hello to everybody
had a bit of issues with most of my machines with the last major update, but with the 2 laptops are mostly over or minor. I was away when I did the updates on those, came back and updated my wife’s desktop pc and as usual if something most go fully wrong it’s not with the machine(s) I use…
Now the pc does boot, but there’s no communication to the monitor, it’s dead, just as if I switch it on but the pc is still off, same with the hdmi connected TV.
If I boot with a live nothing on the monitor, but the TV will work… and after a couple of minutes the monitor starts working too.
This is what I get if I run inxi -Fza:
Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=it tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_212PRE1 quiet
systemd.show_status=1 apparmor=1 security=apparmor driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME H310-PLUS R2.0 v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 1605 date: 07/14/2020
Info: Quad Core model: Intel Core i3-9100F bits: 64 type: MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
bogomips: 28808
Speed: 800 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: ZOTAC driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:128b class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1280x1024 s-dpi: 96 s-size: 339x271mm (13.3x10.7")
s-diag: 434mm (17.1")
Monitor-1: HDMI-1 res: 1280x1024 hz: 60 dpi: 47
size: 698x392mm (27.5x15.4") diag: 801mm (31.5")
Monitor-2: VGA-1 res: 1280x1024 dpi: 80 size: 408x255mm (16.1x10.0")
diag: 481mm (18.9")
OpenGL: renderer: NV106 v: 4.3 Mesa 21.2.5 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ZOTAC driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 05:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: d000
bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-9:5 chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 133.57 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 model: 128GB PCS 2.5 SSD size: 119.24 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 0A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer Blade
size: 14.33 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
Message: No partition data found.
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 43.0 C
Processes: 222 Uptime: 9m wakeups: 0 Memory: 31.3 GiB
used: 1.88 GiB (6.0%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: N/A Packages: pacman: 1136 lib: 311 flatpak: 0 Shell: Bash v: 5.1.8
running-in: xfce4-terminal inxi: 3.3.08
Kernel on the pc is 5.13 something that could be part of the problem maybe?
How can I sort this? I realize there are somewhat similar threads in the forum, but I’ve got quite confused by what I’ve read so far, and haven’t been able to do much
I guess I should manjaro-chroot -a then possibly install a more updated kernel? And? Or? Thanks a lot!
