DE - i3wm
Since yesterday’s big update, my bluetooth headphones are no longer being recognized by pavucontrol as either an input or output device. (I am successfully able to connect my headphone to my laptop via bluetooth)
DE - i3wm
We may be having the same issues; I’m on KDE. My thread: Anker Soundcore Life Q20 Bluetooth Headset Doesn't Show Up as Output/Input Device
Hopefully someone more experienced could point us in the right direction soon.
seems there are bugs in the latest pulseaudio
you may try to downgrade to 13.99.2 for the moment (libpulse pulseaudio pulseaudio-zeroconf)
The recent stable updates replaced Pulseaudio v13.03 with v13.99.3
so v13.99.2 is unlikely to be available for downgrade
and downgrading is only a way to postpone fixing the problem (“for the moment”)
The problem is likely to be that the Pulseaudio update created .pacnew files instead of overwriting system configuration files modified by the user
there is usually a warning during the update process about this
[ALPM] warning: /etc/pulse/daemon.conf installed as /etc/pulse/daemon.conf.pacnew
[ALPM] warning: /etc/pulse/default.pa installed as /etc/pulse/default.pa.pacnew
The new configuration in the .pacnew file must be merged with the configuration file without removing user modifications
When you say merged, do you mean append the contents of one file to the other or something similar?
Or do you mean look at the contents of both the files and create a single one?
Also, the single file after the merge would be the file with the pacnew extension?
PulseAudio update will create a .pacnew file if you have changed any of the PulseAudio configuration files in folder /etc/pulse/ (so any user changes are not replaced)
suggest you check if you have any .pacnew files that need attention
ls /etc/pulse/ | grep *.pacnew
PulseAudio does not read from .pacnew files, only the original configuration files
so it will not have the updated configuration
the original configuration file and it’s corresponding .pacnew file need to be compared by the user to make sure any changes in the .pacnew file are merged with the configuration file and retain user-specific changes
when the changes have been merged the .pacnew file can be deleted
I suggest you check this discussion for how to merge .pacnew files using meld or pacdiff
Good tutorial around pacnew needed
Or this BASH script to find any .pacnew files and open them in meld
There were a looot of pacnew files in my system (I never merged any of them).
Thanks! I merged all the pacnew files that were laying around in my system using this ![]()
Unfortunately, pavucontrol is again unable to detect my headphones. (Pulseaudio 13.03 works)
I suggest you check the link from @xfceman to see how to post relevant information needed for troubleshooting bluetooth connection to headphones
Hi,
after latest update(s) this week (12/2020), I got pretty much similar issue as OP.
I tried to access my Discord app, which worked quite well before, and found that my microfone is no longer working. I’m using it on my front input device at my case, that is connected with my Asus M5A99FX Pro R2.0 mainboard’s onboard sound connector. I checked the input device at Discord, but I wasn’t able to choose one. Then I checked the audio devices setup, but it was missing there too, while the rear-panel device was still found. Probably the driver unit was removed or broken, can’t say.
As I’m using a SSD-switch I can easily change between different OS on the very same machine and tested with Windows 7, where the audio device worked, even with Discord. Tests with other Linux OS’ (Solus OS, ArcoLinux) showed pretty much the same result as with Manjaro, so this points toward a driver issue, probably a kernel issue to me.
The rear panel audio worked as desired on all tested OS’.
Any idea how to solve this?
Works for me with the latest updates.
These are the relevant packages and their versions -
