PC stopped asking for system decryption password
Hi. A few weeks ago I switched into testing. I’ve used Arch in another computer for a decade so I thought it would be fine.
Today my computer was crashing when booting. I suspected it was related to NVidia, so decided to undo yesterday’s update. I installed the previous versions of
lib32-nvidia-utils-570.153.02-1  libxnvctrl-570.153.02-1  linux61-6.1.139-1  linux61-headers-6.1.139-1  linux61-nvidia-570.153.02-1
linux61-virtualbox-host-modules-7.1.8-7  mhwd-nvidia-570.153.02-1  nvidia-settings-570.153.02-1  nvidia-utils-570.153.02-1
opencl-nvidia-570.153.02-1
It still wouldn’t boot, so I spent 5 or 6 hours rebooting and chrooting. The boot partition was full. After many tries, the computer now boots but the strange thing is that it does not ask for a disk decryption key. The disk is btrfs and uses LUKS.
I think the only thing I did was to run mkinitcpio -P, grub-mkconfig and grub-install.
How can I make the computer unbootable again without the decryption key?
Something else which I don’t remember seeing before is the mount point being /var/cache. Isn’t that odd?
$ lsblk -a -fs
NAME                                      FSTYPE      FSVER LABEL    UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
luks-b0a35949-1ae3-43bb-9d72-???????????? btrfs                      d7fa9c05-d68f-4aaf-94a9-xxxxxxxxxxxx                /var/cache
└─nvme0n1p2                               crypto_LUKS 1              b0a35949-1ae3-43bb-9d72-????????????
  └─nvme0n1
nvme0n1p1                                 vfat        FAT32 NO_LABEL FCE9-????                             115,1M    62% /boot/efi
└─nvme0n1
Thank you!
I’m afraid I cannot help you with the LUKS thing, but if you accepted the defaults for a btrfs installation, then you should have four btrfs subvolumes…:
  • @ — mounted at /
  • @home — mounted at /home
  • @cache — mounted at /var/cache
  • @log — mounted at /var/log
The idea behind this layout — which I personally do not support, mind you — is that timeshift would only create snapshots of the @ subolume, so that you would still be able to inspect the logs in /var/log after rolling back a snapshot, and because anything in /var/cache is expendable and replaceable.
And the contents of /home should of course be independent from operating system snapshots.
Thank you for your answer. I do not use timeshift.
And I managed to fix it
I compared the /boot/ folder from broken system with another working one, noticed several nested efi or EFI folders, so I deleted those folders and repeated the mkinitcpio and grub commands and now it works as expected.
I still would like to understand how is it possible that the system was booting without prompting a password if the disk is encrypted. Makes me worried about how safe it is.
