PC froze and now erratically hangs after forced shutdown at the mains
Hi all
Today my PC suddenly froze and I was forced to switch off the plug. When I restarted, there was a failure message, something about execution frozen. After manually restarting again at the power button, it went straight to BIOS.
Now that I’ve finally been able to access the system by repeated restarting, it is hanging erratically, even a long hang in writing this message as everything froze up.
Please could someone walk me through isolating and fixing the problem. Thanks.
[sudo] password for manupc:
  Kernel: 6.6.63-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=1adc77d4-359c-4d50-8e77-204cccc1b265 rw quiet apparmor=1
    security=apparmor udev.log_priority=3 ibt=off
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: light-locker dm: LightDM v: 1.32.0 Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: PRO B660M-E DDR4 (MS-7D46) v: 1.0
    serial: <filter> uuid: cc8ba569-4dc8-2116-a501-d8bbc1dfccda UEFI: American
    Megatrends LLC. v: 2.00 date: 12/27/2021
  System RAM: total: 16 GiB available: 15.48 GiB used: 1.91 GiB (12.3%)
  Array-1: capacity: 64 GiB slots: 4 modules: 1 EC: None
  Device-1: Controller0-DIMMA1 type: DDR4 detail: synchronous size: 16 GiB
    speed: 2133 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
    total: 64 manufacturer: Corsair part-no: CMK16GX4M1D3600C18 serial: N/A
  Device-2: Controller1-DIMMB1 type: no module installed
  Info: model: 12th Gen Intel Core i5-12400F socket: U3E1 bits: 64 type: MT MCP
    arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
    microcode: 0x37
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB
    desc: 6x1.2 MiB L3: 18 MiB desc: 1x18 MiB
  Speed (MHz): avg: 800 min/max: 800/4400 base/boost: 2475/4400 scaling:
    driver: intel_pstate governor: powersave volts: 0.8 V ext-clock: 100 MHz
    cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800
    10: 800 11: 800 12: 800 bogomips: 59916
    bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
    cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
    flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
    intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm
    rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap smep
    split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: NVIDIA GK208B [GeForce GT 730] vendor: ASUSTeK driver: nvidia
    v: 470.256.02 alternate: nouveau,nvidia_drm non-free: series: 470.xx+
    status: legacy-active (EOL~2024-09-xx) arch: Kepler-2 code: GKxxx
    process: TSMC 28nm built: 2012-2018 pcie: gen: 2 speed: 5 GT/s lanes: 4
    link-max: lanes: 8 bus-ID: 01:00.0 chip-ID: 10de:1287 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.14 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
    s-diag: 583mm (22.95")
  Monitor-1: Unknown-1 mapped: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
    size: 476x268mm (18.74x10.55") modes: 1920x1080
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
  Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8
    bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
  API: ALSA v: k6.6.63-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: n/a (root, process) tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
    v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1d class-ID: 0200
  Local Storage: total: 476.94 GiB used: 88.62 GiB (18.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Hikvision
    model: HS-SSD-E3000 512G size: 476.94 GiB block-size: physical: 512 B
    fw-rev: SN06738 temp: 42.9 C scheme: GPT
  SMART: yes health: PASSED on: 144d 12h cycles: 2,690
    read-units: 20,801,566 [10.6 TB] written-units: 10,928,129 [5.59 TB]
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 88.62 GiB (18.9%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2 label: N/A uuid: 1adc77d4-359c-4d50-8e77-204cccc1b265
    used: 316 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: NO_LABEL uuid: 49F1-3C7C
  Device-1: 1-7:2 info: Logitech Mouse type: mouse driver: hid-generic,usbhid
    interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
    power: 100mA chip-ID: 046d:c077 class-ID: 0301
  Hub-2: 1-9:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-3: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
  System Temperatures: cpu: 37.0 C mobo: N/A gpu: nvidia temp: 35 C
  Fan Speeds (rpm): N/A
  Processes: 270 Power: uptime: 20m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.18 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 256 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1461 libs: 424 tools: pamac,yay pm: flatpak
    pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
    default: Bash v: 5.2.37 running-in: xfce4-terminal inxi: 3.3.36
 [manupc@manupc-2 ~]$ mhwd-kernel -li
Currently running: 6.6.63-1-MANJARO (linux66)
   * linux510
   * linux515
   * linux61
   * linux66
journalctl -b-1 -p4 --no-pager
Dec 14 12:31:30 archlinux kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Dec 14 12:31:30 archlinux kernel: nvme nvme0: missing or invalid SUBNQN field.
Dec 14 12:31:33 manupc-2 kernel: systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Dec 14 12:31:33 manupc-2 kernel: usb: port power management may be unreliable
Dec 14 12:31:33 manupc-2 kernel: nvidia: loading out-of-tree module taints kernel.
Dec 14 12:31:33 manupc-2 kernel: nvidia: module license 'NVIDIA' taints kernel.
Dec 14 12:31:33 manupc-2 kernel: Disabling lock debugging due to kernel taint
Dec 14 12:31:33 manupc-2 kernel: nvidia: module license taints kernel.
Dec 14 12:31:33 manupc-2 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  470.256.02  Thu May  2 14:37:44 UTC 2024
Dec 14 12:31:33 manupc-2 kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Dec 14 12:31:33 manupc-2 systemd-journald[479]: File /var/log/journal/ebf5243cc0eb4919864f933cbe3fa929/system.journal corrupted or uncleanly shut down, renaming and replacing.
Dec 14 12:31:35 manupc-2 dbus-broker-launch[759]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Dec 14 12:31:36 manupc-2 dbus-broker-launch[1051]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Dec 14 12:31:36 manupc-2 dbus-broker-launch[1051]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service'
Dec 14 12:31:36 manupc-2 dbus-broker-launch[1051]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Dec 14 12:31:36 manupc-2 dbus-broker-launch[1051]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Dec 14 12:31:36 manupc-2 dbus-broker-launch[1051]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Dec 14 12:31:36 manupc-2 dbus-broker-launch[1051]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Dec 14 12:31:36 manupc-2 dbus-broker-launch[1051]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Dec 14 12:31:37 manupc-2 dbus-broker-launch[759]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Dec 14 12:31:44 manupc-2 lightdm[1082]: gkr-pam: unable to locate daemon control file
Dec 14 12:31:44 manupc-2 systemd-xdg-autostart-generator[1106]: Configuration file /home/manupc/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Dec 14 12:31:44 manupc-2 systemd-xdg-autostart-generator[1106]: Configuration file /home/manupc/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Dec 14 12:31:44 manupc-2 dbus-broker-launch[1119]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Dec 14 12:31:44 manupc-2 dbus-broker-launch[1119]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service'
Dec 14 12:31:44 manupc-2 dbus-broker-launch[1119]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Dec 14 12:31:44 manupc-2 dbus-broker-launch[1119]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Dec 14 12:31:44 manupc-2 dbus-broker-launch[1119]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Dec 14 12:31:44 manupc-2 dbus-broker-launch[1119]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Dec 14 12:31:44 manupc-2 dbus-broker-launch[1119]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Dec 14 12:31:45 manupc-2 colord[1317]: failed to get edid data: EDID length is too small
Dec 14 12:31:45 manupc-2 pulseaudio[1206]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer 'org.bluez': unit failed
Dec 14 12:31:45 manupc-2 tumblerd[1265]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Dec 14 12:31:46 manupc-2 gvfsd-trash[1480]: GFileInfo created without standard::name
Dec 14 12:31:46 manupc-2 gvfsd-trash[1480]: file ../glib/gio/gfileinfo.c: line 1698 (g_file_info_get_name): should not be reached
Dec 14 12:32:16 manupc-2 kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:b4:b0:24:52:c9:13:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=145 PROTO=2
Dec 14 12:34:21 manupc-2 kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:b4:b0:24:52:c9:13:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=763 PROTO=2
Dec 14 12:36:26 manupc-2 kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:b4:b0:24:52:c9:13:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=927 PROTO=2
Dec 14 12:37:37 manupc-2 kernel: nvme nvme0: I/O 965 (Write) QID 7 timeout, aborting
Dec 14 12:37:57 manupc-2 kernel: nvme nvme0: I/O 966 (Write) QID 7 timeout, aborting
Dec 14 12:37:57 manupc-2 kernel: nvme nvme0: I/O 967 (Write) QID 7 timeout, aborting
Dec 14 12:37:57 manupc-2 kernel: nvme nvme0: Abort status: 0x0
Dec 14 12:38:31 manupc-2 kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:b4:b0:24:52:c9:13:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=974 PROTO=2
Dec 14 12:40:36 manupc-2 kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:b4:b0:24:52:c9:13:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=1014 PROTO=2
Dec 14 12:42:41 manupc-2 kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:b4:b0:24:52:c9:13:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=1028 PROTO=2
Dec 14 12:44:46 manupc-2 kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:b4:b0:24:52:c9:13:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=1087 PROTO=2
Dec 14 12:46:34 manupc-2 kernel: nvme nvme0: I/O 350 (Write) QID 4 timeout, aborting
Dec 14 12:46:34 manupc-2 kernel: nvme nvme0: I/O 139 (Write) QID 5 timeout, aborting
Dec 14 12:46:34 manupc-2 kernel: nvme nvme0: I/O 140 (Write) QID 5 timeout, aborting
Dec 14 12:46:38 manupc-2 kernel: nvme nvme0: Abort status: 0x0
Dec 14 12:46:41 manupc-2 kernel: nvme nvme0: Abort status: 0x0
Dec 14 12:46:45 manupc-2 kernel: nvme nvme0: Abort status: 0x0
Dec 14 12:46:51 manupc-2 kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:b4:b0:24:52:c9:13:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=1139 PROTO=2
Dec 14 12:48:56 manupc-2 kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:b4:b0:24:52:c9:13:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=1157 PROTO=2
Dec 14 12:51:01 manupc-2 kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:b4:b0:24:52:c9:13:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=1212 PROTO=2
Dec 14 12:53:06 manupc-2 kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:b4:b0:24:52:c9:13:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=1311 PROTO=2
Dec 14 12:53:40 manupc-2 systemd[1099]: dbus-:1.11-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
Dec 14 12:53:40 manupc-2 systemd[1099]: xfce4-notifyd.service: Failed with result 'exit-code'.
Dec 14 12:53:40 manupc-2 systemd[1099]: xdg-desktop-portal-gtk.service: Failed with result 'exit-code'.
Dec 14 12:53:41 manupc-2 dbus-broker-launch[759]: Activation request for 'org.freedesktop.RealtimeKit1' failed.
Dec 14 12:53:41 manupc-2 xdg-desktop-por[1350]: Caught PipeWire error: connection error
Dec 14 12:53:41 manupc-2 pulseaudio[1206]: Error opening PCM device front:0: No such file or directory
Dec 14 12:53:41 manupc-2 dbus-broker-launch[759]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Dec 14 12:53:42 manupc-2 kernel: watchdog: watchdog0: watchdog did not stop!
Apologies. I need to leave the site now but I will return tomorrow. Thanks to all.
Were you able to run fsck on the partition(s)?
Probably needs an fsck.
For future reference, never just power off your computer. Enable REISUB and learn the key sequence (I keep it on a laminated note attached to my desk).
Hi cscs,
Odd, my system seems to be working fine now with me just leaving it.
But maybe fsck is important just to make sure.
How do I use fsck safely on my system? Can i do the whole system in one command? (sorry, bit of a newbie.)
Hi beermad,
Great advice, thank you! FRom now on i will use REISUB instead of just powering off.
