PC doesn't turn off
Hi, I’m relatively new to linux, so my level is what it is.
Having said that, the problem is the following: sometimes, when I power off the system, the OS turns off but fans and lights in the PC stay on. I then need to shut it down manually (pressing the button). At restart there are no complains, so I guess the OS turns off properly.
This happened to me also before the last update, but I fixed the problem editing the grub configuration file to add acpi=force apm=power_off. After the last update, the problem started again but, as I said, it doesn’t happen all the time.
Where should I look for clues? I had a look at the logs and they look like this
journalctl -p 3 -b :
39s
dets  21 13:30:35 White-Whipy kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
dets  21 13:30:35 White-Whipy kernel: x86/cpu: SGX disabled or unsupported by BIOS.
dets  21 13:30:35 White-Whipy kernel: tpm_crb MSFT0101:00: \[Firmware Bug\]: ACPI region does not cover the entire command/response buffer. \[mem 0xfed40000-0xfed4087f flags 0x201\] vs fed40>
dets  21 13:30:35 White-Whipy kernel: scsi 6:0:0:1: Wrong diagnostic page; asked for 1 got 8
dets  21 13:30:35 White-Whipy kernel: scsi 6:0:0:1: Failed to get diagnostic page 0x1
dets  21 13:30:35 White-Whipy kernel: scsi 6:0:0:1: Failed to bind enclosure -19
dets  21 13:30:35 White-Whipy kernel: hid (null): invalid report_size 32768
dets  21 13:30:35 White-Whipy kernel: hid-generic 0003:05AC:0503.0001: invalid report_size 32768
dets  21 13:30:35 White-Whipy kernel: hid-generic 0003:05AC:0503.0001: item 0 4 1 7 parsing failed
dets  21 13:30:35 White-Whipy kernel: hid-generic 0003:05AC:0503.0001: probe with driver hid-generic failed with error -22
dets  21 13:30:36 White-Whipy kernel:
dets  21 13:30:37 White-Whipy bluetoothd\[811\]: Failed to set mode: Failed (0x03)
dets  21 13:36:28 White-Whipy gdm-password\]\[2141\]: gkr-pam: unable to locate daemon control file
dets  21 13:36:30 White-Whipy systemd\[2282\]: Failed to start Application launched by gnome-session-service.
Thanks for the help!
Edited to add system information as requested
~ ❯ inxi -zv8
  Kernel: 6.12.62-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=3cf5b4b2-4c1b-4a0b-8277-cef0e225a214 rw quiet splash apparmor=1
    security=apparmor resume=UUID=868b9f5d-5f3c-47c9-bf34-580999292715
    udev.log_priority=3 acpi=force apm=power_off
  Desktop: GNOME v: 49.2 tk: GTK v: 3.24.51 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 49.2 Distro: Manjaro
    base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX Z370-I GAMING v: Rev X.0x
    Firmware: UEFI vendor: American Megatrends v: 2202 date: 06/24/2019
  System RAM: total: 16 GiB available: 15.55 GiB used: 3.8 GiB (24.4%)
  Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
  Device-1: ChannelA-DIMM1 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 2667 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: Crucial part-no: BLS16G4D26BFSC.16FD
    serial: <filter>
  Device-2: ChannelB-DIMM1 type: no module installed
  Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/4600 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 76831
    dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
    hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid lahf_lm
    lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx
    pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36
    pti pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse
    sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust
    tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveopt xsaves
    xtopology xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
  Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: EVGA driver: nvidia
    v: 580.119.02 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
    status: current (as of 2025-11; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, DVI-D-1 bus-ID: 01:00.0
    chip-ID: 10de:1b06 class-ID: 0300
    compositor: gnome-shell driver: gpu: nvidia,nvidia-nvswitch display-ID: 0
  Monitor-1: HDMI-A-1 model: LG (GoldStar) TV serial: <filter> built: 2018
    res: 3840x2160 dpi: 61 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green:
    x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") ratio: 16:9
    modes: 3840x2160, 4096x2160, 1920x1080, 1280x1024, 1360x768, 1152x864,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 102 4: parse_edid:
    unhandled CEA mode 101 5: parse_edid: unhandled CEA mode 93 6: parse_edid:
    unhandled CEA mode 94 7: parse_edid: unhandled CEA mode 95 8: parse_edid:
    unhandled CEA mode 98 9: parse_edid: unhandled CEA mode 99 10: parse_edid:
    unhandled CEA mode 100
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
    x11: drv: nvidia inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.119.02
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2
    memory: 10.74 GiB display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
    x11: xprop,xrandr
  Device-1: NVIDIA GP102 HDMI Audio vendor: EVGA driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:10ef class-ID: 0403
  API: ALSA v: k6.12.62-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Microsoft Xbox Wireless Adapter for Windows driver: xone-dongle
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3
    chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
  Device-1: ASUSTek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 0b05:185c
  Local Storage: total: 5 TiB used: 1.41 TiB (28.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B7QCXE7 temp: 37.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD30EZRZ-00Z5HB0 size: 2.73 TiB block-size: physical: 4096 B
    logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 4004 scheme: GPT
  ID-1: / raw-size: 448.36 GiB size: 440.25 GiB (98.19%)
    used: 41.06 GiB (9.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 3cf5b4b2-4c1b-4a0b-8277-cef0e225a214
    used: 324 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: ABB1-DAC7
  ID-3: /media/My Book raw-size: 2.73 TiB size: 2.73 TiB (100.00%)
    used: 1.17 TiB (43.1%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18 label: My Book
    uuid: 5C9020CD9020B006
  ID-4: /mnt/Backup raw-size: 559.17 GiB size: 549.32 GiB (98.24%)
    used: 81.71 GiB (14.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: Backup
    uuid: 7f14b00a-9ad2-4738-9e68-6e316258f286
  ID-5: /mnt/Data raw-size: 1.27 TiB size: 1.25 TiB (98.35%)
    used: 118.42 GiB (9.2%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Data
    uuid: 7a6d40c2-c9bb-431c-9716-558145cf7af8
  ID-1: swap-1 type: partition size: 17.11 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 868b9f5d-5f3c-47c9-bf34-580999292715
  ID-1: /dev/sdb1 maj-min: 8:17 size: 200 MiB fs: vfat label: EFI
    uuid: 67E3-17ED
  Device-1: 1-6:2 info: Apple Apple Watch Magnetic Charging Cable type: HID
    driver: usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 05ac:0503 class-ID: 0300 serial: <filter>
  Device-2: 1-8:3 info: Microsoft Xbox Wireless Adapter for Windows
    type: WiFi driver: xone-dongle interfaces: 1 rev: 2.0
  Hub-2: 1-10:13 info: ROCCAT Sova MK Hub ports: 3 rev: 2.0
    chip-ID: 1e7d:2f93 class-ID: 0900
  Device-1: 1-10.1:15 info: Razer USA DeathAdder Elite type: mouse,keyboard
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:005c class-ID: 0300
  Device-2: 1-10.3:14 info: ROCCAT Sova MK Keyboard type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1e7d:2f94 class-ID: 0300
  Device-3: 1-11:5 info: ASETEK [NZXT Kraken X60] type: <vendor specific>
    driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 50mA chip-ID: 2433:b200 class-ID: 0000 serial: <filter>
  Device-4: 1-13:7 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:1872 class-ID: 0300
    serial: <filter>
  Device-5: 1-14:9 info: ASUSTek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0b05:185c class-ID: e001 serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
  Device-1: 2-3:2 info: Western Digital My Book 25EE type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 8mA chip-ID: 1058:25ee class-ID: 0806
    serial: <filter>
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 35.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1365 pm: pacman pkgs: 1350 libs: 364 tools: gnome-software,pamac
    pm: flatpak pkgs: 11 pm: snap pkgs: 4
    1: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    2: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    3: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    4: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    6: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    7: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    8: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 357
  1: cpu: 22.8% command: kgx pid: 14420 mem: 204.7 MiB (1.2%)
  2: cpu: 13.6% command: thunderbird pid: 13654 mem: 779.1 MiB (4.8%)
  3: cpu: 7.1% command: chromium pid: 14135 mem: 272.3 MiB (1.7%)
  4: cpu: 7.0% command: chromium pid: 14365 mem: 263.7 MiB (1.6%)
  5: cpu: 4.8% command: chromium pid: 14026 mem: 335.3 MiB (2.1%)
  Memory top: 5 of 357
  1: mem: 779.1 MiB (4.8%) command: thunderbird pid: 13654 cpu: 13.6%
  2: mem: 632.6 MiB (3.9%) command: gnome-shell pid: 2449 cpu: 1.9%
  3: mem: 489.4 MiB (3.0%) command: steamwebhelper pid: 7834 cpu: 0.0%
  4: mem: 402.8 MiB (2.5%) command: ./steamwebhelper pid: 7740 cpu: 0.2%
  5: mem: 335.3 MiB (2.1%) command: chromium pid: 14026 cpu: 4.8%
  Processes: 357 Power: uptime: 2h 49m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.19 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: kgx inxi: 3.3.40
Mod edit:- Corrected pre-formatted text as per forum guidelines. No charge.
In future, you are expected to attend to this yourself.
See How to Post Command Output as Preformatted Text :eyes:
Please provide your system information according to forum guidelines, as described (below).
I’m sure someone will help when they are able.
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
Required Reading
Highly Recommended
Work with us, not against us
It is important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem. Please also be prepared to provide output from commands if/when asked.
Simply waiting for others to ask you questions is counter-productive – typically, nobody has a :crystal_ball: at their disposal – and your clear, concise and accurate input is often relied upon in order to help you.
Please help others to make informed suggestions based on information you provide.
System Information
inxi -zv8 (short-form)
inxi man pages (manual)
Running `inxi` within a `chroot` environment
Your privacy is respected
Update Announcements
Technical Resources
