could not resolve host: mirror.truenetwork.ru
error: failed retrieving file 'community.db' from coresite.mm.fcix.net : Could not resolve host: coresite.mm.fcix.net
error: failed retrieving file 'community.db' from mirrors.tuna.tsinghua.edu.cn : Could not resolve host: mirrors.tuna.tsinghua.edu.cn
error: failed retrieving file 'community.db' from mirrors.sjtug.sjtu.edu.cn : Could not resolve host: mirrors.sjtug.sjtu.edu.cn
error: failed retrieving file 'community.db' from ftp.belnet.be : Could not resolve host: ftp.belnet.be
error: failed retrieving file 'community.db' from ftpmirror1.infania.net : Could not resolve host: ftpmirror1.infania.net
error: failed retrieving file 'community.db' from mirror.netcologne.de : Could not resolve host: mirror.netcologne.de
error: failed retrieving file 'community.db' from manjaro.mirror.liquidtelecom.com : Could not resolve host: manjaro.mirror.liquidtelecom.com
error: failed retrieving file 'community.db' from ftp.nluug.nl : Could not resolve host: ftp.nluug.nl
error: failed retrieving file 'community.db' from ftp.tu-chemnitz.de : Could not resolve host: ftp.tu-chemnitz.de
error: failed retrieving file 'community.db' from ftp.psnc.pl : Could not resolve host: ftp.psnc.pl
error: failed retrieving file 'community.db' from download.nus.edu.sg : Could not resolve host: download.nus.edu.sg
error: failed retrieving file 'community.db' from ftp.riken.jp : Could not resolve host: ftp.riken.jp
error: failed retrieving file 'community.db' from ftp.halifax.rwth-aachen.de : Could not resolve host: ftp.halifax.rwth-aachen.de
error: failed retrieving file 'community.db' from fastmirror.pp.ua : Could not resolve host: fastmirror.pp.ua
error: failed retrieving file 'community.db' from muug.ca : Could not resolve host: muug.ca
error: failed retrieving file 'community.db' from mirrors.nic.cz : Could not resolve host: mirrors.nic.cz
error: failed retrieving file 'community.db' from manjaro.mirrors.lavatech.top : Could not resolve host: manjaro.mirrors.lavatech.top
error: failed retrieving file 'community.db' from mirrors.ucr.ac.cr : Could not resolve host: mirrors.ucr.ac.cr
error: failed retrieving file 'community.db' from repo.skni.umcs.pl : Could not resolve host: repo.skni.umcs.pl
error: failed retrieving file 'community.db' from mirrors.huaweicloud.com : Could not resolve host: mirrors.huaweicloud.com
error: failed retrieving file 'community.db' from uvermont.mm.fcix.net : Could not resolve host: uvermont.mm.fcix.net
error: failed retrieving file 'community.db' from mirror.moson.org : Could not resolve host: mirror.moson.org
error: failed retrieving file 'community.db' from mirrors.manjaro.org : Could not resolve host: mirrors.manjaro.org
error: failed retrieving file 'community.db' from manjaro.osmir.ch : Could not resolve host: manjaro.osmir.ch
error: failed retrieving file 'community.db' from mirror.easyname.at : Could not resolve host: mirror.easyname.at
error: failed retrieving file 'community.db' from mirror.xenyth.net : Could not resolve host: mirror.xenyth.net
error: failed retrieving file 'community.db' from mirror.fcix.net : Could not resolve host: mirror.fcix.net
error: failed retrieving file 'community.db' from ftp.gwdg.de : Could not resolve host: ftp.gwdg.de
error: failed retrieving file 'community.db' from ftp.cc.uoc.gr : Could not resolve host: ftp.cc.uoc.gr
error: failed retrieving file 'community.db' from manjaro.c3sl.ufpr.br : Could not resolve host: manjaro.c3sl.ufpr.br
error: failed retrieving file 'community.db' from mirror.terrahost.no : Could not resolve host: mirror.terrahost.no
error: failed retrieving file 'community.db' from mirrors.gethosted.online : Could not resolve host: mirrors.gethosted.online
error: failed retrieving file 'community.db' from mirror.xeonbd.com : Could not resolve host: mirror.xeonbd.com
error: failed retrieving file 'community.db' from ftp.lysator.liu.se : Could not resolve host: ftp.lysator.liu.se
error: failed retrieving file 'community.db' from mirrors.dotsrc.org : Could not resolve host: mirrors.dotsrc.org
error: failed retrieving file 'community.db' from mirror.koddos.net : Could not resolve host: mirror.koddos.net
error: failed retrieving file 'community.db' from mirror.rise.ph : Could not resolve host: mirror.rise.ph
error: failed retrieving file 'community.db' from mirror.alwyzon.net : Could not resolve host: mirror.alwyzon.net
error: failed retrieving file 'community.db' from manjaro.lucassymons.net : Could not resolve host: manjaro.lucassymons.net
error: failed retrieving file 'community.db' from quantum-mirror.hu : Could not resolve host: quantum-mirror.hu
error: failed retrieving file 'community.db' from manjaro.repo.cure.edu.uy : Could not resolve host: manjaro.repo.cure.edu.uy
error: failed retrieving file 'community.db' from mirror.alpix.eu : Could not resolve host: mirror.alpix.eu
error: failed retrieving file 'community.db' from codingflyboy.mm.fcix.net : Could not resolve host: codingflyboy.mm.fcix.net
error: failed retrieving file 'community.db' from mirrors.netix.net : Could not resolve host: mirrors.netix.net
error: failed retrieving file 'community.db' from ftp.icm.edu.pl : Could not resolve host: ftp.icm.edu.pl
error: failed retrieving file 'community.db' from mirror.futureweb.be : Could not resolve host: mirror.futureweb.be
error: failed retrieving file 'community.db' from ridgewireless.mm.fcix.net : Could not resolve host: ridgewireless.mm.fcix.net
error: failed retrieving file 'community.db' from bd.mirror.vanehost.com : Could not resolve host: bd.mirror.vanehost.com
error: failed retrieving file 'community.db' from mirror.dkm.cz : Could not resolve host: mirror.dkm.cz
error: failed retrieving file 'community.db' from ct.mirror.garr.it : Could not resolve host: ct.mirror.garr.it
error: failed retrieving file 'community.db' from mirror.kku.ac.th : Could not resolve host: mirror.kku.ac.th
error: failed retrieving file 'community.db' from mirror.informatik.tu-freiberg.de : Could not resolve host: mirror.informatik.tu-freiberg.de
error: failed retrieving file 'community.db' from ftp.free.org : Could not resolve host: ftp.free.org
error: failed retrieving file 'community.db' from mirrors.ft.uam.es : Could not resolve host: mirrors.ft.uam.es
error: failed retrieving file 'community.db' from mirror.kamtv.ru : Could not resolve host: mirror.kamtv.ru
error: failed retrieving file 'community.db' from mirrors.xtom.de : Could not resolve host: mirrors.xtom.de
error: failed retrieving file 'community.db' from manjaro.mirror.ac.za : Could not resolve host: manjaro.mirror.ac.za
error: failed retrieving file 'community.db' from repos.silknet.com : Could not resolve host: repos.silknet.com
error: failed retrieving file 'community.db' from forksystems.mm.fcix.net : Could not resolve host: forksystems.mm.fcix.net
error: failed retrieving file 'community.db' from mirror2.sandyriver.net : Could not resolve host: mirror2.sandyriver.net
error: failed retrieving file 'community.db' from manjaro.mirrors.uk2.net : Could not resolve host: manjaro.mirrors.uk2.net
error: failed retrieving file 'community.db' from mirror.23m.com : Could not resolve host: mirror.23m.com
error: failed retrieving file 'community.db' from ftp.caliu.cat : Could not resolve host: ftp.caliu.cat
error: failed retrieving file 'community.db' from mirror.zetup.net : Could not resolve host: mirror.zetup.net
error: failed retrieving file 'community.db' from mirror.ufro.cl : Could not resolve host: mirror.ufro.cl
error: failed retrieving file 'community.db' from mirrors.fossho.st : Could not resolve host: mirrors.fossho.st
error: failed retrieving file 'community.db' from mirror.bardia.tech : Could not resolve host: mirror.bardia.tech
error: failed retrieving file 'community.db' from mirrors.ustc.edu.cn : Could not resolve host: mirrors.ustc.edu.cn
error: failed retrieving file 'community.db' from mirror.csclub.uwaterloo.ca : Could not resolve host: mirror.csclub.uwaterloo.ca
error: failed retrieving file 'community.db' from mirror.archlinux.tw : Could not resolve host: mirror.archlinux.tw
error: failed retrieving file 'community.db' from ftp.tsukuba.wide.ad.jp : Could not resolve host: ftp.tsukuba.wide.ad.jp
error: failed retrieving file 'community.db' from irltoolkit.mm.fcix.net : Could not resolve host: irltoolkit.mm.fcix.net
error: failed retrieving file 'community.db' from manjaro.mirror.garr.it : Could not resolve host: manjaro.mirror.garr.it
error: failed retrieving file 'community.db' from mirror.telepoint.bg : Could not resolve host: mirror.telepoint.bg
error: failed retrieving file 'community.db' from mirror.is.co.za : Could not resolve host: mirror.is.co.za
error: failed retrieving file 'community.db' from mirror.aarnet.edu.au : Could not resolve host: mirror.aarnet.edu.au
error: failed retrieving file 'community.db' from mirrors.xtom.ee : Could not resolve host: mirrors.xtom.ee
error: failed retrieving file 'community.db' from mirrors.ocf.berkeley.edu : Could not resolve host: mirrors.ocf.berkeley.edu
error: failed retrieving file 'community.db' from mirrors.pku.edu.cn : Could not resolve host: mirrors.pku.edu.cn
error: failed retrieving file 'community.db' from repo.iut.ac.ir : Could not resolve host: repo.iut.ac.ir
error: failed retrieving file 'community.db' from mirrors.xtom.jp : Could not resolve host: mirrors.xtom.jp
error: failed retrieving file 'community.db' from manjaro.ynh.ovh : Could not resolve host: manjaro.ynh.ovh
error: failed retrieving file 'community.db' from mirror.funami.tech : Could not resolve host: mirror.funami.tech
error: failed retrieving file 'community.db' from mirrors.up.pt : Could not resolve host: mirrors.up.pt
error: failed retrieving file 'community.db' from manjaro.astra.in.ua : Could not resolve host: manjaro.astra.in.ua
error: failed retrieving file 'community.db' from osmirror.org : Could not resolve host: osmirror.org
error: failed retrieving file 'community.db' from mirror1.cl.netactuate.com : Could not resolve host: mirror1.cl.netactuate.com
error: failed retrieving file 'community.db' from www.mirrorservice.org : Could not resolve host: www.mirrorservice.org
error: failed retrieving file 'community.db' from mirror.nju.edu.cn : Could not resolve host: mirror.nju.edu.cn
error: failed retrieving file 'community.db' from mirrors.sonic.net : Could not resolve host: mirrors.sonic.net
error: failed retrieving file 'community.db' from mirror.cyberhost.uk : Could not resolve host: mirror.cyberhost.uk
error: failed retrieving file 'community.db' from mirror.init7.net : Could not resolve host: mirror.init7.net
error: failed retrieving file 'community.db' from mirrors.colocall.net : Could not resolve host: mirrors.colocall.net
error: failed retrieving file 'community.db' from mirror.datacenter.by : Could not resolve host: mirror.datacenter.by
error: failed retrieving file 'community.db' from mnvoip.mm.fcix.net : Could not resolve host: mnvoip.mm.fcix.net
error: failed retrieving file 'community.db' from manjaro.grena.ge : Could not resolve host: manjaro.grena.ge
error: failed retrieving file 'community.db' from ftp.linux.org.tr : Could not resolve host: ftp.linux.org.tr
error: failed retrieving file 'community.db' from mirror.yandex.ru : Could not resolve host: mirror.yandex.ru
error: failed retrieving file 'community.db' from ftp.dei.uc.pt : Could not resolve host: ftp.dei.uc.pt
error: failed retrieving file 'community.db' from ossmirror.mycloud.services : Could not resolve host: ossmirror.mycloud.services
error: failed to update community (invalid url for server)
error: failed retrieving file 'multilib.db' from ftp.snt.utwente.nl : Could not resolve host: ftp.snt.utwente.nl
error: failed retrieving file 'multilib.db' from ba.mirror.garr.it : Could not resolve host: ba.mirror.garr.it
error: failed retrieving file 'multilib.db' from mirror.2degrees.nz : Could not resolve host: mirror.2degrees.nz
error: failed retrieving file 'multilib.db' from mirror.math.princeton.edu : Could not resolve host: mirror.math.princeton.edu
error: failed retrieving file 'multilib.db' from manjaro.kyberorg.fi : Could not resolve host: manjaro.kyberorg.fi
error: failed retrieving file 'multilib.db' from manjaro.ipacct.com : Could not resolve host: manjaro.ipacct.com
error: failed retrieving file 'multilib.db' from ziply.mm.fcix.net : Could not resolve host: ziply.mm.fcix.net
error: failed retrieving file 'multilib.db' from mirror.albony.xyz : Could not resolve host: mirror.albony.xyz
error: failed retrieving file 'multilib.db' from mirror.tarnkappe.info : Could not resolve host: mirror.tarnkappe.info
error: failed retrieving file 'multilib.db' from repo.ialab.dsu.edu : Could not resolve host: repo.ialab.dsu.edu
error: failed retrieving file 'multilib.db' from manjaro.dcc.uchile.cl : Could not resolve host: manjaro.dcc.uchile.cl
error: failed retrieving file 'multilib.db' from mirror.truenetwork.ru : Could not resolve host: mirror.truenetwork.ru
error: failed retrieving file 'multilib.db' from coresite.mm.fcix.net : Could not resolve host: coresite.mm.fcix.net
error: failed retrieving file 'multilib.db' from mirrors.tuna.tsinghua.edu.cn : Could not resolve host: mirrors.tuna.tsinghua.edu.cn
error: failed retrieving file 'multilib.db' from mirrors.sjtug.sjtu.edu.cn : Could not resolve host: mirrors.sjtug.sjtu.edu.cn
error: failed retrieving file 'multilib.db' from ftp.belnet.be : Could not resolve host: ftp.belnet.be
error: failed retrieving file 'multilib.db' from ftpmirror1.infania.net : Could not resolve host: ftpmirror1.infania.net
error: failed retrieving file 'multilib.db' from mirror.netcologne.de : Could not resolve host: mirror.netcologne.de
error: failed retrieving file 'multilib.db' from manjaro.mirror.liquidtelecom.com : Could not resolve host: manjaro.mirror.liquidtelecom.com
error: failed retrieving file 'multilib.db' from ftp.nluug.nl : Could not resolve host: ftp.nluug.nl
error: failed retrieving file 'multilib.db' from ftp.tu-chemnitz.de : Could not resolve host: ftp.tu-chemnitz.de
error: failed retrieving file 'multilib.db' from ftp.psnc.pl : Could not resolve host: ftp.psnc.pl
error: failed retrieving file 'multilib.db' from download.nus.edu.sg : Could not resolve host: download.nus.edu.sg
error: failed retrieving file 'multilib.db' from ftp.riken.jp : Could not resolve host: ftp.riken.jp
error: failed retrieving file 'multilib.db' from ftp.halifax.rwth-aachen.de : Could not resolve host: ftp.halifax.rwth-aachen.de
error: failed retrieving file 'multilib.db' from fastmirror.pp.ua : Could not resolve host: fastmirror.pp.ua
error: failed retrieving file 'multilib.db' from muug.ca : Could not resolve host: muug.ca
error: failed retrieving file 'multilib.db' from mirrors.nic.cz : Could not resolve host: mirrors.nic.cz
error: failed retrieving file 'multilib.db' from manjaro.mirrors.lavatech.top : Could not resolve host: manjaro.mirrors.lavatech.top
error: failed retrieving file 'multilib.db' from mirrors.ucr.ac.cr : Could not resolve host: mirrors.ucr.ac.cr
error: failed retrieving file 'multilib.db' from repo.skni.umcs.pl : Could not resolve host: repo.skni.umcs.pl
error: failed retrieving file 'multilib.db' from mirrors.huaweicloud.com : Could not resolve host: mirrors.huaweicloud.com
error: failed retrieving file 'multilib.db' from uvermont.mm.fcix.net : Could not resolve host: uvermont.mm.fcix.net
error: failed retrieving file 'multilib.db' from mirror.moson.org : Could not resolve host: mirror.moson.org
error: failed retrieving file 'multilib.db' from mirrors.manjaro.org : Could not resolve host: mirrors.manjaro.org
error: failed retrieving file 'multilib.db' from manjaro.osmir.ch : Could not resolve host: manjaro.osmir.ch
error: failed retrieving file 'multilib.db' from mirror.easyname.at : Could not resolve host: mirror.easyname.at
error: failed retrieving file 'multilib.db' from mirror.xenyth.net : Could not resolve host: mirror.xenyth.net
error: failed retrieving file 'multilib.db' from mirror.fcix.net : Could not resolve host: mirror.fcix.net
error: failed retrieving file 'multilib.db' from ftp.gwdg.de : Could not resolve host: ftp.gwdg.de
error: failed retrieving file 'multilib.db' from ftp.cc.uoc.gr : Could not resolve host: ftp.cc.uoc.gr
error: failed retrieving file 'multilib.db' from manjaro.c3sl.ufpr.br : Could not resolve host: manjaro.c3sl.ufpr.br
error: failed retrieving file 'multilib.db' from mirror.terrahost.no : Could not resolve host: mirror.terrahost.no
error: failed retrieving file 'multilib.db' from mirrors.gethosted.online : Could not resolve host: mirrors.gethosted.online
error: failed retrieving file 'multilib.db' from mirror.xeonbd.com : Could not resolve host: mirror.xeonbd.com
error: failed retrieving file 'multilib.db' from ftp.lysator.liu.se : Could not resolve host: ftp.lysator.liu.se
error: failed retrieving file 'multilib.db' from mirrors.dotsrc.org : Could not resolve host: mirrors.dotsrc.org
error: failed retrieving file 'multilib.db' from mirror.koddos.net : Could not resolve host: mirror.koddos.net
error: failed retrieving file 'multilib.db' from mirror.rise.ph : Could not resolve host: mirror.rise.ph
error: failed retrieving file 'multilib.db' from mirror.alwyzon.net : Could not resolve host: mirror.alwyzon.net
error: failed retrieving file 'multilib.db' from manjaro.lucassymons.net : Could not resolve host: manjaro.lucassymons.net
error: failed retrieving file 'multilib.db' from quantum-mirror.hu : Could not resolve host: quantum-mirror.hu
error: failed retrieving file 'multilib.db' from manjaro.repo.cure.edu.uy : Could not resolve host: manjaro.repo.cure.edu.uy
error: failed retrieving file 'multilib.db' from mirror.alpix.eu : Could not resolve host: mirror.alpix.eu
error: failed retrieving file 'multilib.db' from codingflyboy.mm.fcix.net : Could not resolve host: codingflyboy.mm.fcix.net
error: failed retrieving file 'multilib.db' from mirrors.netix.net : Could not resolve host: mirrors.netix.net
error: failed retrieving file 'multilib.db' from ftp.icm.edu.pl : Could not resolve host: ftp.icm.edu.pl
error: failed retrieving file 'multilib.db' from mirror.futureweb.be : Could not resolve host: mirror.futureweb.be
error: failed retrieving file 'multilib.db' from ridgewireless.mm.fcix.net : Could not resolve host: ridgewireless.mm.fcix.net
error: failed retrieving file 'multilib.db' from bd.mirror.vanehost.com : Could not resolve host: bd.mirror.vanehost.com
error: failed retrieving file 'multilib.db' from mirror.dkm.cz : Could not resolve host: mirror.dkm.cz
error: failed retrieving file 'multilib.db' from ct.mirror.garr.it : Could not resolve host: ct.mirror.garr.it
error: failed retrieving file 'multilib.db' from mirror.kku.ac.th : Could not resolve host: mirror.kku.ac.th
error: failed retrieving file 'multilib.db' from mirror.informatik.tu-freiberg.de : Could not resolve host: mirror.informatik.tu-freiberg.de
error: failed retrieving file 'multilib.db' from ftp.free.org : Could not resolve host: ftp.free.org
error: failed retrieving file 'multilib.db' from mirrors.ft.uam.es : Could not resolve host: mirrors.ft.uam.es
error: failed retrieving file 'multilib.db' from mirror.kamtv.ru : Could not resolve host: mirror.kamtv.ru
error: failed retrieving file 'multilib.db' from mirrors.xtom.de : Could not resolve host: mirrors.xtom.de
error: failed retrieving file 'multilib.db' from manjaro.mirror.ac.za : Could not resolve host: manjaro.mirror.ac.za
error: failed retrieving file 'multilib.db' from repos.silknet.com : Could not resolve host: repos.silknet.com
error: failed retrieving file 'multilib.db' from forksystems.mm.fcix.net : Could not resolve host: forksystems.mm.fcix.net
error: failed retrieving file 'multilib.db' from mirror2.sandyriver.net : Could not resolve host: mirror2.sandyriver.net
error: failed retrieving file 'multilib.db' from manjaro.mirrors.uk2.net : Could not resolve host: manjaro.mirrors.uk2.net
error: failed retrieving file 'multilib.db' from mirror.23m.com : Could not resolve host: mirror.23m.com
error: failed retrieving file 'multilib.db' from ftp.caliu.cat : Could not resolve host: ftp.caliu.cat
error: failed retrieving file 'multilib.db' from mirror.zetup.net : Could not resolve host: mirror.zetup.net
error: failed retrieving file 'multilib.db' from mirror.ufro.cl : Could not resolve host: mirror.ufro.cl
error: failed retrieving file 'multilib.db' from mirrors.fossho.st : Could not resolve host: mirrors.fossho.st
error: failed retrieving file 'multilib.db' from mirror.bardia.tech : Could not resolve host: mirror.bardia.tech
error: failed retrieving file 'multilib.db' from mirrors.ustc.edu.cn : Could not resolve host: mirrors.ustc.edu.cn
error: failed retrieving file 'multilib.db' from mirror.csclub.uwaterloo.ca : Could not resolve host: mirror.csclub.uwaterloo.ca
error: failed retrieving file 'multilib.db' from mirror.archlinux.tw : Could not resolve host: mirror.archlinux.tw
error: failed retrieving file 'multilib.db' from ftp.tsukuba.wide.ad.jp : Could not resolve host: ftp.tsukuba.wide.ad.jp
error: failed retrieving file 'multilib.db' from irltoolkit.mm.fcix.net : Could not resolve host: irltoolkit.mm.fcix.net
error: failed retrieving file 'multilib.db' from manjaro.mirror.garr.it : Could not resolve host: manjaro.mirror.garr.it
error: failed retrieving file 'multilib.db' from mirror.telepoint.bg : Could not resolve host: mirror.telepoint.bg
error: failed retrieving file 'multilib.db' from mirror.is.co.za : Could not resolve host: mirror.is.co.za
error: failed retrieving file 'multilib.db' from mirror.aarnet.edu.au : Could not resolve host: mirror.aarnet.edu.au
error: failed retrieving file 'multilib.db' from mirrors.xtom.ee : Could not resolve host: mirrors.xtom.ee
error: failed retrieving file 'multilib.db' from mirrors.ocf.berkeley.edu : Could not resolve host: mirrors.ocf.berkeley.edu
error: failed retrieving file 'multilib.db' from mirrors.pku.edu.cn : Could not resolve host: mirrors.pku.edu.cn
error: failed retrieving file 'multilib.db' from repo.iut.ac.ir : Could not resolve host: repo.iut.ac.ir
error: failed retrieving file 'multilib.db' from mirrors.xtom.jp : Could not resolve host: mirrors.xtom.jp
error: failed retrieving file 'multilib.db' from manjaro.ynh.ovh : Could not resolve host: manjaro.ynh.ovh
error: failed retrieving file 'multilib.db' from mirror.funami.tech : Could not resolve host: mirror.funami.tech
error: failed retrieving file 'multilib.db' from mirrors.up.pt : Could not resolve host: mirrors.up.pt
error: failed retrieving file 'multilib.db' from manjaro.astra.in.ua : Could not resolve host: manjaro.astra.in.ua
error: failed retrieving file 'multilib.db' from osmirror.org : Could not resolve host: osmirror.org
error: failed retrieving file 'multilib.db' from mirror1.cl.netactuate.com : Could not resolve host: mirror1.cl.netactuate.com
error: failed retrieving file 'multilib.db' from www.mirrorservice.org : Could not resolve host: www.mirrorservice.org
error: failed retrieving file 'multilib.db' from mirror.nju.edu.cn : Could not resolve host: mirror.nju.edu.cn
error: failed retrieving file 'multilib.db' from mirrors.sonic.net : Could not resolve host: mirrors.sonic.net
error: failed retrieving file 'multilib.db' from mirror.cyberhost.uk : Could not resolve host: mirror.cyberhost.uk
error: failed retrieving file 'multilib.db' from mirror.init7.net : Could not resolve host: mirror.init7.net
error: failed retrieving file 'multilib.db' from mirrors.colocall.net : Could not resolve host: mirrors.colocall.net
error: failed retrieving file 'multilib.db' from mirror.datacenter.by : Could not resolve host: mirror.datacenter.by
error: failed retrieving file 'multilib.db' from mnvoip.mm.fcix.net : Could not resolve host: mnvoip.mm.fcix.net
error: failed retrieving file 'multilib.db' from manjaro.grena.ge : Could not resolve host: manjaro.grena.ge
error: failed retrieving file 'multilib.db' from ftp.linux.org.tr : Could not resolve host: ftp.linux.org.tr
error: failed retrieving file 'multilib.db' from mirror.yandex.ru : Could not resolve host: mirror.yandex.ru
error: failed retrieving file 'multilib.db' from ftp.dei.uc.pt : Could not resolve host: ftp.dei.uc.pt
error: failed retrieving file 'multilib.db' from ossmirror.mycloud.services : Could not resolve host: ossmirror.mycloud.services
error: failed to update multilib (invalid url for server)
error: failed to synchronize all databases
[manjaro-cinnamon /]# ::WARNING https://gitlab.manjaro.org '<urlopen error [Errno -2] Name or service not known>'
::WARNING https://wikipedia.org '<urlopen error [Errno -2] Name or service not known>'
::WARNING https://bitbucket.org '<urlopen error [Errno -2] Name or service not known>'
::INFO Internet connection appears to be down
::INFO Mirror ranking is not available
::INFO Mirror list is generated using random method
::INFO Writing mirror list
::Netherlands     : https://manjaro.mirrors.lavatech.top/stable
::Hungary         : https://quantum-mirror.hu/mirrors/pub/manjaro/stable
::Uruguay         : https://manjaro.repo.cure.edu.uy/stable
::United_States   : https://repo.ialab.dsu.edu/manjaro/stable
::Spain           : https://mirrors.ft.uam.es/manjaro/stable
::United_States   : https://uvermont.mm.fcix.net/manjaro/stable
::United_States   : https://coresite.mm.fcix.net/manjaro/stable
::Italy           : https://ct.mirror.garr.it/mirrors/manjaro/stable
::Chile           : https://mirror.ufro.cl/manjaro/stable
::Sweden          : https://mirror.zetup.net/manjaro/stable
::Bulgaria        : https://mirror.telepoint.bg/manjaro/stable
::Iran            : https://repo.iut.ac.ir/repo/manjaro/stable
::Costa_Rica      : https://mirrors.ucr.ac.cr/manjaro/stable
::China           : https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable
::United_States   : https://codingflyboy.mm.fcix.net/manjaro/stable
::Austria         : https://mirror.alwyzon.net/manjaro/stable
::Bangladesh      : https://bd.mirror.vanehost.com/Manjaro/stable
::Japan           : https://mirrors.xtom.jp/manjaro/stable
::Singapore       : http://ossmirror.mycloud.services/os/linux/manjaro/stable
::Bangladesh      : http://mirror.xeonbd.com/manjaro/stable
::Brazil          : https://manjaro.c3sl.ufpr.br/stable
::Ukraine         : https://fastmirror.pp.ua/manjaro/stable
::South_Korea     : https://mirror.funami.tech/manjaro/stable
::Georgia         : https://repos.silknet.com/manjaro/stable
::Portugal        : http://ftp.dei.uc.pt/pub/linux/manjaro/stable
::Kenya           : https://manjaro.mirror.liquidtelecom.com/stable
::New_Zealand     : https://mirror.2degrees.nz/manjaro/stable
::Sweden          : https://ftp.lysator.liu.se/pub/manjaro/stable
::Canada          : https://mirror.csclub.uwaterloo.ca/manjaro/stable
::Italy           : https://ba.mirror.garr.it/mirrors/manjaro/stable
::Norway          : http://mirror.terrahost.no/linux/manjaro/stable
::Germany         : https://ftp.halifax.rwth-aachen.de/manjaro/stable
::Australia       : https://manjaro.lucassymons.net/stable
::France          : http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable
::Canada          : https://muug.ca/mirror/manjaro/stable
::United_Kingdom  : https://mirror.cyberhost.uk/sites/manjaro/stable
::Thailand        : https://mirror.kku.ac.th/manjaro/stable
::Austria         : https://mirror.easyname.at/manjaro/stable
::France          : https://manjaro.ynh.ovh/stable
::Global          : https://mirrors.manjaro.org/repo/stable
::Netherlands     : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable
::Russia          : https://mirror.kamtv.ru/manjaro/stable
::Germany         : https://mirror.informatik.tu-freiberg.de/manjaro/stable
::Ukraine         : http://mirrors.colocall.net/manjaro/stable
::China           : https://mirrors.ustc.edu.cn/manjaro/stable
::Germany         : https://mirror.netcologne.de/manjaro/stable
::Germany         : https://ftp.gwdg.de/pub/linux/manjaro/stable
::Poland          : https://ftp.icm.edu.pl/pub/Linux/dist/manjaro/stable
::Portugal        : https://mirrors.up.pt/pub/manjaro/stable
::China           : https://mirrors.pku.edu.cn/manjaro/stable
::Switzerland     : https://mirror.init7.net/manjaro/stable
::United_Kingdom  : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable
::Germany         : https://mirror.moson.org/manjaro/stable
::United_States   : https://irltoolkit.mm.fcix.net/manjaro/stable
::Japan           : http://ftp.riken.jp/Linux/manjaro/stable
::United_States   : https://mirror2.sandyriver.net/pub/manjaro/stable
::Czechia         : https://mirrors.nic.cz/manjaro/stable
::Australia       : https://mirror.aarnet.edu.au/pub/manjaro/stable
::India           : https://mirror.albony.xyz/manjaro/stable
::Belgium         : http://ftp.belnet.be/mirrors/manjaro/repos/stable
::Belgium         : https://mirror.futureweb.be/manjaro/stable
::Germany         : https://mirror.tarnkappe.info/manjaro/stable
::Netherlands     : https://mirror.koddos.net/manjaro/stable
::Czechia         : https://mirror.dkm.cz/manjaro/stable
::Greece          : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable
::Russia          : https://mirror.truenetwork.ru/manjaro/stable
::Philippines     : http://mirror.rise.ph/manjaro/stable
::United_States   : https://mirrors.sonic.net/manjaro/stable
::United_States   : https://forksystems.mm.fcix.net/manjaro/stable
::Chile           : http://manjaro.dcc.uchile.cl/stable
::Georgia         : http://manjaro.grena.ge/stable
::Sweden          : https://ftpmirror1.infania.net/mirror/manjaro/stable
::United_States   : https://ziply.mm.fcix.net/manjaro/stable
::China           : https://mirror.nju.edu.cn/manjaro/stable
::Spain           : https://ftp.caliu.cat/pub/distribucions/manjaro/stable
::United_States   : https://mirror.math.princeton.edu/pub/manjaro/stable
::Turkey          : http://ftp.linux.org.tr/manjaro/stable
::Ukraine         : https://manjaro.astra.in.ua/stable
::Chile           : https://mirror1.cl.netactuate.com/manjaro/stable
::Canada          : https://osmirror.org/manjaro/stable
::United_States   : https://mirrors.ocf.berkeley.edu/manjaro/stable
::United_States   : https://ridgewireless.mm.fcix.net/manjaro/stable
::Estonia         : https://mirrors.xtom.ee/manjaro/stable
::Germany         : https://mirror.23m.com/manjaro/stable
::Netherlands     : http://ftp.snt.utwente.nl/pub/linux/manjaro/stable
::United_Kingdom  : https://mirrors.gethosted.online/manjaro/repos/stable
::Poland          : https://ftp.psnc.pl/linux/manjaro/stable
::United_Kingdom  : http://manjaro.mirrors.uk2.net/stable
::Belarus         : http://mirror.datacenter.by/pub/mirrors/manjaro/stable
::South_Africa    : http://manjaro.mirror.ac.za/stable
::Germany         : https://mirrors.xtom.de/manjaro/stable
::South_Africa    : http://mirror.is.co.za/mirrors/manjaro.org/stable
::Canada          : https://mirror.xenyth.net/manjaro/stable
::Japan           : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable
::Italy           : https://manjaro.mirror.garr.it/manjaro/stable
::Global          : https://mirrors.fossho.st/manjaro/stable
::Bulgaria        : https://manjaro.ipacct.com/manjaro/stable
::Germany         : http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable
::Denmark         : https://mirrors.dotsrc.org/manjaro/stable
::Germany         : https://mirror.alpix.eu/manjaro/stable
::Poland          : https://repo.skni.umcs.pl/manjaro/stable
::China           : https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable
::China           : https://mirrors.huaweicloud.com/manjaro/stable
::Taiwan          : https://mirror.archlinux.tw/Manjaro/stable
::United_States   : https://mnvoip.mm.fcix.net/manjaro/stable
::Bulgaria        : https://mirrors.netix.net/manjaro/stable
::Iran            : https://mirror.bardia.tech/manjaro/stable
::United_States   : http://mirror.fcix.net/manjaro/stable
::Switzerland     : https://manjaro.osmir.ch/stable
::Singapore       : https://download.nus.edu.sg/mirror/manjaro/stable
::Russia          : https://mirror.yandex.ru/mirrors/manjaro/stable
::Finland         : https://manjaro.kyberorg.fi/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
[1]+  Done                    pacman-mirrors -f 5
[manjaro-cinnamon /]# grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Installing for x86_64-efi platform.
Installation finished. No error reported.
[manjaro-cinnamon /]# mkinitcpio -P && update-grub
==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: 'default'
  -> -k /boot/vmlinuz-4.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-x86_64.img
==> Starting build: 4.14.225-1-MANJARO
  -> Running build hook: [base]
  -> Running build hook: [udev]
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: 'fallback'
  -> -k /boot/vmlinuz-4.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'default'
  -> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64.img
==> Starting build: 5.9.16-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'fallback'
  -> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.9-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.9-x86_64.img
Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
Found linux image: /boot/vmlinuz-4.14-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.14-x86_64.img
Found initrd fallback image: /boot/initramfs-4.14-x86_64-fallback.img
It's output will be used to detect bootable binaries on them and create new boot entries.
grub-probe: error: cannot find a GRUB drive for /dev/sdb1.  Check your device.map.
done
Mod note: Reformatted your console output for readability.
first exit chroot:
exit
then make sure you are connected to internet, chroot again and uninstall the dead kernels:
pacman -R linux414 linux59
then rerun the update again:
pacman-mirrors -f 5 && pacman -Syyu
and post the output from this update command here
aw hell. Hang on. I think I know part of the problem
the problem is the dead kernels + probably partially updated your system… so first remove the kernels, rerun the update again, and post the output here, and if its without errors, and you are up to date, we install the 5.15 kernel and that should do it…
Yes I had caught that internet connection down when I was scrolling through. I have a switch and it had flipped off.
So I should remove both kernels as root? wooh.
well if you say so.
I hope I don’t regret this lol
mhwd-kernel -r linux414 linux59
Inside the chroot you are root. :wink:
It won’t allow me to remove the kernels. It says they will break dependencies
I’m having trouble getting the screen print.
post output
The flash drives mutinied.
OK
[manjaro-cinnamon /]# pacman -R linux414 linux59
checking dependencies…
:: removing linux414 breaks dependency ‘linux414’ required by linux414-virtualbox-host-modules
:: removing linux59 breaks dependency ‘linux59’ required by linux59-virtualbox-host-modules
so remove them too:
pacman -R linux414 linux59 linux414-virtualbox-host-modules linux59-virtualbox-host-modules
continue with the update command
[manjaro-cinnamon /]# pacman -R linux414 linux59 linux414-virtualbox-host-modules linux59-virtualbox-host-modules
:: removing linux414-virtualbox-host-modules breaks dependency ‘VIRTUALBOX-HOST-MODULES’ required by virtualbox
not sure which of those to remove, or both?
do you use virtualbox?
no. Well at one time I guess it can always be reinstalled.
I believe that was for running old games
so if you dont use it, remove it:
pacman -R linux414 linux59 linux414-virtualbox-host-modules linux59-virtualbox-host-modules virtualbox
It says its ready to remove all but ‘base optionally requires linux: bare metal support’.
Go ahead?
yes go ahead
Its all removed & running the pacman mirrors command now.
This time it is loading
Sitting here, not moving:
[manjaro-cinnamon /]# pacman-mirrors -f 5 & pacman -Syyu
[1] 3180
core 163.5 KiB 353 KiB/s 00:00 [###################################################] 100%
extra 1857.9 KiB 2.36 MiB/s 00:01 [###################################################] 100%
community 7.5 MiB 3.54 MiB/s 00:02 [###################################################] 100%
multilib 169.4 KiB 3.85 MiB/s 00:00 [###################################################] 100%
:: Starting full system upgrade…
:: Replace at-spi2-atk with extra/at-spi2-core? [Y/n] ::INFO Downloading mirrors from repo.manjaro.org
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
1.794 Georgia : Index of /manjaro/
1.560 Georgia : Index of /manjaro/
… Norway : Index of /linux/manjaro/
1.877 Turkey : Index of /manjaro/
… Turkey : ftp://ftp.linux.org.tr/manjaro/
… Brazil : https://mirror.ufam.edu.br/manjaro/
… China : manjaro
::Georgia : Index of /manjaro/stable/
::Turkey : Index of /manjaro/stable/
::Norway : Index of /linux/manjaro/stable/
::Brazil : https://mirror.ufam.edu.br/manjaro/stable
::China : stable
