A few days ago I tried to format my external harddrive without having a clue how to do that correctly in Manjaro. If I remember correctly, I deleted the partition that existed on the external harddrive and created a new one. Unfortunately, I wasn’t able to copy any files over to the external harddrive after that, so I tried a few other things, I think I changed the mounting path, whatever that is. (I did all of this in GParted).
I must have done some harm to my Manjaro installation residing on my internal harddrive in the process, because while there were no errors or any alarming signs immediately after I had done my “experiments” with the external harddrive, when I tried to boot the computer again with the external harddrive disconnected, it failed with an error message I couldn’t get past.
I later discovered, to my surprise, that the PC boots just fine if I plug in the external harddrive before I press the on button.
Following is the output of inxi:
[vivian@Viviversum ~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=65eb49fc-1c79-44a8-949d-30220ce34760 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Hewlett-Packard
product: HP Compaq dc7700p Convertible Minitower v: N/A serial: <filter>
Chassis: type: 6 serial: <filter>
Mobo: Hewlett-Packard model: 0A58h serial: <filter> BIOS: Hewlett-Packard
v: 786E1 v02.10 date: 04/13/2007
Device-1: hidpp_battery_0 model: Logitech Performance MX serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 7.65 GiB used: 2.44 GiB (31.9%)
Info: Dual Core model: Intel Core2 6400 bits: 64 type: MCP arch: Core Merom
family: 6 model-id: F (15) stepping: 2 microcode: 5D cache: L2: 2 MiB
bogomips: 8509
Speed: 1595 MHz min/max: 1596/2133 MHz Core speeds (MHz): 1: 1595 2: 1595
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid
cx16 cx8 de ds_cpl dtes64 dtherm dts est fpu fxsr ht lahf_lm lm mca mce mmx
monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge pni pse pse36 pti
rep_good sep sse sse2 ssse3 syscall tm tm2 tsc vme xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Micro-Star MSI
driver: nvidia v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:128b class-ID: 0300
Screen-1: 0 s-res: 1280x1024 s-dpi: 85 s-size: 382x302mm (15.0x11.9")
s-diag: 487mm (19.2")
Monitor-1: DVI-D-0 res: 1280x1024 dpi: 86 size: 380x300mm (15.0x11.8")
diag: 484mm (19.1")
OpenGL: renderer: NVIDIA GeForce GT 710/PCIe/SSE2 v: 4.6.0 NVIDIA 470.57.02
direct render: Yes
Device-1: Intel 82801H HD Audio vendor: Hewlett-Packard Compaq dc7700p
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:284b
class-ID: 0403
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e0f
class-ID: 0403
Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Intel 82566DM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: 2100 bus-ID: 00:19.0 chip-ID: 8086:104a
class-ID: 0200
IF: enp0s25 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
driver: btusb v: 0.8 bus-ID: 5-1:2 chip-ID: 0a12:0001 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: down
bt-service: enabled,running rfk-block: hardware: no software: no
address: <filter>
Local Storage: total: 1.13 TiB used: 99.75 GiB (8.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: R013 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD Elements 25A2 size: 931.48 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1014
scheme: MBR
Optical-1: /dev/sr0 vendor: TSSTcorp model: DVD-ROM TS-H353B rev: BC03
dev-links: cdrom
Features: speed: 48 multisession: yes audio: yes dvd: yes rw: none
state: running
ID-1: / raw-size: 223.56 GiB size: 219.05 GiB (97.98%)
used: 99.75 GiB (45.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 65eb49fc-1c79-44a8-949d-30220ce34760
ID-2: /run/media/vivian/backups raw-size: 931.48 GiB
size: 915.79 GiB (98.32%) used: 28 KiB (0.0%) fs: ext4 dev: /dev/sdb1
maj-min: 8:17 label: backups uuid: 4afefefc-8738-457f-a109-411df0059115
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-4:2 info: Western Digital Elements 25A2 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA
chip-ID: 1058:25a2 class-ID: 0806 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Device-1: 5-1:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Device-1: 6-1:2 info: Logitech Keyboard K120 type: Keyboard,HID
power: 90mA chip-ID: 046d:c31c class-ID: 0300
Device-2: 6-2:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
System Temperatures: cpu: 47.0 C mobo: N/A gpu: nvidia temp: 50 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 50%
Processes: 181 Uptime: 1h 20m wakeups: 8 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1624 lib: 439
flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
dmesg errors, warnings:
[vivian@Viviversum ~]$ sudo dmesg --level emerg,alert,crit,err,warn
[sudo] password for vivian:
[ 0.283428] x86/cpu: VMX (outside TXT) disabled by BIOS
[ 0.394753] core: PEBS disabled due to CPU errata
[ 0.403363] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.419935] ACPI BIOS Error (bug): \_SB.PCI0._OSC: Excess arguments - ASL declared 5, ACPI requires 4 (20200925/nsarguments-162)
[ 0.420036] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0._OSC.CAPD], AE_ALREADY_EXISTS (20200925/dsfield-184)
[ 0.420043] ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20200925/dswload2-477)
[ 0.420049] ACPI Error: Aborting method \_SB.PCI0._OSC due to previous error (AE_ALREADY_EXISTS) (20200925/psparse-529)
[ 0.456737] pnp 00:07: disabling [io 0xf800-0xf81f] because it overlaps 0000:00:1f.0 BAR 13 [io 0xf800-0xf87f]
[ 0.456740] pnp 00:07: disabling [io 0xf820-0xf83f] because it overlaps 0000:00:1f.0 BAR 13 [io 0xf800-0xf87f]
[ 0.456742] pnp 00:07: disabling [io 0xf840-0xf85f] because it overlaps 0000:00:1f.0 BAR 13 [io 0xf800-0xf87f]
[ 0.456745] pnp 00:07: disabling [io 0xf860-0xf87f] because it overlaps 0000:00:1f.0 BAR 13 [io 0xf800-0xf87f]
[ 2.163016] sd 2:0:0:0: [sdb] No Caching mode page found
[ 2.163020] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 9.777923] nvidia: loading out-of-tree module taints kernel.
[ 9.777943] nvidia: module license 'NVIDIA' taints kernel.
[ 9.777945] Disabling lock debugging due to kernel taint
[ 10.359563] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.57.02 Tue Jul 13 16:14:05 UTC 2021
[ 10.696269] coretemp coretemp.0: Using relative temperature scale!
[ 10.711771] coretemp coretemp.0: Using relative temperature scale!
[ 13.737789] kauditd_printk_skb: 33 callbacks suppressed
[ 14.935250] resource sanity check: requesting [mem 0x000e0000-0x000fffff], which spans more than pnp 00:09 [mem 0x000d0a00-0x000e3fff]
[ 14.935661] caller _nv033140rm+0x2a/0x60 [nvidia] mapping multiple BARs
[ 15.158404] resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than pnp 00:09 [mem 0x000d0a00-0x000e3fff]
[ 15.158936] caller _nv000722rm+0x1ad/0x200 [nvidia] mapping multiple BARs
[ 19.351259] kauditd_printk_skb: 38 callbacks suppressed
[ 30.024494] kauditd_printk_skb: 5 callbacks suppressed
[ 2261.105359] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 2266.385190] blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
[ 2266.520449] blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
[ 2266.520455] Buffer I/O error on dev sr0, logical block 0, async page read
[ 2266.520459] Buffer I/O error on dev sr0, logical block 1, async page read
[ 2266.612165] blk_update_request: I/O error, dev sr0, sector 1024 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 2266.733769] blk_update_request: I/O error, dev sr0, sector 1024 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
[ 2266.733775] Buffer I/O error on dev sr0, logical block 256, async page read
[ 2266.733779] Buffer I/O error on dev sr0, logical block 257, async page read
[ 2266.833750] blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 2 prio class 0
[ 2266.833756] Buffer I/O error on dev sr0, logical block 0, async page read
[ 2266.833760] Buffer I/O error on dev sr0, logical block 1, async page read
[ 3143.889535] sd 5:0:0:0: Power-on or device reset occurred
[ 3145.914809] ready
[ 3153.056217] FAT-fs (sdc): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 3213.242650] blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 3 prio class 0
[ 3213.272008] blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 3213.272013] Buffer I/O error on dev sr0, logical block 0, async page read
[ 3213.298514] blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 3213.298520] Buffer I/O error on dev sr0, logical block 1, async page read
[ 3213.322016] blk_update_request: I/O error, dev sr0, sector 1024 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[ 3213.351870] blk_update_request: I/O error, dev sr0, sector 1024 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 3213.351875] Buffer I/O error on dev sr0, logical block 256, async page read
[ 3213.375174] blk_update_request: I/O error, dev sr0, sector 1028 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 3213.375180] Buffer I/O error on dev sr0, logical block 257, async page read
[ 3213.417748] blk_update_request: I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 3213.417754] Buffer I/O error on dev sr0, logical block 0, async page read
[ 3213.449735] blk_update_request: I/O error, dev sr0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 3213.449740] Buffer I/O error on dev sr0, logical block 1, async page read
dmesg info on usb devices:
[vivian@Viviversum ~]$ sudo dmesg | grep usb
[ 0.429575] usbcore: registered new interface driver usbfs
[ 0.429586] usbcore: registered new interface driver hub
[ 0.429595] usbcore: registered new device driver usb
[ 0.680705] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 0.680709] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.680711] usb usb1: Product: EHCI Host Controller
[ 0.680714] usb usb1: Manufacturer: Linux 5.10.56-1-MANJARO ehci_hcd
[ 0.680716] usb usb1: SerialNumber: 0000:00:1a.7
[ 0.697516] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 0.697519] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.697522] usb usb2: Product: EHCI Host Controller
[ 0.697524] usb usb2: Manufacturer: Linux 5.10.56-1-MANJARO ehci_hcd
[ 0.697526] usb usb2: SerialNumber: 0000:00:1d.7
[ 0.698208] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 0.698211] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.698213] usb usb3: Product: UHCI Host Controller
[ 0.698215] usb usb3: Manufacturer: Linux 5.10.56-1-MANJARO uhci_hcd
[ 0.698216] usb usb3: SerialNumber: 0000:00:1a.0
[ 0.698777] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 0.698780] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.698782] usb usb4: Product: UHCI Host Controller
[ 0.698783] usb usb4: Manufacturer: Linux 5.10.56-1-MANJARO uhci_hcd
[ 0.698785] usb usb4: SerialNumber: 0000:00:1a.1
[ 0.699334] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 0.699337] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.699338] usb usb5: Product: UHCI Host Controller
[ 0.699340] usb usb5: Manufacturer: Linux 5.10.56-1-MANJARO uhci_hcd
[ 0.699342] usb usb5: SerialNumber: 0000:00:1d.0
[ 0.699887] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 0.699890] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.699891] usb usb6: Product: UHCI Host Controller
[ 0.699893] usb usb6: Manufacturer: Linux 5.10.56-1-MANJARO uhci_hcd
[ 0.699895] usb usb6: SerialNumber: 0000:00:1d.1
[ 0.700198] usbcore: registered new interface driver usbserial_generic
[ 0.700205] usbserial: USB Serial support registered for generic
[ 0.933701] usb 1-4: new high-speed USB device number 2 using ehci-pci
[ 1.138977] usb 1-4: New USB device found, idVendor=1058, idProduct=25a2, bcdDevice=10.14
[ 1.138982] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.138985] usb 1-4: Product: Elements 25A2
[ 1.138988] usb 1-4: Manufacturer: Western Digital
[ 1.138990] usb 1-4: SerialNumber: 575833314137364636385538
[ 1.144306] usb-storage 1-4:1.0: USB Mass Storage device detected
[ 1.144509] scsi host2: usb-storage 1-4:1.0
[ 1.144611] usbcore: registered new interface driver usb-storage
[ 1.146814] usbcore: registered new interface driver uas
[ 1.151312] usb 5-1: new full-speed USB device number 2 using uhci_hcd
[ 1.357364] usb 5-1: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice=88.91
[ 1.357368] usb 5-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1.357370] usb 5-1: Product: CSR8510 A10
[ 1.976371] usb 6-1: new low-speed USB device number 2 using uhci_hcd
[ 2.167242] usb 6-1: New USB device found, idVendor=046d, idProduct=c31c, bcdDevice=64.00
[ 2.167247] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.167255] usb 6-1: Product: USB Keyboard
[ 2.167257] usb 6-1: Manufacturer: Logitech
[ 2.213905] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:1d.1/usb6/6-1/6-1:1.0/0003:046D:C31C.0001/input/input4
[ 2.269824] hid-generic 0003:046D:C31C.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-0000:00:1d.1-1/input0
[ 2.295115] input: Logitech USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:1d.1/usb6/6-1/6-1:1.1/0003:046D:C31C.0002/input/input5
[ 2.349725] input: Logitech USB Keyboard System Control as /devices/pci0000:00/0000:00:1d.1/usb6/6-1/6-1:1.1/0003:046D:C31C.0002/input/input6
[ 2.349835] hid-generic 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-0000:00:1d.1-1/input1
[ 2.349888] usbcore: registered new interface driver usbhid
[ 2.349889] usbhid: USB HID core driver
[ 2.896209] usb 6-2: new full-speed USB device number 3 using uhci_hcd
[ 3.091231] usb 6-2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.01
[ 3.091235] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.091237] usb 6-2: Product: USB Receiver
[ 3.091240] usb 6-2: Manufacturer: Logitech
[ 3.099864] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1d.1/usb6/6-2/6-2:1.0/0003:046D:C52B.0003/input/input7
[ 3.157157] hid-generic 0003:046D:C52B.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:1d.1-2/input0
[ 3.162360] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:1d.1/usb6/6-2/6-2:1.1/0003:046D:C52B.0004/input/input8
[ 3.162462] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:1d.1/usb6/6-2/6-2:1.1/0003:046D:C52B.0004/input/input9
[ 3.217133] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:1d.1/usb6/6-2/6-2:1.1/0003:046D:C52B.0004/input/input10
[ 3.217299] hid-generic 0003:046D:C52B.0004: input,hiddev96,hidraw3: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1d.1-2/input1
[ 3.221138] hid-generic 0003:046D:C52B.0005: hiddev97,hidraw4: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1d.1-2/input2
[ 3.367575] logitech-djreceiver 0003:046D:C52B.0005: hiddev96,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1d.1-2/input2
[ 3.483321] input: Logitech Wireless Device PID:200a Keyboard as /devices/pci0000:00/0000:00:1d.1/usb6/6-2/6-2:1.2/0003:046D:C52B.0005/0003:046D:200A.0006/input/input12
[ 3.483562] input: Logitech Wireless Device PID:200a Consumer Control as /devices/pci0000:00/0000:00:1d.1/usb6/6-2/6-2:1.2/0003:046D:C52B.0005/0003:046D:200A.0006/input/input13
[ 3.483633] input: Logitech Wireless Device PID:200a System Control as /devices/pci0000:00/0000:00:1d.1/usb6/6-2/6-2:1.2/0003:046D:C52B.0005/0003:046D:200A.0006/input/input14
[ 3.483718] hid-generic 0003:046D:200A.0006: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Device PID:200a] on usb-0000:00:1d.1-2/input2:2
[ 3.485201] input: Logitech Wireless Device PID:4004 Keyboard as /devices/pci0000:00/0000:00:1d.1/usb6/6-2/6-2:1.2/0003:046D:C52B.0005/0003:046D:4004.0007/input/input18
[ 3.485441] input: Logitech Wireless Device PID:4004 Consumer Control as /devices/pci0000:00/0000:00:1d.1/usb6/6-2/6-2:1.2/0003:046D:C52B.0005/0003:046D:4004.0007/input/input19
[ 3.485510] input: Logitech Wireless Device PID:4004 System Control as /devices/pci0000:00/0000:00:1d.1/usb6/6-2/6-2:1.2/0003:046D:C52B.0005/0003:046D:4004.0007/input/input20
[ 3.485586] hid-generic 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4004] on usb-0000:00:1d.1-2/input2:1
[ 3.486975] input: Logitech Wireless Device PID:101a Mouse as /devices/pci0000:00/0000:00:1d.1/usb6/6-2/6-2:1.2/0003:046D:C52B.0005/0003:046D:101A.0008/input/input24
[ 3.487064] hid-generic 0003:046D:101A.0008: input,hidraw5: USB HID v1.11 Mouse [Logitech Wireless Device PID:101a] on usb-0000:00:1d.1-2/input2:3
[ 3.640559] input: Logitech K350 as /devices/pci0000:00/0000:00:1d.1/usb6/6-2/6-2:1.2/0003:046D:C52B.0005/0003:046D:200A.0006/input/input28
[ 3.640790] logitech-hidpp-device 0003:046D:200A.0006: input,hidraw3: USB HID v1.11 Keyboard [Logitech K350] on usb-0000:00:1d.1-2/input2:2
[ 3.774541] input: Logitech K360 as /devices/pci0000:00/0000:00:1d.1/usb6/6-2/6-2:1.2/0003:046D:C52B.0005/0003:046D:4004.0007/input/input29
[ 3.774780] logitech-hidpp-device 0003:046D:4004.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech K360] on usb-0000:00:1d.1-2/input2:1
[ 3.796318] input: Logitech Performance MX as /devices/pci0000:00/0000:00:1d.1/usb6/6-2/6-2:1.2/0003:046D:C52B.0005/0003:046D:101A.0008/input/input30
[ 3.796457] logitech-hidpp-device 0003:046D:101A.0008: input,hidraw5: USB HID v1.11 Mouse [Logitech Performance MX] on usb-0000:00:1d.1-2/input2:3
[ 13.211548] usbcore: registered new interface driver btusb
[ 3142.721218] usb 1-3: new high-speed USB device number 3 using ehci-pci
[ 3142.872034] usb 1-3: New USB device found, idVendor=054c, idProduct=09c0, bcdDevice= 1.00
[ 3142.872039] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3142.872042] usb 1-3: Product: WALKMAN
[ 3142.872044] usb 1-3: Manufacturer: Sony
[ 3142.872047] usb 1-3: SerialNumber: 1100AD55478844
[ 3142.873253] usb-storage 1-3:1.0: USB Mass Storage device detected
[ 3142.874528] scsi host5: usb-storage 1-3:1.0
[ 3448.877799] usb 1-3: USB disconnect, device number 3
How can I restore my PC to its former behaviour (booting into OS from internal HDD regardless if external HDD is connected or not)?
How can I format my external HDD correctly so it becomes usable again?
Then I decided to take a risk and delete the whole sdb section from fstab, and everything still works fine after a reboot.
