Hello i’m currently experiencing a problem with my manjaro installation (and with the english language so sorry in advance for my possible mistakes). While using firefox on youtube or when looking at some video streams (on discord for example), the pc start to freeze and become unresponsive. it’s all explained in this post (manjaro-freezes-sometimes-if-youtube-is-used-firefox/57961) but it has been closed since (hence why i’m making a new post).
From what i’ve seen (like armaet, the previous poster, i can’t replicate the problem well enough to provide useful information), it seems to happen randomly when video decoding.
Fearing a hardware issue, i tried the following :
- 5 consecutive memetestx86 (nothing shown and no error found)
- s.m.a.r.t test (it’s an old sdd but it is in good health)
- stress test (by stress, all of the available test always with 4 threads at least 3 time each)
- blender benchmark (in order to stress my APU)
but to no avail.
Something i’ve found curious is that the problem didn’t happened either on windows (i tried other test there in order to be sure and some occt related stress test)
or on any live usb i’ve tested (either ubuntu, lubuntu, manjaro i3 or manjaro sway).
All of them kept on during 3-4 days, while doing the harchest video decoding test i know : 1 youtube video at 1080p + 2 gameblog"dot"fr videos at 4k (this site has honestly one of the worst video player i know, even my beefy gaming computer has problems handling these videos)
i’m kinda new to this forum (the old “lurker first time poster”) so i hope i’ve followed the rules
thanks in advance
here is my inxi output :
Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=b459569f-9fdf-42ea-bfe1-e019aa921cde rw quiet apparmor=1
Desktop: sway v: 1.7 info: waybar vt: 2 dm: greetd Distro: Manjaro Linux
base: Arch Linux
Type: Desktop System: LENOVO product: 10J0S2CH00 v: ThinkCentre M700
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: LENOVO model: 30D2 v: SDK0J40697 WIN 3305028826571
serial: <superuser required> UEFI: LENOVO v: FWKTBFA date: 06/23/2022
ID-1: hidpp_battery_0 charge: 62% condition: N/A volts: 3.9 min: N/A
model: Logitech G903 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: discharging
RAM: total: 7.65 GiB used: 3.41 GiB (44.6%)
RAM Report: missing: Required tool dmidecode not installed. Check
--recommends
Info: model: Intel Core i3-6100T bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 level: v3 built: 2015 process: Intel 14nm family: 6
model-id: 0x5E (94) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1736 high: 2361 min/max: 800/3200 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 1747 3: 1936
4: 2361 bogomips: 25610
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 530 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: DP-2,DP-3
empty: DP-1, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:1912 class-ID: 0300
Display: wayland server: Xwayland v: 22.1.3 compositor: sway v: 1.7
driver: gpu: i915 d-rect: 4000x1440 display-ID: 1
Monitor-1: DP-2 pos: right model: Samsung C27JG5x serial: <filter>
built: 2019 res: 2560x1440 hz: 144 dpi: 109 gamma: 1.2 scale: 1
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
Monitor-2: DP-3 pos: primary,left model: Samsung SMB1940W serial: <filter>
built: 2011 res: 1440x900 hz: 75 dpi: 90 gamma: 1.2 scale: 1.10000002384186
size: 408x255mm (16.06x10.04") diag: 481mm (18.9") ratio: 16:10 modes:
max: 1440x900 min: 720x400
Message: Wayland GBM/EGL data currently not available.
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 16.1 running: no
Sound Server-5: PipeWire v: 0.3.57 running: yes
Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Device-2: Guillemot RTL8188S WLAN Adapter type: USB driver: r8712u
bus-ID: 1-2:2 chip-ID: 06f8:e034 class-ID: 0000 serial: <filter>
IF: wlp0s20f0u2 state: up mac: <filter>
Local Storage: total: 238.47 GiB used: 39.88 GiB (16.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZNLN256HCHP-00000
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 100Q scheme: GPT
ID-1: / raw-size: 80 GiB size: 78.19 GiB (97.73%) used: 11.69 GiB (15.0%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: b459569f-9fdf-42ea-bfe1-e019aa921cde
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 175A-EB3B
ID-3: /home raw-size: 158.17 GiB size: 154.63 GiB (97.76%) used: 28.19 GiB
(18.2%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: ccf1931c-e593-4e58-9840-46a7ac511362
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-2:2 info: Guillemot RTL8188S WLAN Adapter type: Network
driver: r8712u interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-2: 1-6:3 info: Alcor Micro Hub ports: 4 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 058f:9254 class-ID: 0900
Hub-3: 1-6.1:4 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 12 Mb/s
chip-ID: 2109:2815 class-ID: 0900
Device-1: 1-6.1.2:6 info: Griffin PowerMate type: HID driver: powermate
interfaces: 1 rev: 1.0 speed: 1.5 Mb/s power: 100mA chip-ID: 077d:0410
class-ID: 0300
Device-2: 1-6.1.3:7 info: Logitech Cordless Mouse Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c539 class-ID: 0300
Device-3: 1-6.1.4:8 info: Apple Aluminium Keyboard (ANSI)
type: Keyboard,Mouse driver: apple,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 250mA chip-ID: 05ac:024f class-ID: 0301
Device-4: 1-6.3:5 info: Uni Class 2Port KVMSwitcher type: HID
power: 96mA chip-ID: 10d5:55a2 class-ID: 0300 serial: <filter>
Hub-4: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 51.0 C mobo: N/A
Processes: 193 Uptime: 5m wakeups: 2 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1041 libs: 288 tools: pamac,yay pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
running-in: foot inxi: 3.3.21
