doj
July 2, 2021, 9:18pm
1
I was installing chromium and it said:
chromium: error while loading shred libraries: libicui18n.so.69
So I updated libicu to 69 and rebooted my pc
When I rebooted I see: [FAILED] Failed to start Simple Desktop Display Manager.
I am able to use tty2
And now I can’t use my pc, please help!
Did you just do a partial update?
That won’t work - always update all packages at the same time:
$ sudo pacman -Syu
@freggel.doe just beat me to it.
Keep in mind partial upgrades are not supported and will cause breakages just like you encountered. See: System Maintenance - Manjaro
doj
July 2, 2021, 9:39pm
4
I wrote sudo pacman -Syu but it says failed to get file multilib.db
Sounds like you have mirrors that are out of sync and/or your database is out of date or corrupt. This will use the 5 of the fastest mirrors and force a sync:
sudo pacman-mirrors -f5 && sudo pacman -Syyu
Please post full outputs of commands you’re running that generate errors.
doj
July 2, 2021, 9:59pm
6
When I run sudo pacman-mirrors -f5
it lists a list of countries.
When I run sudo pacman -Syyu
it says could not sync all databases
Please help us help you by posting the full output as I asked.
This may be helpful for posting output from the TTY:
Sometimes we might want to easily share terminal output.
While this can be accomplished directly in the forums or manually through websites like pastebin, there also exist a number of open services that allow you to paste and share directly from the command line by using tools you already have installed.
This is great for many situations, including troubleshooting from a non-graphical boot, or simply very large outputs. Here I will share a few examples and how to use them.
Services and Exampl…
doj
July 2, 2021, 10:10pm
8
Oh ok, so when I start it says it failed to start sddm. When I run startplasma-x11 it says error while loading shared libraries libicui18n.so.68 cannot open chared object file no such file or directory.
Perhaps you’re not realizing it, but
$ sudo pacman -Syu
not working is actually worse than your initial problem.
Please post the exact error message this command produced, like you were asked before.
doj
July 2, 2021, 10:59pm
10
Idk what I did different but when I run it now it says
error: failed to commit transaction (conflicting files)
plasma-workspace: /usr/share/locale/ta/LC_MESSAGES/kcm_autostart.mo
exists in filesystem (owned by plasma-desktop-primex)
snapd: /snap already exists
errors occurred, no packages were upgraded.
Ok, if the /snap
directory has contents, move it out of they way for the time being, else remove it.
Updating should be possible after that:
$ sudo mv /snap /snap.we-will-deal-with-this-later
$ sudo pacman -Syu --overwrite '/usr/share/locale/ta/LC_MESSAGES/kcm_autostart.mo'
If updating worked, then you can restore the previous /snap
directory (if it had contents):
$ sudo rmdir /snap && sudo mv /snap.we-will-deal-with-this-later /snap
doj
July 3, 2021, 1:15am
12
This worked, thank you so much!
system
Closed
July 18, 2021, 1:15am
13
