Hey guys! I’m having a problem where my computer keeps crashing and rebooting in random moments. Just to give some context here: I have been using this DELL keyboard and mouse with no problems except for keys repeating and mouse lagging (2 devices, 1 dongle), did some search on the internet and found out to be the 5GHz wifi interfering, ok no problem, switched to a wired keyboard and mouse, then my computer started rebooting in random moments, have been using my computer for about 4 hours and it rebooted like eight times. There’s a lot of systemd erros for WHATEVER the application I open, firefox tabs keep crashing, if I try to play any game on steam it also crashes after a while. Here are some logs that I took from journalctl. I don’t have too much knowledge on Linux so feel free to ask for more information.
inxi -Fxz
Kernel: 6.8.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: GNOME v: 45.4 Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-GAMING/BR v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2006
date: 11/13/2019
Info: 6-core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ rev: 2
cache: L1: 576 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 1435 high: 1739 min/max: 1550/3850 boost: disabled
cores: 1: 1374 2: 1550 3: 1273 4: 1377 5: 1377 6: 1378 7: 1576 8: 1281
9: 1739 10: 1377 11: 1550 12: 1377 bogomips: 92429
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel arch: GCN-4 bus-ID: 08:00.0
temp: 50.0 C
Device-2: A4Tech REDRAGON Live Camera driver: uvcvideo type: USB
bus-ID: 3-3:3
Display: x11 server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4 driver:
X: loaded: amdgpu unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu
resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: radeonsi,swrast platforms:
active: x11,surfaceless,device inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 570 Series (radeonsi
polaris10 LLVM 16.0.6 DRM 3.57 6.8.0-1-MANJARO)
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 08:00.1
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0a:00.3
Device-3: FIFINE Microphones K670 Microphone
driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 3-1:2
Device-4: A4Tech REDRAGON Live Camera driver: uvcvideo type: USB
bus-ID: 3-3:3
API: ALSA v: k6.8.0-1-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.0.3 status: active
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB bus-ID: 1-4:4
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1
lmp-v: 10
Local Storage: total: 447.13 GiB used: 212.33 GiB (47.5%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
ID-1: / size: 438.75 GiB used: 212.33 GiB (48.4%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat
dev: /dev/sda1
ID-1: swap-1 type: file size: 18 GiB used: 0 KiB (0.0%) file: /swapfile1
System Temperatures: cpu: 57.5 C mobo: N/A gpu: amdgpu temp: 50.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1124
Memory: total: 24 GiB available: 23.39 GiB used: 4.86 GiB (20.8%)
Processes: 347 Uptime: 15m Init: systemd
Packages: 1277 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
inxi: 3.3.33
Mar 29 21:53:17 manjaro bluetoothd[509]: profiles/audio/bap.c:bap_adapter_probe() BAP requires ISO Socket which is not enabled
Mar 29 21:53:17 manjaro bluetoothd[509]: bap: Operation not supported (95
Mar 29 21:53:30 manjaro bluetoothd[509]: Failed to remove UUID: Not Connected (0x02)
Mar 29 21:53:30 manjaro bluetoothd[509]: profiles/audio/a2dp.c:load_remote_sep() Unable to load LastUsed: lseid 7 not found
Mar 29 21:53:30 manjaro bluetoothd[509]: profiles/audio/a2dp.c:a2dp_select_capabilities() Unable to select SEP
Mar 29 21:53:30 manjaro bluetoothd[509]: malloc(): unaligned fastbin chunk detected 3
Mar 29 21:53:30 manjaro systemd[1]: Created slice Slice /system/systemd-coredump.
Mar 29 21:53:30 manjaro systemd[1]: Started Process Core Dump (PID 1258/UID 0).
Mar 29 21:53:31 manjaro systemd-coredump[1259]: [🡕] Process 509 (bluetoothd) of user 0 dumped core.
Stack trace of thread 509:
#0 0x0000763ed900b32c n/a (libc.so.6 + 0x9132c)
#1 0x0000763ed8fba6c8 raise (libc.so.6 + 0x406c8)
#2 0x0000763ed8fa24b8 abort (libc.so.6 + 0x284b8)
#3 0x0000763ed8fa3395 n/a (libc.so.6 + 0x29395)
#4 0x0000763ed90152a7 n/a (libc.so.6 + 0x9b2a7)
#5 0x0000763ed90187fc n/a (libc.so.6 + 0x9e7fc)
#6 0x0000763ed90198ea malloc (libc.so.6 + 0x9f8ea)
#7 0x0000763ed9305763 g_malloc (libglib-2.0.so.0 + 0x62763)
#8 0x0000763ed931f47f g_strndup (libglib-2.0.so.0 + 0x7c47f)
#9 0x0000763ed92f417e n/a (libglib-2.0.so.0 + 0x5117e)
#10 0x0000763ed92f455b n/a (libglib-2.0.so.0 + 0x5155b)
#11 0x0000763ed92f4851 n/a (libglib-2.0.so.0 + 0x51851)
#12 0x0000763ed92f4945 g_key_file_load_from_file (libglib-2.0.so.0 + 0x51945)
#13 0x00006042024f5f64 n/a (bluetoothd + 0xabf64)
#14 0x0000763ed92fcf69 n/a (libglib-2.0.so.0 + 0x59f69)
#15 0x0000763ed935b3a7 n/a (libglib-2.0.so.0 + 0xb83a7)
#16 0x0000763ed92fdb97 g_main_loop_run (libglib-2.0.so.0 + 0x5ab97)
#17 0x000060420246ee52 n/a (bluetoothd + 0x24e52)
#18 0x0000763ed8fa3cd0 n/a (libc.so.6 + 0x29cd0)
#19 0x0000763ed8fa3d8a __libc_start_main (libc.so.6 + 0x29d8a)
#20 0x000060420246ffb5 n/a (bluetoothd + 0x25fb5)
Mar 29 21:55:55 manjaro /usr/lib/gdm-x-session[2730]: > Warning: Could not resolve keysym XF86SidevuSonar
Mar 29 21:55:55 manjaro /usr/lib/gdm-x-session[2730]: > Warning: Could not resolve keysym XF86NavInfo
Mar 29 21:55:55 manjaro /usr/lib/gdm-x-session[2730]: Errors from xkbcomp are not fatal to the X server
Mar 29 21:55:55 manjaro systemd-coredump[2692]: [🡕] Process 2517 (pamac-manager) of user 1000 dumped core.
Stack trace of thread 2633:
#0 0x00007eb460953adc n/a (libalpm.so.13 + 0x20adc)
#1 0x00007eb4609428eb n/a (libalpm.so.13 + 0xf8eb)
#2 0x00007eb46093de6c n/a (libalpm.so.13 + 0xae6c)
#3 0x00007eb46093e02f alpm_db_get_pkgcache (libalpm.so.13 + 0xb02f)
#4 0x00007eb4616a5ca3 n/a (libpamac.so.11 + 0x30ca3)
#5 0x00007eb4616b0032 n/a (libpamac.so.11 + 0x3b032)
#6 0x00007eb4616b04a1 n/a (libpamac.so.11 + 0x3b4a1)
#7 0x00007eb461966a45 n/a (libglib-2.0.so.0 + 0x8ba45)
#8 0x00007eb46151e55a n/a (libc.so.6 + 0x8f55a)
#9 0x00007eb46159ba3c n/a (libc.so.6 + 0x10ca3c)
Stack trace of thread 2517:
#0 0x00007eb46192286f g_hash_table_replace (libglib-2.0.so.0 + 0x4786f)
#1 0x00007eb461ec11ff n/a (libgtk-4.so.1 + 0x2c11ff)
#2 0x00007eb461ec1826 n/a (libgtk-4.so.1 + 0x2c1826)
#3 0x00007eb461ec1826 n/a (libgtk-4.so.1 + 0x2c1826)
#4 0x00007eb461ec1826 n/a (libgtk-4.so.1 + 0x2c1826)
#5 0x00007eb461ec1826 n/a (libgtk-4.so.1 + 0x2c1826)
#6 0x00007eb461ec1826 n/a (libgtk-4.so.1 + 0x2c1826)
#7 0x00007eb461ec1826 n/a (libgtk-4.so.1 + 0x2c1826)
#8 0x00007eb461ec1826 n/a (libgtk-4.so.1 + 0x2c1826)
#9 0x00007eb461ec1826 n/a (libgtk-4.so.1 + 0x2c1826)
#10 0x00007eb461ec1826 n/a (libgtk-4.so.1 + 0x2c1826)
#11 0x00007eb461ec4e7f n/a (libgtk-4.so.1 + 0x2c4e7f)
#12 0x00007eb461d005c9 n/a (libgtk-4.so.1 + 0x1005c9)
#13 0x00007eb461d010e8 gtk_css_provider_load_from_file (libgtk-4.so.1 + 0x1010e8)
#14 0x00007eb461d01195 gtk_css_provider_load_from_path (libgtk-4.so.1 + 0x101195)
#15 0x00007eb461d01405 gtk_css_provider_load_named (libgtk-4.so.1 + 0x101405)
#16 0x00007eb461de9e2b n/a (libgtk-4.so.1 + 0x1e9e2b)
#17 0x00007eb461dea4e9 gtk_settings_get_for_display (libgtk-4.so.1 + 0x1ea4e9)
#18 0x00007eb461d5be43 n/a (libgtk-4.so.1 + 0x15be43)
#19 0x00007eb461d5c13b gtk_icon_theme_get_for_display (libgtk-4.so.1 + 0x15c13b)
#20 0x00007eb461cbfa02 n/a (libgtk-4.so.1 + 0xbfa02)
#21 0x000063ac744a1f02 n/a (pamac-manager + 0x25f02)
#22 0x00007eb4624efb73 n/a (libgobject-2.0.so.0 + 0x33b73)
#23 0x00007eb4624efc77 g_signal_emit_valist (libgobject-2.0.so.0 + 0x33c77)
#24 0x00007eb4624efd34 g_signal_emit (libgobject-2.0.so.0 + 0x33d34)
#25 0x00007eb461b06205 g_application_register (libgio-2.0.so.0 + 0xdf205)
#26 0x00007eb461b067c0 n/a (libgio-2.0.so.0 + 0xdf7c0)
#27 0x00007eb461b06afc g_application_run (libgio-2.0.so.0 + 0xdfafc)
#28 0x000063ac744893cb n/a (pamac-manager + 0xd3cb)
#29 0x00007eb4614b8cd0 n/a (libc.so.6 + 0x29cd0)
#30 0x00007eb4614b8d8a __libc_start_main (libc.so.6 + 0x29d8a)
#31 0x000063ac744894f5 n/a (pamac-manager + 0xd4f5)
Stack trace of thread 2634:
#0 0x00007eb46196f28f g_utf8_validate_len (libglib-2.0.so.0 + 0x9428f)
#1 0x00007eb46064a249 n/a (libjson-glib-1.0.so.0 + 0x1c249)
#2 0x00007eb46064b5ce json_parser_load_from_data (libjson-glib-1.0.so.0 + 0x1d5ce)
#3 0x00007eb45d1b7484 n/a (libpamac-aur.so + 0x7484)
#4 0x00007eb45d1b7b51 n/a (libpamac-aur.so + 0x7b51)
#5 0x00007eb4616b053a n/a (libpamac.so.11 + 0x3b53a)
#6 0x00007eb4616b0881 n/a (libpamac.so.11 + 0x3b881)
Stack trace of thread 2534:
#0 0x00007eb46158e0bf __poll (libc.so.6 + 0xff0bf)
#1 0x00007eb4619932f6 n/a (libglib-2.0.so.0 + 0xb82f6)
#2 0x00007eb461935b97 g_main_loop_run (libglib-2.0.so.0 + 0x5ab97)
#3 0x00007eb461b3919c n/a (libgio-2.0.so.0 + 0x11219c)
#4 0x00007eb461966a45 n/a (libglib-2.0.so.0 + 0x8ba45)
#5 0x00007eb46151e55a n/a (libc.so.6 + 0x8f55a)
#6 0x00007eb46159ba3c n/a (libc.so.6 + 0x10ca3c)
Stack trace of thread 2532:
#0 0x00007eb46159988d syscall (libc.so.6 + 0x10a88d)
#1 0x00007eb46198e337 g_cond_wait (libglib-2.0.so.0 + 0xb3337)
#2 0x00007eb4619001b4 n/a (libglib-2.0.so.0 + 0x251b4)
#3 0x00007eb461968ace n/a (libglib-2.0.so.0 + 0x8dace)
Stack trace of thread 2635:
#3 0x00007eb46190021c g_async_queue_pop (libglib-2.0.so.0 + 0x2521c)
#4 0x00007eb460e53c48 n/a (libpangoft2-1.0.so.0 + 0x8c48)
#5 0x00007eb461966a45 n/a (libglib-2.0.so.0 + 0x8ba45)
#6 0x00007eb46151e55a n/a (libc.so.6 + 0x8f55a)
#7 0x00007eb46159ba3c n/a (libc.so.6 + 0x10ca3c)
Stack trace of thread 2683:
#0 0x00007eb46151aebe n/a (libc.so.6 + 0x8bebe)
#1 0x00007eb46151d750 pthread_cond_wait (libc.so.6 + 0x8e750)
#2 0x00007eb451d021fc n/a (radeonsi_dri.so + 0x1021fc)
#3 0x00007eb451d18f0c n/a (radeonsi_dri.so + 0x118f0c)
#4 0x00007eb46151e55a n/a (libc.so.6 + 0x8f55a)
#5 0x00007eb46159ba3c n/a (libc.so.6 + 0x10ca3c)
Stack trace of thread 2533:
#2 0x00007eb461933162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
#3 0x00007eb4619331b2 n/a (libglib-2.0.so.0 + 0x581b2)
Stack trace of thread 2684:
Stack trace of thread 2685:
Stack trace of thread 2689:
Stack trace of thread 2690:
Stack trace of thread 2688:
Stack trace of thread 2682:
Stack trace of thread 2686:
Stack trace of thread 2687:
`Mar 29 22:01:52 manjaro systemd-coredump[8220]: [🡕] Process 8038 (pamac-manager) of user 1000 dumped core.
Stack trace of thread 8038:
#0 0x000078cf49b2032c n/a (libc.so.6 + 0x9132c)
#1 0x000078cf49acf6c8 raise (libc.so.6 + 0x406c8)
#2 0x000078cf49ab74b8 abort (libc.so.6 + 0x284b8)
#3 0x000078cf49ab8395 n/a (libc.so.6 + 0x29395)
#4 0x000078cf49b2a2a7 n/a (libc.so.6 + 0x9b2a7)
#5 0x000078cf49b2af9c n/a (libc.so.6 + 0x9bf9c)
#6 0x000078cf49b2bfdd n/a (libc.so.6 + 0x9cfdd)
#7 0x000078cf49b2c669 n/a (libc.so.6 + 0x9d669)
#8 0x000078cf49b2ee93 __libc_free (libc.so.6 + 0x9fe93)
#9 0x000078cf49f1eed5 n/a (libglib-2.0.so.0 + 0x43ed5)
#10 0x000078cf49f23044 g_hash_table_unref (libglib-2.0.so.0 + 0x48044)
#11 0x000078cf474bd0b8 n/a (libpamac-aur.so + 0x60b8)
#12 0x000078cf4aa818b4 g_object_unref (libgobject-2.0.so.0 + 0x228b4)
#13 0x000078cf49cc0171 n/a (libpamac.so.11 + 0x4b171)
#14 0x000078cf4aa818b4 g_object_unref (libgobject-2.0.so.0 + 0x228b4)
#15 0x000064e9c10a33ee n/a (pamac-manager + 0xd3ee)
#16 0x000078cf49ab8cd0 n/a (libc.so.6 + 0x29cd0)
#17 0x000078cf49ab8d8a __libc_start_main (libc.so.6 + 0x29d8a)
#18 0x000064e9c10a34f5 n/a (pamac-manager + 0xd4f5)
Stack trace of thread 8057:
#0 0x000078cf49b8e0bf __poll (libc.so.6 + 0xff0bf)
#1 0x000078cf49f932f6 n/a (libglib-2.0.so.0 + 0xb82f6)
#2 0x000078cf49f33162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
#3 0x000078cf49f331b2 n/a (libglib-2.0.so.0 + 0x581b2)
#4 0x000078cf49f66a45 n/a (libglib-2.0.so.0 + 0x8ba45)
#5 0x000078cf49b1e55a n/a (libc.so.6 + 0x8f55a)
#6 0x000078cf49b9ba3c n/a (libc.so.6 + 0x10ca3c)
Stack trace of thread 8058:
#2 0x000078cf49f35b97 g_main_loop_run (libglib-2.0.so.0 + 0x5ab97)
#3 0x000078cf4a13919c n/a (libgio-2.0.so.0 + 0x11219c)
Stack trace of thread 8162:
#0 0x000078cf49b1aebe n/a (libc.so.6 + 0x8bebe)
#1 0x000078cf49b1d750 pthread_cond_wait (libc.so.6 + 0x8e750)
#2 0x000078cf39d021fc n/a (radeonsi_dri.so + 0x1021fc)
#3 0x000078cf39d18f0c n/a (radeonsi_dri.so + 0x118f0c)
#4 0x000078cf49b1e55a n/a (libc.so.6 + 0x8f55a)
#5 0x000078cf49b9ba3c n/a (libc.so.6 + 0x10ca3c)
Stack trace of thread 8166:
Stack trace of thread 8167:
Stack trace of thread 8169:
Stack trace of thread 8056:
#0 0x000078cf49b9988d syscall (libc.so.6 + 0x10a88d)
#1 0x000078cf49f8e337 g_cond_wait (libglib-2.0.so.0 + 0xb3337)
#2 0x000078cf49f001b4 n/a (libglib-2.0.so.0 + 0x251b4)
#3 0x000078cf49f68ace n/a (libglib-2.0.so.0 + 0x8dace)
Stack trace of thread 8170:
Stack trace of thread 8164:
Stack trace of thread 8165:
Stack trace of thread 8180:
#1 0x000078cf49f8ed13 g_cond_wait_until (libglib-2.0.so.0 + 0xb3d13)
#2 0x000078cf49f00185 n/a (libglib-2.0.so.0 + 0x25185)
#3 0x000078cf49f002e7 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x252e7)
#4 0x000078cf49f693be n/a (libglib-2.0.so.0 + 0x8e3be)
#5 0x000078cf49f66a45 n/a (libglib-2.0.so.0 + 0x8ba45)
#6 0x000078cf49b1e55a n/a (libc.so.6 + 0x8f55a)
#7 0x000078cf49b9ba3c n/a (libc.so.6 + 0x10ca3c)
Stack trace of thread 8168:
Stack trace of thread 8163:
Stack trace of thread 8138:
#3 0x000078cf49f0021c g_async_queue_pop (libglib-2.0.so.0 + 0x2521c)
#4 0x000078cf493eec48 n/a (libpangoft2-1.0.so.0 + 0x8c48)
ELF object binary architecture: AMD x86-64`
Mar 29 22:12:46 manjaro systemd-coredump[6672]: [🡕] Process 6601 (zsh) of user 1000 dumped core.
Stack trace of thread 6601:
#0 0x0000634f2f196107 n/a (zsh + 0x63107)
#1 0x0000634f2f19a916 deletejob (zsh + 0x67916)
#2 0x0000634f2f19cf90 printjob (zsh + 0x69f90)
#3 0x0000634f2f19db4e n/a (zsh + 0x6ab4e)
#4 0x0000634f2f1dc7c1 wait_for_processes (zsh + 0xa97c1)
#5 0x0000634f2f1dbc46 zhandler (zsh + 0xa8c46)
#6 0x00007417ec30d770 n/a (libc.so.6 + 0x40770)
#7 0x00007417ec2370bd n/a (complist.so + 0x40bd)
#8 0x00007417ec6520e2 n/a (ld-linux-x86-64.so.2 + 0x10e2)
#9 0x00007417ec655ffe n/a (ld-linux-x86-64.so.2 + 0x4ffe)
#10 0x00007417ec30fb36 n/a (libc.so.6 + 0x42b36)
#11 0x00007417ec30fc80 exit (libc.so.6 + 0x42c80)
#12 0x0000634f2f162616 zexit (zsh + 0x2f616)
#13 0x0000634f2f1dbe75 zhandler (zsh + 0xa8e75)
#14 0x00007417ec30d770 n/a (libc.so.6 + 0x40770)
#15 0x00007417ec30da29 __sigsuspend (libc.so.6 + 0x40a29)
#16 0x0000634f2f19eadf n/a (zsh + 0x6badf)
#17 0x0000634f2f19ebd4 waitjobs (zsh + 0x6bbd4)
#18 0x0000634f2f1740c2 n/a (zsh + 0x410c2)
#19 0x0000634f2f175646 execlist (zsh + 0x42646)
#20 0x0000634f2f175e3e execode (zsh + 0x42e3e)
#21 0x0000634f2f1942af loop (zsh + 0x612af)
#22 0x0000634f2f19be05 zsh_main (zsh + 0x68e05)
#23 0x0000634f2f14a0de main (zsh + 0x170de)
#24 0x00007417ec2f6cd0 n/a (libc.so.6 + 0x29cd0)
#25 0x00007417ec2f6d8a __libc_start_main (libc.so.6 + 0x29d8a)
#26 0x0000634f2f14a105 _start (zsh + 0x17105)
